flashjazzcat #126 Posted February 25, 2015 (edited) Are the yellow, white and green wires going to pins on Freddie? It's hard to tell since the photo is so small. I'm surprised to see the oscillator still at the bottom corner of the motherboard, too, since VBXE should now supply the clock. Can you post a larger photo? EDIT: Also note that on most white VBXE boards, the master clock crystals are in the wrong place: i.e. PAL is on the NTSC jumper position and vice-versa. Edited February 25, 2015 by flashjazzcat Quote Share this post Link to post Share on other sites
TheNameOfTheGame #127 Posted February 25, 2015 Are the yellow, white and green wires going to pins on Freddie? It's hard to tell since the photo is so small. I'm surprised to see the oscillator still at the bottom corner of the motherboard, too, since VBXE should now supply the clock. Can you post a larger photo? EDIT: Also note that on most white VBXE boards, the master clock crystals are in the wrong place: i.e. PAL is on the NTSC jumper position and vice-versa. I reversed the NTSC/PAL clock jumper and I get a picture now with J6 hooked up, but it is jumpy and garbled. Maybe I need to take the crystal off the motherboard then. Quote Share this post Link to post Share on other sites
TheNameOfTheGame #128 Posted February 25, 2015 Took off the crystal from the mainboard and now I get output from the standard monitor port with the VBXE powered and connected. This was in conjunction with swapping the NTSC/PAL jumper to PAL. Now I'm going to hook up the RGB output to the SC1224. Quote Share this post Link to post Share on other sites
flashjazzcat #129 Posted February 25, 2015 Great! Quote Share this post Link to post Share on other sites
TheNameOfTheGame #130 Posted February 26, 2015 Hacked together a quick and dirty DIN13 connection for the SC1224. Took sync from pin15 of the 4050 and tied it to HSYNC and VSYNC in the DIN13. Connected RGB and GND from the vbxe header and viola! Crystal clear picture on the SC1224. I'm going to put a proper flush mount DIN13 in place of the old monitor jack as some others have done before I close it up and call this project done! Quote Share this post Link to post Share on other sites
Shawn Jefferson #131 Posted February 26, 2015 Nice, looks like you got the "Ulrimare serue" working fine! 6 Quote Share this post Link to post Share on other sites
