HatefulGravey
Having a problem with VbB
I was having an issue opening files with my install of VbB. It was making looking at code samples and such hard so I uninstalled everything and thought a re-install might help. I can't get the damned program running right again. In the time I was looking for a fix to this problem I found a fix to the original problem, now I can't get back to there.
The problem is I'm getting all black when I try to create a play field or sprite. I can't get past that to know if there are more problems. I'm using Windows 7 64bit, and I know I had some issue when I first installed all this. I also remember a helpful how to on getting everything running right on this OS but I can't find it again. Any help would be awesome, I'm looking forward to learning more.
Thanks, looking better for now. If I have more questions I'll just post them here. I'm back to where I started, so if I can open sample files now things can move forward.
