Lincoln Posted December 20, 2012 Share Posted December 20, 2012 (edited) So I have a couple 4-switch units that were purchased long ago as nonworking. I guess today I decided I would like them to work. I don't know how to make that happen though, so I am looking for some help. What I have: good power cord, good video connection, good tv, good game cart. I have a working 2600 to verify all these things. What's not working: vader 2600, rev 16 board. symptoms powers on, displays garbage on channel 3. no switches seem to produce any effect- even the ch. 2-3 switch doesn't do anything, it's always channel 3. I have opened it up and removed the shielding. everything looks fine visually. I have looked at the field repair guide. It's a bit over my head. Is there another guide to help diagnose and fix my issue? the 2nd unit is a wood grain 4-switch (forgot to check rev #) that powers up and shows a black screen. the sliding part of the reset switch is missing if that makes a difference. as I'm writing this it occurs to me that cracked soldering on the cart connector might cause this- is that accurate? I can reflow the solder on all those points if that is a reasonable action. I have a simple multimeter for checking voltages and can solder/desolder things. Edited December 20, 2012 by Lincoln Quote Link to comment Share on other sites More sharing options...
TVisitor Posted December 21, 2012 Share Posted December 21, 2012 Hi Lincoln, I'm sorry I'm bypassing your question a bit, but you mentioned the "field repair guide" - can you post the link to that? Thank you. Quote Link to comment Share on other sites More sharing options...
TVisitor Posted December 21, 2012 Share Posted December 21, 2012 Found, it nevermind :-) Quote Link to comment Share on other sites More sharing options...
