Willsy Posted October 25, 2012 Share Posted October 25, 2012 HEX 000E CODE: TEST 02E0 WORKSPACE , C820 A00A ' TEST + , 02E0 0000 ;CODE DECIMAL Unfortunately that won't work, Lee, as CODE: only permits numeric literals. It should be a relatively trivial mod to change the interpreter to permit it, however. I'll take a look at it! Quote Link to comment Share on other sites More sharing options...
Willsy Posted October 25, 2012 Share Posted October 25, 2012 I like it! Did you get a chance to look at the abortion I posted just above. ...lee I did! It is very hacky, but it could have it's uses. I don't like the limitation of CODE: only being able to process numeric literals. Though it's actually a limitation of the interpreter/compiler. I'm going to see if I can change it. It won't take any extra ROM space, and more flexibility can only be a good thing! So, did my diatribe make sense to you? It only just about made sense to me!! Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 25, 2012 Author Share Posted October 25, 2012 (edited) Unfortunately that won't work, Lee, as CODE: only permits numeric literals. It should be a relatively trivial mod to change the interpreter to permit it, however. I'll take a look at it! Trust me. I tried it. It works! I would not have posted it otherwise. ...lee Edited October 26, 2012 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 25, 2012 Author Share Posted October 25, 2012 (edited) ... So, did my diatribe make sense to you? It only just about made sense to me!! It did, indeed. ...lee Edited October 25, 2012 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
Willsy Posted October 26, 2012 Share Posted October 26, 2012 Lee and anyone else that is interested Quiet at work so spent an afternoon hacking. I thought I would have a go at writing an ED/AS option 3 loader for TF. It could have it's uses... Anyway, after reading the tagged object code loader spec in the ED/AS and physically looking at a few object files I managed to work it out. The following loader is able to successfully load the following assembly code (when assembled into an object file, of course!) VBLNK EQU >83D7 ; VERTICAL BLANK COUNTER VDPR EQU >8800 ; VDP READ REGISTER VDPW EQU >8C00 ; VDP WRITE REGISTER VDPA EQU >8C02 ; VDP ADDRESS REGISTER AORG >A900 LI R1,'!'*256 START CLR R0 LI R2,40*24 AGAIN BL @VSBW INC R0 DEC R2 JNE AGAIN AI R1,>0100 JMP START VSBW ORI R0,>4000 SWPB R0 MOVB R0,@VDPA SWPB R0 MOVB R0,@VDPA MOVB R1,@VDPW XOR @BIT1,R0 RT BIT1 DATA >4000 AORG >FACE DATA 1,2,3,4,5,6,7,8,9,10 DATA 10,9,8,7,6,5,4,3,2,1 DATA >994A END The loader itself is nothing special (seems quite fast though). It only supports the 9 tag (set address) and the B tag (load data). It does not support REF or DEF. It does support AORG. Anyway, using classic99 I ran the loader, and then examined the memory using the debugger, and there was the code! I then set the PC to A900 and voila! The machine code ran just fine! Woohoo! I might have a look at supporting the DEF directive. Any DEF'd code could generate dictionary entries: DEF START START CLR R0 ... ... Would actually create a dictionary entry called START that, when executed, does a branch to that address! I don't know if supporting REF would have much use inside the TF environment... Any code written with the TI assembler for TF would probably want to be AORG'd, and the EA utilities such as VMBR KSCAN et al are no use inside TF - they're not there - and anyway, supporting REF seems complex - resolving REFd entries seems to be walking a big long chain, as far as I can see. Quite clever. Here is the loader code: FORGET LLen 0 VALUE LLen \ line length 0 VALUE LAddr \ address of line in memory 0 VALUE LPos \ current position in line 0 VALUE CAddr \ code load address FALSE VALUE #3debug : SetAddress 1 +TO Lpos Laddr Lpos + 4 NUMBER DROP TO CAddr #3debug IF CR ." Set load address:" CAddr $. CR THEN 3 +TO LPos ; : LoadData 1 +TO Lpos Laddr Lpos + 4 NUMBER DROP DUP CAddr ! #3debug IF $. ELSE DROP THEN 2 +TO Caddr 4 +TO LPos ; : ParseLine BEGIN LAddr Lpos + C@ CASE ASCII 9 OF SetAddress ENDOF ASCII B OF LoadData ENDOF ASCII : OF 999 TO LPos ENDOF ASCII 7 OF 999 to LPos ENDOF 1 +TO LPos ENDCASE Lpos LLen > UNTIL ; fbuf: objFile : #3LOAD ZEROS @ >R BASE @ >R 16 BASE ! TRUE ZEROS ! s" DSK2.AL-TEST.OBJ DF80SI" objFile FILE objFile #OPEN ABORT" Cant open object file" BEGIN objFile #EOF? NOT WHILE PAD objFile #GET ABORT" Cant read from file" PAD COUNT TO LLen DROP \ set line length PAD 1+ TO LAddr \ set line address 0 TO Lpos \ 0 line position ParseLine REPEAT objFile #CLOSE R> BASE ! R> ZEROS ! ; #3LOAD And here are the files as text files. option 3 loader.txt AL-TEST.txt Enjoy! Quite pleased with this! Mark Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 26, 2012 Author Share Posted October 26, 2012 (edited) Lee and anyone else that is interested ... Enjoy! Quite pleased with this! Mark Wow! Even though I already worked out how to load a binary image produced from an object file, I may switch to this because I won't have to keep track of the size every time I change the ALC!---especially if your loader updates the available-memory-size indicators. Does it? ...lee Edited October 26, 2012 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 26, 2012 Author Share Posted October 26, 2012 Lee and anyone else that is interested ... It does not support REF or DEF. It does support AORG. ... Mark As long as I don't care about the REF/DEF table, i.e., not using DEFed labels in other programs' REFs, I should still be able to use DEFs for program clarity, right? ...lee Quote Link to comment Share on other sites More sharing options...
Willsy Posted October 26, 2012 Share Posted October 26, 2012 You shouldn't be using def for program clarity. DEF is designed to make an entry in the ref/ def table for calling either by call link or by entering a program name into the prompt in editor/ assembler. Excuse the typos. Bloody touch pad rubbish! I'm going to have a look at def though. I can't make head or tail of the editor assembler book so I'll just study a dump of an object file. Should be able to work it out. Ref is of dubious utility in my opinion. What do you think? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 26, 2012 Author Share Posted October 26, 2012 (edited) You shouldn't be using def for program clarity. DEF is designed to make an entry in the ref/ def table for calling either by call link or by entering a program name into the prompt in editor/ assembler. ... You're right, of course. I guess I should take out the DEFs in the FPLTF code to prevent the DEF garbage at the end of the file. Or, does your loader ignore it? Ref is of dubious utility in my opinion. What do you think? I can't think why we would need it in TF. Any AORGed programs written to work in the TF environment can use EQUates I should think. ...lee Edited October 26, 2012 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
Willsy Posted October 26, 2012 Share Posted October 26, 2012 Good point about updating the memory pointers. Excellent idea! The solution is to use comma to load the data instead of ! and then the pointers are updated for free. So SetAddress should set H and load data should just comma the data in. I'll do it this evening! Mark Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 26, 2012 Author Share Posted October 26, 2012 Good point about updating the memory pointers. Excellent idea! The solution is to use comma to load the data instead of ! and then the pointers are updated for free. So SetAddress should set H and load data should just comma the data in. I'll do it this evening! Mark Cool beans!! ...lee Quote Link to comment Share on other sites More sharing options...
Willsy Posted October 26, 2012 Share Posted October 26, 2012 Currently I think the loader will choke on def - give it a try! I'll add def to it though, so it will be supported. I'll later write the opposite: take assembler code from ram and export it to a df80in object format! Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 26, 2012 Author Share Posted October 26, 2012 (edited) Unfortunately that won't work, Lee, as CODE: only permits numeric literals. It should be a relatively trivial mod to change the interpreter to permit it, however. I'll take a look at it! Trust me. I tried it. It works! I would not have posted it otherwise. ...lee Mark... You didn't respond to this. Did you see it? ...lee Edited October 26, 2012 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
Rod Van Orden Posted October 26, 2012 Share Posted October 26, 2012 Lee: It looks like you and Mark have been really busy here. Things are looking good! I am uploading a file for an expanded version of the words definition. I called it WORDS+ I combined a few things, and I used some of the code you sent me. I'm in the ballpark....... but I'm not finished yet. The routine reads the TF Word Dictionary. However, so far I have not corrected the logic (or illogic) which reads passed the end of the dictionary in memory. This shows up in the last display screen of the running routine. The TF word EXIT seems to be the last word in the dictionary. I could test for that and stop the loop at that point. There may be a half dozen other ways to do this. Anyway.... take a look and let me know what you think. Rod Van Orden WORDS+.zip Quote Link to comment Share on other sites More sharing options...
Willsy Posted October 26, 2012 Share Posted October 26, 2012 Mark... You didn't respond to this. Did you see it? ...lee Yeah I saw it I'm just not convinced! Try: 9 constant n Code: test n n n ;code See? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 26, 2012 Author Share Posted October 26, 2012 Yeah I saw it I'm just not convinced! Try: 9 constant n Code: test n n n ;code See? What's your point? CODE: sees the name of the constant and does nothing because the name is not a number. n just executes, pushing 9 onto the stack. My point is that anything presented to CODE: that is not seen as a literal number is ignored and passed to the interpreter. If you want to put the executed result into the CODE:ed word at that point, you simply comma ( , ) it: CODE: TEST n , n , n , ;CODE When you want to use a literal number in a calculation before compiling the result with comma, you must put it on the stack prior to CODE: and use it in the proper order in the embedded calculation followed by comma. Works like a charm! ...lee Quote Link to comment Share on other sites More sharing options...
Willsy Posted October 26, 2012 Share Posted October 26, 2012 Oh yes! I wrote it and I don't understand it! I'm so dumb! I guess you could also use [ & ] so you don't have to put stuff on the stack before calling code: ? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 26, 2012 Author Share Posted October 26, 2012 Rod... The logic for stopping when you get to the beginning of the dictionary must check that the first word's previous-word pointer contains a 0, indicating that there are no more words before it. The place in @Willsy's code where that is checked is in words : : words ... begin @ dup @ while ... ; The first @ gets the address of the previous word (the current last word from latest the first time through), which actually contains the address of the word before it, which the second @ gets. This second value will be 0 just after the routine displays the first word in the dictionary. Your code is DUPing the address of latest the first time through, when it should be DUPing the address of the last word with @ before DUP . I would put back the @'s around DUP in words+ as in the code snippet in words above and remove the @ in scr-wrd to maintain the other logic (I think!). ...lee Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 26, 2012 Author Share Posted October 26, 2012 Oh yes! I wrote it and I don't understand it! I'm so dumb! I guess you could also use [ & ] so you don't have to put stuff on the stack before calling code: ? I think I tried that to no avail; but, I will look at it again. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 26, 2012 Author Share Posted October 26, 2012 (edited) Oh yes! I wrote it and I don't understand it! I'm so dumb! I guess you could also use [ & ] so you don't have to put stuff on the stack before calling code: ? In looking at your ALC for CODE: , ;CODE , [ , ] and INTERPRET , that won't work because [ and ] change _state but not coding , while CODE: and ;CODE change coding but not _state . I'm actually not sure what's going on inside the coded word definition when the interpreter sees compile mode while it is coding---I had to re-boot TF because something went awry! I think I actually prefer the way TIF handles this, viz., TIF's CODE (sort of equivalent to TF's CODE: but not as smart) just establishes the header for the dictionary entry and nothing else. The programmer must compile each number with comma ( , ) and properly terminate the word with hex 045F , TIF's machine code equivalent of NEXT, (sort of equivalent to TF's ;CODE but not as smart). For further comparison TF uses CODE and NEXT, pretty much as TF uses ASM: and ;ASM ; TIF uses CODE and hex 045F as TF uses CODE: and ;CODE . H-m-m-m, never mind! TF's way is clearer except for the non-coding-number stuff. Perhaps you could implement [ and ] equivalents for coding, say { and } . ...lee Edited October 26, 2012 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 26, 2012 Author Share Posted October 26, 2012 (edited) Yeah I saw it I'm just not convinced! Try: 9 constant n Code: test n n n ;code See? What's your point? CODE: sees the name of the constant and does nothing because the name is not a number. n just executes, pushing 9 onto the stack. My point is that anything presented to CODE: that is not seen as a literal number is ignored and passed to the interpreter. If you want to put the executed result into the CODE:ed word at that point, you simply comma ( , ) it: CODE: TEST n , n , n , ;CODE When you want to use a literal number in a calculation before compiling the result with comma, you must put it on the stack prior to CODE: and use it in the proper order in the embedded calculation followed by comma. Works like a charm! ...lee Actually, I got this backwards. CODE: is not doing anything after establishing the header and setting an ALC variable (coding). The interpreter is in charge and executes any word it finds before it ever checks to see if it is a number. It does other things after that if the input is not a TF word; but, the last thing but one that the interpreter does before giving up and issuing an error message is to check whether the input item is a number. If it is, it pushes it onto the stack. Only then does it check whether coding is set. If coding is set, the number on the stack is popped off and compiled into the dictionary at HERE . ...lee Edited October 26, 2012 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
Rod Van Orden Posted October 26, 2012 Share Posted October 26, 2012 Lee: Thanks for the look / see. I will finish off the WORDS+ corrections this weekend. Have a good weekend. Rod Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 26, 2012 Author Share Posted October 26, 2012 Lee: Thanks for the look / see. I will finish off the WORDS+ corrections this weekend. Have a good weekend. Rod You, as well, Rod. Quote Link to comment Share on other sites More sharing options...
Willsy Posted October 26, 2012 Share Posted October 26, 2012 Yes, I like the idea of {{ and }} very much! Back to the loader... 'Tis done... It now processes DEF directives, and, furthermore, it creates dictionary entries for them! So, after a loading a routine, you can type it's name to run it! Here's a video! The memory pointers are also updated. Source code attached - I'm about to start work on removing the debug option and putting it in a couple of blocks. Will post when done. I've also attached the source code that I used as my test platform. I used ASM994A to produce an object file *directly* into Classic99's DSK2 folder. The loader loads this object file and processes it, loading into the correct memory address (as per the AORG directive) and creating a dictionary entry for the DEF'd address. Cool. http://youtu.be/ryaSh-7iyl4 AL-TEST.txt option 3 loader.txt Quote Link to comment Share on other sites More sharing options...
Willsy Posted October 26, 2012 Share Posted October 26, 2012 Rod, What do I do with the words+ file in the zip file? I tried putting it in a classic99 DSK folder but classic99 can't process it. What type of file is it? Mark Quote Link to comment Share on other sites More sharing options...
