ApolloBoy
Question about the 5V RAM conversion
I'm thinking of doing the 5V RAM conversion to my CV before too long and I've got a couple of questions regarding it. First off, will this completely eliminate the -5V and 12V rails, and second, will getting rid of those power rails have any kind of adverse effects on expansions or AV mods?
The SGM should work fine with just 5V. Not sure about the EM#1, need to check.
I've got a Heavy Sixer and 7800 so I'm not worried about losing the Expansion Module 1. I was mainly curious about the SGM, good to hear about that. But now my main concern is whether or not Ben Heck's AV mod will still work.
One other question, will having only the +5V rail have any effect on the controllers? What I'd really like to do is replace the original power jack with a barrel jack along with a 5V regulator board so that I can use a standardized power supply with the CV.
Hi there,
Although replacing the RAM with straight +5V chips eliminates the need for +12V/-5V from the logic board, the AV circuits need +12V (both stock and A/V mod, assuming that the A/V mod resembles Solarfox's LM318 mod). I learned this the hard way today, after having thoroughly examined the reverse-engineered schematics but not re-examining my A/V mod.
The right thing to do, I think, is to wire it for a stock +12V wallwart and feed +5V in via a simple 7805-based regulator circuit. I'm going to do this over the Christmas break; will post the results here.
Hi there,
yes, this method makes the most sense.
Update: I put together a simple 5V regulator circuit using a 7805S (good for one amp, TO-220) and a couple of filter caps.
It worked; however, the generated heat caused the circuit to thermal shutdown within a couple of minutes. A decent heat sink would probably fix that; I'll get one the next time I'm in Akihabara. It would probably be better to use a TO-3 can rather than TO-220, but I haven't had much luck finding those lately.
It would be nice if the LM318 composite modification could run off just +5V ...
I ended up wiring a cheap DC-DC converter (Cosel MGFW152405) into the unit. Seems to work okay; the converter runs quite cool. I am now wondering if I can remove the RF daughterboard to reduce the noise in the unit... has anyone tried this?
