SoLo2 #1 Posted December 4, 2012 Hello! Here is version 20121204 of BITS 1600 PIXeL PaINT. This is a little pixel painting program for ATARI XL. Download: http://thebitsclub.tripod.com/util/BITS1600-XL-20121204.ZIP Goodbye, BITS Quote Share this post Link to post Share on other sites
+CharlieChaplin #2 Posted December 4, 2012 Hmm, I find it rather strange that most of your programs end with Error 136 (program too short) and thus are not executable on the Atari. The same is true for the newest version of Pixel Paint - Error 136 while loading. Therefore I did a file-trace (to find out start and end adress of the program) and since it did not overwrite DUP.SYS I re-saved it using the binary save option under DOS. Attached you will find the new version without Error 136 (luckily the RUN adress was the same as the start adress, otherwise the program would not have worked, since the version posted above did not have a RUN adress)... Besides, executable or ML programs for the A8 do not use the extender *.PRG (common for Atari ST and other computers), one should use *.XEX or *.COM instead... -Andreas Koch. BITS_pixel_paint.zip Quote Share this post Link to post Share on other sites
