dafivehole
Just got a 1702 monitor for my 800XL but...
when I plug it in, all I get is a white screen and a hum when I turn up the volume. Any ideas? I am using a video cable that Sloopy made for me... with red & white plugs that works great on a modern LCD TV. I tried the front & rear AV connections but no change... is the monitor dead?!?
Thank you,
Roger
Seems the front is A/V and rear offers the seperate chroma/luma. There is a signal selector switch according to text of the manual I found.
Also, even if a monitor won't run due to Pal/NTSC or something dead in the video circuit often it'll still play the audio.
Best to try multiple devices before deciding it's a dud.
Have you tried hooking a dvd player to it? Video to the white and one of the audios to the red, using the front input. A hum in the audio usually means you have video going to the audio input...
Good idea! I hooked my daughter's DVD player to the front of the monitor and it works like a charm!!! I used the 800XL all weekend to play games so I know that the Atari is good... could I possibly just need a new video cable?!?
Thanks again,
Roger
Nevermind, nevermind... I tried swapping the red and white plugs and it works perfectly! I guess the colors aren't supposed to match up between Atari and Commodore? Who knew? One thing, I only get B/W when using the back connections... I guess because of the Chroma/Luma split (which my 800XL doesn't have).
Thanks to all,
Roger
Yes, you would need to do the sVideo mod and have a cable with Audio/Chroma/Luma connectors to use the rear ports and get color on a 800xl (well worth it btw)
Edited by orpheuswaking
Definitely - the increase in picture quality is amazing. 80 column text is perfectly legible. The only disadvantage is that games which rely on artifacting will be in B&W.
It's a one-wire upgrade inside the XL. You can do it yourself.. But you still need the cable that has all 3 RCA jacks for Audio, Chroma, and Luma
