Sign in to follow this
carmel_andrews
How to use an int. amiga floppy drive in an STFM/E
All you do is reverse the data cable at the drive end and plug it into the miggy int. drive (obviously you have to take the drive out of the amiga and stick it into the ST (pref FM's or E's) don't ask me about F's or mega's....never used them
Slight problem is though, you will have to cut a bigger hole at the disk drive part of the ST case so that the amiga disk eject button can come fully out, or just leave the case off, like i did
I know this works, did it myself when i had an STe (didn't get around to trying it with the FM as i gave that away (to someone in ashford, kent)
I only did this since the drive that was previously in the STe had issues with formatting some disks i had, so i tried the amiga int. floppy drive instead and it formatted the disks no problem
