+JAC! #1 Posted January 1, 2013 Hi, Are there standard ways of loading and starting (normal INIADR/RUNADR handling) an executable file under MyDos & SpartaDOS? Something like specific XIO commands or well defined vectors? Peter/JAC! Quote Share this post Link to post Share on other sites
+Roydea6 #2 Posted January 1, 2013 XIO 40,#3,4,0,"D:FILENAME.COM" Quote Share this post Link to post Share on other sites
+JAC! #3 Posted January 2, 2013 Great. With this info I foud here: http://www.mathyvannisselroy.nl/bflist.htm MyDos: - XIO 40 is much slower then XIO 39. It's basically the same command. XIO 40 was added by Bob Puff for compatibility reasons (SpartaDOS uses XIO 40). But XIO 39 is about 3 times faster then XIO 40. So should I rather use 39 under MyDOS or is this fixed in 4.5xx ? Quote Share this post Link to post Share on other sites
Heaven/TQA #4 Posted January 2, 2013 the good thing in Atari OS... expandable Quote Share this post Link to post Share on other sites
xxl #5 Posted January 2, 2013 and switch off able Quote Share this post Link to post Share on other sites
1050 #6 Posted January 4, 2013 Great. With this info I foud here: http://www.mathyvann...y.nl/bflist.htm MyDos: - XIO 40 is much slower then XIO 39. It's basically the same command. XIO 40 was added by Bob Puff for compatibility reasons (SpartaDOS uses XIO 40). But XIO 39 is about 3 times faster then XIO 40. So should I rather use 39 under MyDOS or is this fixed in 4.5xx ? That's not quite accurate to begin with. In the first place if you actually see this behavior then you are dealing with a pre 4.50 MyDOS of which 4.51 qualifies as it has this broken XIO 40 mode in particular. Puff then came along, fixed it and made 39 exactly the same as 40 in order to be compatable with Sparta and released it as 4.50. Everything after that is fixed for the broken XIO 40 mode. Blame Marslett for discontinuity in version numbers along with the broken XIO 40 mode. 4.51 predates 4.50. Puff came on board for 4.50 and fixed a LOT of these kinds of bugs. What you should have been looking at while at that site was the 4.50 tech.doc from which I quote: To load a program into memory, the address of the file name string is stored into the buffer address, and a value of 4, 5, 6 or 7 is stored into the AUX1 field. If AUX1 is 4, both the initialization routines and the run address are executed after closing the IOCB, but before returning to the calling program. If AUX1 is 5, the initialization routines are disabled, but the program will be run. If AUX1 is 6, the initialization routines will be run, but the program execute address will be loaded and ignored. If AUX1 is 7, the text of the program will be loaded into memory, but no other activity will be performed. CIO function code 40 performs the exact same function as this (39). Autorun.sys files are loaded with only the init vector active so whatever file you had in mind to autorun may need it's vectors played with. Sparta as far as I know has nothing like this at all. It will ignore any and all run or init vectors and just run the file from it's first byte location after loading it into memory. Quote Share this post Link to post Share on other sites
+JAC! #7 Posted January 4, 2013 (edited) Thanks a lot, but that would mean neiter variant of the command on neiter DOS is compatible with DOS 2.5? BLOCK,INI1,BLOCK,INI2,BLOCK,RUN would be INI2,RUN under MyDos according to the text (IOCB can only be closed after reading the whole file). And Spartados does not support INI/RUN? ... Walter/Draco...? Edited January 4, 2013 by JAC! Quote Share this post Link to post Share on other sites
drac030 #8 Posted January 4, 2013 Sparta as far as I know has nothing like this at all. It will ignore any and all run or init vectors and just run the file from it's first byte location after loading it into memory. Complete nonsense. XIO 40 in SpartaDOS does normal binary load which means that init and run vectors are used as usual. The only difference is that when a binary file DOES NOT contain a run vector, it will be executed from the beginning. Quote Share this post Link to post Share on other sites
+JAC! #9 Posted January 4, 2013 (edited) Thanks drac030 and 1050, that's what I expected. And I also verfied the the ICOB is still open during INADR calls and only closed for RUNADR in MyDOS when using AUX1=4. I guess the writing in the document was just a bit imprecise. So everything works fine here now with XIO 40. Edited January 4, 2013 by JAC! Quote Share this post Link to post Share on other sites
+MrFish #10 Posted January 5, 2013 Here's a chart that has XIO commands for a bunch of DOS's: XIO Command Codes for DOS.doc 3 Quote Share this post Link to post Share on other sites
jacobus #11 Posted December 31, 2018 Is there a way of launching a disk based .EXE after wiping DOS from memory? I've tried reading the file into memory with the intention of calling its start location, but the load process overwrites the code that I am using to read it in. Quote Share this post Link to post Share on other sites
+JAC! #12 Posted December 31, 2018 I've tried reading the file into memory with the intention of calling its start location, but the load process overwrites the code that I am using to read it in. It that an arbitrary XEX or your own code? If it is your own, the best is to combine everything into one XEX. In any case, you have to plan your memory layout accordingly. And if you wipe DOS, how do you load the file? Quote Share this post Link to post Share on other sites
xxl #13 Posted December 31, 2018 And if you wipe DOS, how do you load the file? jsr xBIOS_LOAD_BINARY_FILE https://media.giphy.com/media/lp9V36IrHd1FC/giphy.gif Quote Share this post Link to post Share on other sites
_The Doctor__ #14 Posted December 31, 2018 (edited) hey that gif is an mp4.. wtf is giphy doing? I think Arnold needs to have a talk with them! Nice none the less one more day till the start of looking back into projects... Edited December 31, 2018 by _The Doctor__ Quote Share this post Link to post Share on other sites
jacobus #15 Posted December 31, 2018 It that an arbitrary XEX or your own code? If it is your own, the best is to combine everything into one XEX. In any case, you have to plan your memory layout accordingly. And if you wipe DOS, how do you load the file? It's actually a Rastaconverter image. The idea is to display the image (by running the executable) after the player has successfully completed the game. I would need to initiate a process that is completely separate from my code. Quote Share this post Link to post Share on other sites
jacobus #16 Posted December 31, 2018 jsr xBIOS_LOAD_BINARY_FILE https://media.giphy.com/media/lp9V36IrHd1FC/giphy.gif I like the sound of this - can you please provide a bit more detail? (my skill level floats somewhere above basic but below assembler) Quote Share this post Link to post Share on other sites
Rybags #17 Posted January 1, 2019 Your best bet for a RC image might be to use compression. The code section tends to have lots of NOPs and repeated sequences to you might crunch down to about half the size or less. Quote Share this post Link to post Share on other sites
xxl #18 Posted January 2, 2019 I like the sound of this - can you please provide a bit more detail? (my skill level floats somewhere above basic but below assembler) I prepared a quick example of how you can use the xBOOT functions to load and decompress on the fly a packed binary file (rastaconverter/ packed LZ4). exactly the same (and even faster) can be done with xBIOS. the problem is that you wanted for Sparta DOS and xBIOS does not support the SparaDOS filesystem. only AtariDOS / MyDOS / SuperDOS / BiboDOS etc. test-normal.atr test-lz4.atr 3 Quote Share this post Link to post Share on other sites
jacobus #19 Posted January 14, 2019 I prepared a quick example of how you can use the xBOOT functions to load and decompress on the fly a packed binary file (rastaconverter/ packed LZ4). exactly the same (and even faster) can be done with xBIOS. the problem is that you wanted for Sparta DOS and xBIOS does not support the SparaDOS filesystem. only AtariDOS / MyDOS / SuperDOS / BiboDOS etc. Thank you for the examples! Unfortunately xBIOS would consume too much memory. I am trying to load and run an external executable file from within my program. As that I have already wiped out DOS, using a standard call is not an option. Is there a (relatively) simple way to run an executable from disk by either by filename or disk sector? I think I'd basically need to duplicate the functionality of the Binary Load function in the standard DUP.SYS Quote Share this post Link to post Share on other sites
+JAC! #20 Posted January 14, 2019 Thank you for the examples! Unfortunately xBIOS would consume too There will hardly be anything smaller. Maybe you can share more about the context and we find a way to not kill DOS at all. Using direct sector accesy is not a good idea for new stuff. It breaks on many modern devices. 1 Quote Share this post Link to post Share on other sites
xxl #21 Posted January 14, 2019 DOS by Fox is shorter. it takes the same as xBOOT (384 bytes) its advantage is that it uses CIO but it does not decompress on the fly. And of course, it only works on Atari DOS and not on SpartaDOS Quote Share this post Link to post Share on other sites
Xuel #22 Posted January 15, 2019 Thank you for the examples! Unfortunately xBIOS would consume too much memory. I am trying to load and run an external executable file from within my program. As that I have already wiped out DOS, using a standard call is not an option. Is there a (relatively) simple way to run an executable from disk by either by filename or disk sector? I think I'd basically need to duplicate the functionality of the Binary Load function in the standard DUP.SYS If you are using an single or enhanced-density disk and if you can *raw* write your executable to consecutive sectors, 128 bytes per sector, then you could adapt my boot loader: http://atariage.com/forums/topic/241044-writing-asm-programs-that-boot-from-disk/?p=3288846 You could probably get it to under 128 bytes of code. But note that raw writing the executable means there will be no chaining info in those sectors. This means DOS will not be able to read the file. Ideally you should mark those sectors as used in the VTOC so that DOS doesn't try to use them. 1 Quote Share this post Link to post Share on other sites
jacobus #23 Posted January 15, 2019 xxl, on 14 Jan 2019 - 11:21 AM, said:DOS by Fox is shorter. it takes the same as xBOOT (384 bytes) its advantage is that it uses CIO but it does not decompress on the fly. And of course, it only works on Atari DOS and not on SpartaDOS xBoot is 384 bytes? That works - I thought it was around 6K. Question #2 - is it possible to load the xBIOS file into memory, execute it and then have access to the functions like "xBIOS_LOAD_BINARY_FILE" or do I need to boot from it? Quote Share this post Link to post Share on other sites
xxl #24 Posted January 15, 2019 xBoot is 384 bytes? That works - I thought it was around 6K. Question #2 - is it possible to load the xBIOS file into memory, execute it and then have access to the functions like "xBIOS_LOAD_BINARY_FILE" or do I need to boot from it? xBoot - 384 bytes (at start, reusing it 256 maybe) xBios - 1024 bytes (1K) 2. you can boot DOS, load xB from DOS - xB loads xautorun file (your program) -- xB supports many varieties of DOS filesystem, you need to run xB to configure&relocate itself according to the preferences of the coder. 1 Quote Share this post Link to post Share on other sites
baktra #25 Posted January 17, 2019 This might help you, when you decide to use your own implementation. If you remove cassette-specific stuff (motor control fiddling) and the initialization code (after the STARTUP label), you have your own binary load routine (using CIO device). This loads Atari DOS 2 binary load files. I am sure more experienced coders would be able to shorten the routine. ;=============================================================================== ;TURGEN SYSTEM - STDBLOAD 2a ;Binary loader for standard (FSK) tape records ;The author has placed this work in the Public Domain, thereby relinquishing all ;copyrights. Everyone is free to use, modify, republish, sell or give away this ;work without prior consent from anybody. ;This loader uses the "trailing EOF record trick" - Last 128 bytes of the ;loader are in the EOF block. These 128 bytes are moved from the cassette ;buffer to the intended memory location. The trick allows this loader to be ;only 4 records long ;The loader is ROM OS agnostic ;Using the LDRTYPE symbol, this loader can be assembled ;to either boot (LDRTYPE=0) or binary (LDRTYPE=1) file. ;=============================================================================== .INCLUDE "equates.asm" .IF LDRTYPE=0 LDR_START=[2048-24] .ELSE LDR_START=2048 .ENDIF CIO1_OP =$0342+16 CIO1_STAT =$0343+16 CIO1_BUFLO=$0344+16 CIO1_BUFHI=$0345+16 CIO1_LENLO=$0348+16 CIO1_LENHI=$0349+16 CIO1_AUX1 =$034A+16 CIO1_AUX2 =$034B+16 CIO0_OP =$0342 CIO0_STAT =$0343 CIO0_BUFLO=$0344 CIO0_BUFHI=$0345 CIO0_LENLO=$0348 CIO0_LENHI=$0349 CIO0_AUX1 =$034A CIO0_AUX2 =$034B *=[LDR_START] ;------------------------------------------------------------------------------- ; Boot header ;------------------------------------------------------------------------------- .IF LDRTYPE=0 BOOTHEAD .BYTE 0 .BYTE 3 .WORD [LDR_START] .WORD FAKEINIT lda #60 ;Motor off sta PACTL ldx #255 ;Clear pushdown store txs ;------------------------------------------------------------------------------- ; Move last portion of the loader code from cassette buffer ;------------------------------------------------------------------------------- RELO_P2 ldx #128 ;Move 128 bytes of the EOF block RELO_P2_L lda [1024-1],X ;from cassette buffer sta [LDR_START+384-1],X ;to the intended place dex bne RELO_P2_L .ENDIF ;------------------------------------------------------------------------------- ; Loader mainline code ;------------------------------------------------------------------------------- BL000 jsr STARTUP ;Display program name BLTOP lda #1 ;Rest flags (first segment + no binary header) sta BLF_FIRST sta BLF_NOBIN jsr FCLOSE jsr FOPEN ;Call subroutine that opens C: file lda CIO1_STAT ;Check for error bpl GETSEG ;No error, continue jsr ERRHNDL ;If error occured, go to handle it jmp BLTOP ;Then start again ;------------------------------------------------------------------------------- ; Read a segment ;------------------------------------------------------------------------------- GETSEG lda #<FAKEINIT ;Set fake INIT vector to RTS sta 738 lda #>FAKEINIT sta 739 ;------------------------------------------------------------------------------- ; Get segment header ;------------------------------------------------------------------------------- GS_STRTA lda #<BLSEGHEAD ;Read first two bytes of segment header sta CIO1_BUFLO lda #>BLSEGHEAD sta CIO1_BUFHI lda #2 sta CIO1_LENLO lda #0 sta CIO1_LENHI jsr GETBLK lda #255 ;Check for 255 255 cmp BLSEGHEAD bne GS_ENDA cmp BLSEGHEAD+1 bne GS_ENDA ;If 255 255 not found, continue lda #0 sta BLF_NOBIN jmp GS_STRTA ;And then start over GS_ENDA lda #<[BLSEGHEAD+2] ;Get rest of the segment header sta CIO1_BUFLO lda #>[BLSEGHEAD+2] sta CIO1_BUFHI lda #2 sta CIO1_LENLO lda #0 sta CIO1_LENHI jsr GETBLK ;------------------------------------------------------------------------------- ; Processing specific for the first segment ; 255 255 header check ; RUNAD is set to point to the first segment ;------------------------------------------------------------------------------- lda BLF_NOBIN ;Check if 255 255 header was found beq GS_FSRUN ;It was, we can continue jmp ERRNOBIN ;If not, we signalize an error and continue GS_FSRUN lda BLF_FIRST ;Is this the first segment beq GS_CALCLN ;No, just continue lda #0 ;Reset first segment indication sta BLF_FIRST ;RUNAD points to this segment lda BLSEGHEAD sta 736 lda BLSEGHEAD+1 sta 737 ;------------------------------------------------------------------------------- ; Calculate length of the segment ;------------------------------------------------------------------------------- GS_CALCLN sec ;Subtract start address from end address lda BLSEGHEAD+2 sbc BLSEGHEAD+0 sta CIO1_LENLO bcs GS_LENHI dec BLSEGHEAD+3 GS_LENHI sec lda BLSEGHEAD+3 sbc BLSEGHEAD+1 sta CIO1_LENHI clc ;Increase the difference by 1 to get length lda CIO1_LENLO adc #1 sta CIO1_LENLO bcc GS_GETD inc CIO1_LENHI ;------------------------------------------------------------------------------- ;Read segment data ;------------------------------------------------------------------------------- GS_GETD lda BLSEGHEAD sta CIO1_BUFLO lda BLSEGHEAD+1 sta CIO1_BUFHI jsr GETBLK ;------------------------------------------------------------------------------- ; INIT segment handling ;------------------------------------------------------------------------------- lda 738 ;Check if there was real INIT segment cmp #<FAKEINIT bne REALINI lda 739 cmp #>FAKEINIT beq POSTINI REALINI lda #60 ;Switch off the motor sta PACTL jsr DOINIT ;Execute INIT segment code lda #52 ;Switch on the motor sta PACTL POSTINI jmp GETSEG ;Get another segment ;=============================================================================== ;Subroutine that gets a blocks using CIO. Buffer address and length of ;the block must be set by the caller. ;=============================================================================== GETBLK ldx #16 ;Channel 1 lda #7 ;Requesting CIO READ operation sta CIO1_OP jsr CIOV ;Call CIO lda CIO1_STAT ;Check for error bmi GBERR ;Error occured - handle it rts GBERR cmp #136 ;Is this EOF ? bne GBERR_S ;No - handle error ldx #255 ;Yes, this is EOF txs ;Clear stack jsr FCLOSE ;Close file jmp (736) ;Run the program GBERR_S jmp ERRHNDL ;=============================================================================== ;Emulation of JSR(738) ;=============================================================================== DOINIT jmp (738) FAKEINIT rts ;=============================================================================== ;Main data area ;=============================================================================== BLSEGHEAD .BYTE 0,0,0,0 ;Segment header and position pointer BLF_FIRST .BYTE 0 ;First segment to be loaded BLF_NOBIN .BYTE 0 ;No binary file header found yet CDEV .BYTE "C:",155 ;File name ;=============================================================================== ;Subroutine that closes file ;=============================================================================== FCLOSE ldx #16 lda #12 ;Requesting CIO CLOSE operation with code 12 sta CIO1_OP jsr CIOV ;Call CIO rts ;=============================================================================== ;Subroutine that opens file ;=============================================================================== FOPEN ldx #16 ;IOCB 1 lda #3 ;Requesting CIO OPEN operation with code 3 sta CIO1_OP lda #4 ;Auxiliary value 4 - open for reading sta CIO1_AUX1 lda #12 ;And also simulate key press sta CH lda #128 ;Auxiliary value 128 - short IRGs sta CIO1_AUX2 lda #<CDEV ;Buffer- DEVICE:FILENAME ("C:") sta CIO1_BUFLO lda #>CDEV sta CIO1_BUFHI jsr CIOV ;Call CIO rts ;=============================================================================== ;Error handling ;=============================================================================== ERRHNDL lda #$24 ;I/O error - red background jsr ERRSIG jmp COLDSV ;Cold start ERRNOBIN lda #$0E ;Not a binary file - white background jsr ERRSIG jmp WARMSV ;Warm start ;=============================================================================== ; Auxiliary routines for error handling ;=============================================================================== ERRSIG sta COLOR4 ;Signalize error by changing background sta COLOR2 sta COLBK sta COLPF2 lda #60 ;Switch off the motor sta PACTL jsr WFORKEY rts WFORKEY lda #255 ;Wait for any key sta 764 WFORKEYL lda 764 cmp #255 beq WFORKEYL rts ;=============================================================================== ; Loader startup ;=============================================================================== STARTUP lda #0 ;Reset cold start flag sta 580 lda #1 ;Indicate disk boot succeeded sta 9 jsr DINI lda #<DINI sta DOSINI lda #>DINI sta DOSINI+1 lda #148 ;Set background sta COLOR2 lda #3 ;Noisy or silent I/O sta SOUNDR ldx #0 ;Channel 0 lda #9 ;Requesting PRINT sta CIO0_OP lda #<PROGTITLE sta CIO0_BUFLO lda #>PROGTITLE sta CIO0_BUFHI lda #<[PROGNEND-PROGTITLE] sta CIO0_LENLO lda #>[PROGNEND-PROGTITLE] sta CIO0_LENHI jsr CIOV ;Call CIO DINI lda #<BLTOP sta DOSVEC lda #>BLTOP sta DOSVEC+1 rts PROGTITLE .BYTE 125 ;Clear screen PROGNAME .BYTE 32 ;34 characters for program name .REPT [33] .BYTE 32 .ENDR .BYTE 32 ;Extra blank .BYTE "!" ;Inverse video exclamation mark PROGNEND ;=============================================================================== ; RUN segment ;=============================================================================== .IF LDRTYPE=1 *=736 .BYTE <BL000,>BL000 .ENDIF Quote Share this post Link to post Share on other sites
