SlowCoder #1 Posted August 25, 2012 Pretty well everywhere I go, I hear the only way to "fix" a worn out joystick is by replacing it. You can find replacement joysticks for around $10 online, which I don't really think is worth it unless you really want NEW. Otherwise, for about the same price, maybe a little more, you can just buy a replacement controller. The main problem appears to be that the dome inside the joystick gets worn out, very rough and uneven. If I knew the proper ball diameter of the dome I thought maybe I could coat the dome with a layer of resin/epoxy and insert a carefully measured mold (marble?) to reshape the resin in the dome and create a new surface. As an alternative to using epoxy/resin I could make a "sacrificial lamb" of one controller joystick and have enough plastic to fix others by melting it into the mold. What do you think about this? Quote Share this post Link to post Share on other sites
Rex Dart #2 Posted August 25, 2012 Sounds like a project. Worth a shot, eh? Quote Share this post Link to post Share on other sites
