Sign in to follow this
racerx
AV connector damage
So last year at MGC this unit was working fine. I pulled it out of (dry, semi-sealed) storage today to inventory everything and found this:
No way I can slip a composite cable over that. What would have caused that kind of damage? It's like the edge connector just bubbled up or something...it almost looks burned. Should I just try to Dremel it back down? Try to "desolder" it?
[edit] Upon further review, I think I picked this unit up afterwards. It's looks as though the connectors have been soldered. Should I just desolder whatever's on there?
Edited by racerx
Yes, just clean the pads using solder wick, then alcohol. They will still look silvery, but it's OK.
Edited by Zerosquare
Success! Pads cleaned up, LED installed...just need to Dremel the posts on the white case and reattach to the mobo.
Edited by racerx
