NKG
Any hope of reviving tutankham cart :(
Hi Guys,
Sad day my old tutankham cart that i have had since 86 has given up the ghost :( is there any chance of reviving it? the label is long since gone and have opened up the case and have two chips tms4732-45nl & tms4764-45nl.
I have all the tools needed from back when i collected arcade goodness.
Any help would be very much appreciated :)
What is "given up the ghost"? Black screen, some visuals but garbled, no sound?
I bought a copy recently from ebay that was garbled graphics no matter what I tried. Eraser on the contacts followed by alcohol is the normal fix, but it did no good on this one. I sent it back and the seller said they could not get it working either.
If your other games work fine on that console and you've tried all the cleaning tricks, then it is most likely dead. When you had the cartridge case apart, was there a capacitor or two on the game PCB? It is possible that on board components can go bad, but most often with a black screen it is the PROM chip.
Probably a bad solder joint/cold solder joint on one or more of the PROM pins that connect to the cartridge PCB. As ColecoDan stated, these problems can be fixed by someone with the proper tools and abilities if you are not able to handle the job of desoldering the PROMs from the PCB, cleaning the PCB and PROM pins properly and resoldering the PROMs back onto the PCB. Unfortunately there are no guarantees that this will indeed fix the problems as maybe there is another issue like PCB traces or edge connector contacts, but it's a start. If all else fails, a loose Tutankham cartridge is pretty easily had via numerous sources such as eBay or even Mumbai's CV cart sale thread in the MarketPlace Forum... just do a search for Mumbai.
Never mind, I found the sales thread and Mumbai does indeed have it for $9.00, but you will have to PM him to see if he will ship overseas. Follow this link:
http://www.atariage.com/forums/topic/168225-fs-colecovision-cartridges/page__hl__%20mumbai
You may also want to look into the AtariMax Ultimate SD Cart at www.atarimax.com. With this Multi-Cart, you can copy all the rom images that are easily found on the Web to the SD Card and play them thru this cartridge. It costs about $130, but you also get two free "newer" homebrew games that make the cost well worth it!
well.. i did the cleaning with alcohol on two carts.. Pitfall and something else.. no black detected.. couldn't get them working at all.... i gave them a shot of De-oxit.. BOOM back to life...
I don't know whats in that stuff.. but...............
Just sayin'..
Just wrote a big reply and then laptop crashed :(
This morning i cleaned, de-soldered/re-solder, changed cap, re-cleaned cart slot but still no joy :(
I checked mumbai but loose tut cart is gone :( sd looks a nice piece of kit maybe santa will bring me one for christmas ;)
Understand that all is lost with this cart now but is there anyway of using a donor cart and still use the case? i know it sounds made but my dad worked hard to get me and my brother these games and would like to keep a small part of it at least :)
Also is there any new cart slots edge connectors available anywhere? looked about but could only sega and nintendo ones.
Thanks for your input guys :)
