0078265317 #1 Posted January 30, 2013 Finally scored a broken besshu zoomer nes off ebay for a little uner 20 with shipping. It doesn't work unless I giggle the cord. I made a video describing what is wrong. I hope somebody knows what is wrong or if it is worth trying to fix. Quote Share this post Link to post Share on other sites
ApolloBoy #2 Posted January 30, 2013 If you have to wiggle the cable to get it working, then it's pretty obvious to assume the cable's the issue. I'd suggest getting an NES extension cord, cut off the other end and then solder it to the controller after you've removed the old cable. Quote Share this post Link to post Share on other sites
0078265317 #3 Posted January 30, 2013 Nice idea but I'm not good with soldering. I'll probably just re-ebay it. They are not rare or anything are they. Quote Share this post Link to post Share on other sites
Rex Dart #4 Posted January 30, 2013 Rare enough to pay $20 for a busted one, eh? You don't have to be good with soldering to replace cables. 1 Quote Share this post Link to post Share on other sites
0078265317 #5 Posted January 30, 2013 Well I didn't see any others. Only other one was 80 something. It said probably works but hadn't used it in ages so I took a risk. I can probably get most back. But I can try to fix it. And I know its hard to see. But if you pause the video around 3 minutes and 1 or 2 seconds you'll see the wires are soldered to board. So it is a solder job. Quote Share this post Link to post Share on other sites
ApolloBoy #6 Posted January 30, 2013 But if you pause the video around 3 minutes and 1 or 2 seconds you'll see the wires are soldered to board. So it is a solder job. Not a difficult one though, not all solder jobs are created equal. Quote Share this post Link to post Share on other sites
Daryle #7 Posted April 18, 2020 I just bought one intended for use with the NES, but I intend to re-cable it to work with a 2600. Mu Ha Ha!!! Quote Share this post Link to post Share on other sites
0078265317 #8 Posted April 18, 2020 1 hour ago, Daryle said: I just bought one intended for use with the NES, but I intend to re-cable it to work with a 2600. Mu Ha Ha!!! There is a 2600 version also. Quote Share this post Link to post Share on other sites
0078265317 #9 Posted April 18, 2020 And its weird the linked video is not my original anymore. Its linking to my fds video. Quote Share this post Link to post Share on other sites
0078265317 #10 Posted April 18, 2020 A little expensive. But just to prove one does exist. https://www.ebay.com/itm/Beeshu-Zoomer-Flight-Controller-Joystick-Commodore-64-128-Atari-2600-Amiga-1988/392669748339?hash=item5b6cf0dc73:g:S0cAAOSw83deN2Q5 https://www.ebay.com/itm/Beeshu-ZOOMER-JOYSTICK-Flight-Controller-for-ATARI-AMIGA-COMMODORE-Systems/143569790412?hash=item216d6d25cc:g:SJoAAOSwGN9cj7hg Quote Share this post Link to post Share on other sites
Daryle #11 Posted April 25, 2020 (edited) The expense was the problem. Everything I found that was Atari compatible was ~$100 I found one for the NES for $25. It was a bit of a trick, there are like five different kinds of switches in this beast, but I figured it out. The NES ones are far cheaper. I couldn't find a wiring diagram for the Zoomer so it took a bit of time probing with an Ohmmeter. Perfectly possible though, works great with Zaxxon. Edited April 25, 2020 by Daryle Quote Share this post Link to post Share on other sites
0078265317 #12 Posted April 25, 2020 Or just buy this. https://www.ebay.co.uk/itm/293206009844 Quote Share this post Link to post Share on other sites
