cubelindo #1 Posted January 3, 2013 Hi there! I have a bartop with a 1280 x 1024 LCD screen. For some unknown reason, changing the resolution corrupts the background of my front-end (MALA) So, I'd like to run Stella in 1280 x 1024 FULLSCREEN 1) If I use "-fullscreen 1" in command line, Stella runs fullscreen but changes the resolution to 640 x 480 2) If I use "-fullres 1280x1024" Stella does not change the resolution but the game window itself is centered (and about 640x480), the rest of the screen is black (so it does not cover the screen) I f I use both commands at the same time I get the same result as in 2) Is it possible to run 1280x1024 fullscreen? Or, at least, run a x2 window By the way, I'm also using "-gl_fsmax 1" in the command line, if that matters Thanks!! Quote Share this post Link to post Share on other sites
cubelindo #2 Posted January 3, 2013 I just touched some of the Video options and Voilà ! Solved! Quote Share this post Link to post Share on other sites
