Sign in to follow this
yllawwally
Can't compile sample game
I just installed visual batari basic. I load up the zombie sample. I cannot get the sample game to work. What did I setup incorrectly. When I compile I get the following
Compile started at 10/3/2012 10:52:38 AM
Compiling C:\ATARI\bB\PROJECTS\Zombie_Chase\DEFAULT.BAS
bytes of ROM space left
91 bytes of ROM space left
--- Unresolved Symbol List
pfcenter 0000 ???? (R )
mul8 0000 ???? (R )
kernelmacrodef 0000 ???? (R )
pfhalfwidth 0000 ???? (R )
Fatal assembly error: Source is not resolvable.
Errors were encountered during assembly.
2600 Basic compilation completed.
Compilation completed at 10/3/2012 10:52:39 AM
view output file:///C:/ATARI/bB/PROJECTS/Zombie_Chase/bin
Post compilation files deleted
Sometimes if one label wasn't found you end up getting a bunch of unresolved symbols instead of just the one. In this case I'm guessing that "mul8" is the culprit, because it's a routine found in the "div_mul.asm" include file, which is *not* included unless you tell bB to include it. Try adding the following line at the beginning of the program and compiling again:
  include div_mul.asm
Thanks that fixed it. It had an include fixed math statement, but not div_mul. I just assumed the sample would be correct, and I has messed something up in the installation.
It worked when it was first written, but later there was a bug introduced into bB in which multiplication or division by certain powers-of-two don't use bit shifting like they should, but instead use these general functions.
