+slx Posted December 18, 2012 Share Posted December 18, 2012 I have bought an Indus GT on EBay and think about saving on shipping by leaving the power supply in the US as I can't use it in Europe anyway. Any ideas if the Indus will run on a stabilized 12V supply with 2 amps or is it necessary to absolutely keep the specified 11.5 V? (I don't expect 230V AC to 11.5VDC power supplies to be available anywhere. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted December 18, 2012 Share Posted December 18, 2012 I can't swear on it but I think mine runs fine on a 9v 5200 power supply. Its in the box with it stored away but I can check later tonight. Sent from my Windows Phone 8X by HTC using Board Express Quote Link to comment Share on other sites More sharing options...
trub Posted December 18, 2012 Share Posted December 18, 2012 12V DC is ok (at least it works for me . In fact Indus schematics also assumes 12V. Quote Link to comment Share on other sites More sharing options...
+slx Posted December 18, 2012 Author Share Posted December 18, 2012 Thanks a lot for your help! Any idea how heavy the original power supply actually is? Quote Link to comment Share on other sites More sharing options...
suspicious_milk Posted December 18, 2012 Share Posted December 18, 2012 (edited) Mine feels right about the same weight as my 65xe ps; probably a smidgen heavier (sorry, no scales). Anecdotally, I've heard people using 5200 ps all the time for the GT (though I never have). According to 8-Bit FAQ : "Indus GT 11.5 V DC 1.95 A (22.4 VA) Max:33W DataByte#DV-9319A Center positive This is identical to the Atari power supply for earlier 2-port 5200s: Atari#CO18187(unit, early version)/CA019141(box) What happens if power supplies for the Atari 1050 and Indus GT are mixed? Paul Alhart writes (20 Jan 2004): "The Indus requires DC, the 1050 uses AC. Plug an Indus supply into a 1050 and it will usually blow the rectifier diodes in the 1050. Plug an Atari supply into an Indus and it will blow the fuse in the supply. It can damage the mother board as well." " Edited December 18, 2012 by suspicious_milk 1 Quote Link to comment Share on other sites More sharing options...
+wood_jl Posted December 19, 2012 Share Posted December 19, 2012 Thanks a lot for your help! Any idea how heavy the original power supply actually is? (click pics to enlarge) Here's my 110V Indus GT power supply: Here's the weight in Yankee: Here's metric weight: Quote Link to comment Share on other sites More sharing options...
nethermind Posted July 3, 2018 Share Posted July 3, 2018 (edited) I found a couple of Peavey Power Supplies on eBay. This is exactly what was printed on the bottom: PEAVEY POWER SUPPLY FOR USE WITH AUDIO EQUIPMENT REPLACE WITH PART NO. 70900601 MODEL NO. DV-9319A INPUT: 120VAC 60Hz 33W OUTPUT: 11.5VDC 1.95A CAUTION: INDOOR USE ONLY UL LISTED 883K E59477 (POSITIVE CENTER POLE [CPC-2]) SA LR99152 MADE IN CHINA I paid $20 for one and $26 for the other. Edited July 3, 2018 by nethermind 1 Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted July 3, 2018 Share Posted July 3, 2018 another thumbs up for 12v from me no issues to report Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted July 3, 2018 Share Posted July 3, 2018 My Indus works fine on a 12V DC supply. Quote Link to comment Share on other sites More sharing options...
+slx Posted May 7, 2019 Author Share Posted May 7, 2019 I got a couple European 12V DC 2-amp PSUs but the plugs dont fit. Does anyone happen to know the correct dimensions for the barrel plug? The receptacle is too far recessed to allow measuring with calipers. Does Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted May 7, 2019 Share Posted May 7, 2019 I believe it's the same 5.5mm outside x 2.5mm inside barrell connector like the 1050 plug, on account of problems encountered with people mistakenly mixing up the AC/DC power supplies... 1 Quote Link to comment Share on other sites More sharing options...
+slx Posted May 10, 2019 Author Share Posted May 10, 2019 I believe it's the same 5.5mm outside x 2.5mm inside barrell connector like the 1050 plug, on account of problems encountered with people mistakenly mixing up the AC/DC power supplies... I got some 2.5x5.5 connectors and they feel quite "loose". I will solder one on and try it out. Quote Link to comment Share on other sites More sharing options...
Jacques Posted November 21, 2021 Share Posted November 21, 2021 On 5/10/2019 at 1:27 PM, slx said: I got some 2.5x5.5 connectors and they feel quite "loose". I will solder one on and try it out. Is it maybe 2.1x5.5, then? Indus GT is in shipping from US so I need to buy European power supply (don't want voltage transformer). Quote Link to comment Share on other sites More sharing options...
Mathy Posted November 21, 2021 Share Posted November 21, 2021 Hello guys The Indus GT was sold in Eastern Europe under different names. Maybe licensed. Either as Toms 710/720 or California Access IIRC. I would suspect that they didn't change the drive internally, but I might be wrong. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
dely Posted November 21, 2021 Share Posted November 21, 2021 Indus GT was sold in Poland as LDW Super 2000 and later as CA2001 with different power supplies (2 voltages) and different back plate. http://atariki.krap.pl/index.php/LDW_Super_2000 http://atariki.krap.pl/index.php/CA-2001 1 Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted November 21, 2021 Share Posted November 21, 2021 The closest looking Indus GT clone is the LDW Super 2000 but it uses a roctec mechanism instead of tandon. The LDW power supply is AC with a rectifier circuit inside the drive whereas the Indus is DC input with standard 78xx regulators inside the drive. Its possible the California Access CA2000 drive is more closely cloned than the LDW but ive never seen one in the flesh. However it's case colour was modded to suit the XE range and they omitted the tinted flip-front. Quote Link to comment Share on other sites More sharing options...
Jacques Posted November 22, 2021 Share Posted November 22, 2021 (edited) Indeed, Indus' power supply is different than the one of CA/LDW, therefore my question for plug dimensions at drive's end no to have it "loose", what @slx mentioned. Edited November 22, 2021 by Jacques Quote Link to comment Share on other sites More sharing options...
+slx Posted November 22, 2021 Author Share Posted November 22, 2021 14 hours ago, Jacques said: Indeed, Indus' power supply is different than the one of CA/LDW, therefore my question for plug dimensions at drive's end no to have it "loose", what @slx mentioned. Sorry, I never soldered that connector on, but as for European PSUs, a lot of external hard drives, 3.5" hard drive enclosures and small NAS have 12V/2A DC power supplies that should work with the Indus voltage/amp-wise. WD drives usually have a barrel connector which might fit (although I have not checked the polarity). 1 Quote Link to comment Share on other sites More sharing options...
Jacques Posted November 23, 2021 Share Posted November 23, 2021 Thanks @slx I already ordered 12V DC/3A 3rd party power supply that should be OK. As for how the plug fits - I'll report. Still I'm waiting for Indus itself... ? Quote Link to comment Share on other sites More sharing options...
Jacques Posted November 30, 2021 Share Posted November 30, 2021 And here it is ? European power supply from Sagemcom is working just fine (the plug indeed feels a bit loose, though): 1 Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted November 30, 2021 Share Posted November 30, 2021 sweet - you have the case is the drive itself in good condition? tf_hh used to make a ramcharger, he may still do so if you need one? 1 Quote Link to comment Share on other sites More sharing options...
Jacques Posted November 30, 2021 Share Posted November 30, 2021 (edited) Hi @xrbrevin thank you. Yes, it's in decent (could risk word 'excellent') visual condition, I only had opportunity to power it on standalone and so far, so good. I have spare drive belt ready in case it needs replacement, though. Didn't have time to take more pictures (especially drive itself ), sorry for that. I'm really eager to test SDX with SuperSyncromesh using INDUSGT.SYS driver ? And yes, I've e-mailed @tf_hh regarding SRAM-charger already, patiently waiting for reply ? Edited November 30, 2021 by Jacques Quote Link to comment Share on other sites More sharing options...
