Wildstar #276 Posted February 21, 2015 cool. I'll begin installing the f18A VDP soon. For reasons beyond my control, I got delayed in doing this but soon. I'll also will be intrigue with the F18A emulation support for cross-platform development and proto-testing. Quote Share this post Link to post Share on other sites
+OLD CS1 #277 Posted March 2, 2015 Please forgive me for not RTFM, but I figure someone can answer this really quickly. Does the F18A give any indication on its setting for handling multiple sprites on a line? I would like to have my sprite rotation routine not trigger if the F18A is not set to mimic the old 9918A behavior. Quote Share this post Link to post Share on other sites
Asmusr #278 Posted March 2, 2015 Please forgive me for not RTFM, but I figure someone can answer this really quickly. Does the F18A give any indication on its setting for handling multiple sprites on a line? I would like to have my sprite rotation routine not trigger if the F18A is not set to mimic the old 9918A behavior. So you want to respect the user's decision to see sprite flicker? You probably know that VR30/>1E controls the numbers of sprites that can be displayed on a line, but whether the default value (if you read the register) reflects the jumper setting or it's just zero Matthew will have to answer. Reading the register can AFAIK only be done from the GPU side by reading address >601E. The question is why you would bother to disable your rotation algorithm unless you need the clock cycles you gain for something specific to the F18A? Quote Share this post Link to post Share on other sites
matthew180 #279 Posted March 3, 2015 (edited) Please forgive me for not RTFM ... Forgiven. There is no FM to R at this time. It is on a long list of things to do. At power-on VR30 gets its value from the jumper, however it can be altered by writing a new value to VR30. You can reset VR30 to the jumper selection by writing a zero to VR30. With an F18A you can also read any VDP Register (VR) via the host interface, meaning the 99/4A can read the F18A VDP Registers. Also note that the F18A cannot display a sprite that is disabled, so if your rotation routine prevents a sprite from being displayed for a frame or two then the sprites will flicker. Edited March 3, 2015 by matthew180 Quote Share this post Link to post Share on other sites
Asmusr #280 Posted March 3, 2015 With an F18A you can also read any VDP Register (VR) via the host interface, meaning the 99/4A can read the F18A VDP Registers. Interesting. How do you do that? Quote Share this post Link to post Share on other sites
matthew180 #281 Posted March 3, 2015 Any time you set up a VDP *read* address, the MSB is used as the address of the VR to read (just like when writing to a VR, but the VR is read instead of written). To gain access to the value you read SR (status register) 15. The F18A has 16 status registers, although not all are used, and you set up the SR to read via VR15. LI R0,>0F0F // Set VR15 to read SR15 BL @VWTR LI R0,>0100 // Set to read VR01 BL @VRAD // Set up a VDP Read address which will also put the addressed VR into SR15 MOVB @VDPSTA,R1 // The MSB of R1 now has the addressed VR value LI R0,>0F00 // Set VR15 to read SR0 (the default) BL @VWTR Here is a routine to read all VRs LI R0,>0F0F // Set status port to read SR15 BL @VWTR CLR R0 // Start with VR0 LI R2,64 // Read all VRs, some do not exist and will return 0 LP BL @VRAD // Read the register to SR15 MOVB @VDPSTA,R1 // Put the register value into MSB of R1 . . . do something with VR value in MSB of R1 . . . AI R0,>0100 // Next VR to read DEC R2 JNE LP LI R0,>0F00 // Set status port to read SR0 BL @VWTR . . . ********************************************************************* * * VDP Set Read Address * * R0 Address to set VDP address counter to * VRAD MOVB @R0LB,@VDPWA // Send low byte of VDP RAM write address ANDI R0,>3FFF // Make sure the two MSbits are 00 for read MOVB R0,@VDPWA // Send high byte of VDP RAM write address B *R11 *// VRAD ********************************************************************* * * VDP Write To Register * * R0 MSB VDP register to write to * R0 LSB Value to write * VWTR MOVB @R0LB,@VDPWA // Send low byte (value) to write to VDP register ORI R0,>8000 // Set up a VDP register write operation (10) MOVB R0,@VDPWA // Send high byte (address) of VDP register ANDI R0,>3FFF // Restore R0 top two MSbits B *R11 *// VWTR vr_read_test.zip Quote Share this post Link to post Share on other sites
Asmusr #282 Posted March 3, 2015 Thanks, I see now that this has been in the documentation (spreadsheet) all along, I just didn't connect the dots. Quote Share this post Link to post Share on other sites
matthew180 #283 Posted April 27, 2015 After a year of work I'm happy to announce the release of the F18A V1.6 Firmware. There have been many changes (see below), most of which were driven by suggestions, wishes, and feedback from Rasmus and Tursi as they were exploring the enhanced F18A features. I owe both of them a huge thanks, without their input and help this update would not exist. The main focus of the V1.6 changes was usability. When I created many of the initial F18A features I did not have any context for how they might be used, and in practice some of the features were cool but useless. On the other hand Rasmus was writing games and asking if certain features would be possible, thus began the changes and updates. There are also a few bug fixes, most notably a change to the 5th sprite number in the status register. This change corrects the miner49er bug, and probably fixes compatibility problems with other software not reported to me. One of the coolest (I think) new features is Tile Layer 2 (TL2), which is a second completely independent tile layer that sits on top of the first original tile layer (TL1). Both TL1 and TL2 can have their own name table, color table, and horizontal and vertical scroll registers. Another new feature for those who really like the Text Modes (T40 / T80) is the ability for *each tile* to have its own foreground and background color. This means you can now do full ANSI color in terminal programs, easily highlight text, etc. The text modes now have single-page pixel-scroll support too. There is a virtual scan line feature for those who want to simulate the look of the old CRT monitors. And much more. I have updated the first post of this thread with the 99/4A in-system update program. Also included is a demo disk with excellent programs supplied by Rasmus and Tursi (original Hat and Manderbolt code). Hopefully these demos will entice others to start taking advantage of the F18A's enhanced features. Also, Rasmus' emulator (js99er) has almost full F18A support so you can write and test your F18A code under emulation! Classic99 has some initial F18A support as well, with more support on the way (I hope). Change Log: V1.6 Apr 26, 2015 * Removed fixed tile functionality * Removed border scroll limit functionality * Removed banner functionality * Removed host-side 32-bit counter * Removed host-side 32-bit RNG * Removed GPU 32-bit counter * Removed GPU 32-bit RNG * Removed the sprite "disable value" (>F8) in the sprite Y-location when ROW30 is enabled. * Added second tile layer with its own NTBA, CTBA, h/v page sizes, and h/v scroll regs * Added ECM2/3 pattern table size selections for tiles and sprites. * Added host-side segmented counter with 10ns accuracy. * Added configurable HSYNC and VSYNC GPU triggers. * Added fat-pixel (2x1) with 16-color support to the bitmap layer (BML). * Added 1x1 page scroll support for T40 and T80 modes. * Added option to reset most VDP registers to their power-on values. * Added option to disable Tile Layer 1, which includes GM1, GM2, MCM, T40, and T80. Sprites, the BML, and TL2 are still active and can be enabled/disabled independently. * Added option to allow attribute byte to be fg/bg color select in T40 and T80. * Added per-position tile attribute support. * Added DMA capability to the GPU: 8xx0 - MSB src 8xx1 - LSB src 8xx2 - MSB dst 8xx3 - LSB dst 8xx4 - width 8xx5 - height 8xx6 - stride 8xx7 - 0..5 | !INC/DEC | !COPY/FILL 8xx8 - trigger FILL (active high) will read a single byte at the src address and fill the destination with that byte. src, dst, width, height, and stride are copied to dedicated counters when the DMA is triggered, thus the original values remain unchanged. * Added USR3 jumper to control GROMCLK/CPUCLK output on pin37 to provide support for 9128/29 * Added USR2 jumper to disable/enable simulated scan lines (every other VGA scan line has its color reduced by 50%.) Also controllable via a new VDP register bit. * Added a 5th sprite reporting option instead of reporting the max-sprite, which on the F18A might be different than the original VDP because all 32 sprites can be on a single scan line. * Added a new register (VR51) to limit the maximum sprite processed. This has nothing to do with the number of sprites that can be visible on a scan line, which is controlled by a separate register (VR30). This register is always active and can be used instead of the >D0 byte in the sprite Y-location, and is the only way to limit sprite processing early when ROW30 is enabled. * Changed the GPU interlock so that polling the VDP status register will not cause the GPU to pause. This should greatly increase GPU performance during heavy VDP interrupt polling. * Fixed T80 NTBA two LSbit problem. They are ignored (set to "00") when the F18A is locked to provide compatibility with the 9938 and avoid problem with software that set the two LSbits of the NTBA to other than "11" as the 9938 documentation specifies they should be. This limits the T80 name table to 4K boundaries. When the F18A is unlocked, all 4-bits of the NTBA are used and the T80 name table can be located on 1K boundaries. * Fixed the 5th number update during a scan line. As long as the 5S flag is zero, the 5th number register follows the sprite scanning sequence. Seems to be a transparent latch that follows the input (current sprite being scanned) until latched by the 5S flag. If the status register is being polled and 5S is reset mid frame, then the 5th number begins following the scanned sprites again. This bug is known to have affected Miner49er on the 99/4A. 10 Quote Share this post Link to post Share on other sites
+Schmitzi #284 Posted April 27, 2015 Hi Matthew, great works, thanks. But sorry for one question: Where can I get this update ? Is it this article in the shop, 1$ "F18A Firmware V1.6 Update Service" plus 24.74$ shipping ? Or can I just download the file anywhere ? Ralf 1 Quote Share this post Link to post Share on other sites
CosmicBoy #285 Posted April 27, 2015 Hi Matthew, great works, thanks. But sorry for one question: Where can I get this update ? Is it this article in the shop, 1$ "F18A Firmware V1.6 Update Service" plus 24.74$ shipping ? Or can I just download the file anywhere ? Ralf See post #1 ...... -> http://codehackcreate.com/archives/418 1 Quote Share this post Link to post Share on other sites
+Schmitzi #286 Posted April 27, 2015 Bedankt :) Quote Share this post Link to post Share on other sites
Asmusr #287 Posted April 27, 2015 Congratulations on the release Matthew. Screenshots from the demos. Some are old - some are new. The music in the demos is by various artists and was downloaded from smspower.org. It is played using Tursi's VGM player. 6 Quote Share this post Link to post Share on other sites
Opry99er #288 Posted April 27, 2015 Insane..... Quote Share this post Link to post Share on other sites
+OLD CS1 #289 Posted April 27, 2015 All those bad-ass graphics on our little old TI?? No way?? WAY!! 1 Quote Share this post Link to post Share on other sites
kl99 #290 Posted April 27, 2015 this is awesome news. at the same time this comes too late for the Birkenau TI Meeting in Germany by just a day or two. Klaus Quote Share this post Link to post Share on other sites
+Schmitzi #291 Posted April 27, 2015 yes, confirmed, we need more beta´s Quote Share this post Link to post Share on other sites
Dexter #292 Posted April 27, 2015 Wohoo, they are on my way home! I can't wait to start exploring that video chip! Goodbye VIC-II, Welcome F18A. 2 Quote Share this post Link to post Share on other sites
Imperious #293 Posted May 8, 2015 Anyone know how to turn on the scanlines feature of the new firmware? I can't seem to find any information on how to do this. Quote Share this post Link to post Share on other sites
Dexter #294 Posted May 8, 2015 I think it's the fith bit of register 50. I found it in the spreadsheet file with the firmware. I haven't tested that though. Quote Share this post Link to post Share on other sites
matthew180 #295 Posted May 8, 2015 Two ways: 1. The USR2 jumper will set the default virtual scan line behavior. With the jumper "on" the scan lines are "off". 2. Using VR50 bit >04 (0000 0100) the scan lines can be turned on or off. If the USR2 jumper is off (scan lines enabled) then VR50 cannot turn them off. Quote Share this post Link to post Share on other sites
Imperious #296 Posted May 9, 2015 Thankyou both for that, I'll try the register method, don't really want to take the computer apart if I can avoid it. Quote Share this post Link to post Share on other sites
kl99 #297 Posted May 10, 2015 can i change the Scanlines Setting to be active as default via some software Changes only? If not, are the pins for the JMP2 jumper on the F18A on the board or do I need to solder anything to add this jumper? Sorry, it has been long since I have seen the F18a hardware... I use it almost daily but only see the vga connector Quote Share this post Link to post Share on other sites
matthew180 #298 Posted May 11, 2015 With the V1.6 firmware removing USR2 will enable scan lines that *cannot* be turned off programmatically. If USR2 is on, then the scan lines can be turned on and off via software by setting or resetting bit >04 (0000 0X00) in VR50. 1 Quote Share this post Link to post Share on other sites
Asmusr #299 Posted May 22, 2015 The absolute top feature of the 1.6 firmware is the ability to add a second layer of tiles (aka patterns or characters) on top of the normal Graphics I tile layer. The new layer has its own name table but shares its patterns with tile layer 1. Sprites can be placed anywhere below, above or in between the two tile layer. What's more, each tile layer has its own set of pixel smooth hardware scroll registers. This provides almost unlimited potential for what we could do with a Ti-99/4A. Check out the attached demo (needs to run on F18A console or JS99er.net). Here I have ripped some graphics from MAME from the arcade game Bomb Jack and converted it to TI format using Magellan. The background is displayed in tile layer 1 while the foreground with the platforms is tile layer 2. You can change between foreground and background layers using keys 1-9 and turn off the foreground using 0. 1-3 are displayed on the same background and so are 4-6 and 7-9. If you had to make different patterns for each combination of foreground and background the 256 characters would soon run out, but with two tile layers we have no such problems. Just to show the scrolling capabilities you can also scroll the top layer using the joystick. Imagine what we can do with this: graphical adventures like Leisure suit Larry, platform games like Mario bros, etc. With the F18A it's really easy, all you need to do is to set a few VDP registers. Look in the register spreadsheet for instructions, and please ask if you have any questions. BOMBJACK.dsk Bomb Jack.zip 9 Quote Share this post Link to post Share on other sites
Dexter #300 Posted May 22, 2015 (edited) Wonderfull!!! Thanks for the demo and the explanation. Edited May 22, 2015 by Dexter Quote Share this post Link to post Share on other sites
