jbs30000 #1 Posted February 15, 2013 Has there been any upgrades lately? Mainly, with the asymmetrical multiplayer kernel can you check for collision(player1, player5)? It's been over a year since I've done anything and it didn't really work, but I heard it was being worked on. Thanks. Quote Share this post Link to post Share on other sites
Gemintronic #2 Posted February 16, 2013 batari stopped working on the normal multi-sprite kernel. Several known issues exist. As far as I know you must use soft collisions for the virtual sprites. His multi-sprite DPC+ kernel has gotten much more love. I don't use it but there's a good chance virtual sprites have proper collision. Quote Share this post Link to post Share on other sites
Cybearg #3 Posted February 16, 2013 Oh, will he never be working on that stuff again? :< I guess no one else is willing to take up his mantle? Because it would be awesome to see new possibilities being added and the potential of everything expanded upon. Quote Share this post Link to post Share on other sites
Gemintronic #4 Posted February 16, 2013 The whole point of batariBASIC was to be a stepping stone towards assembly. However, reality is complicated. The assembly guys are too busy with their own projects to make bB kernels. The bB guys are too grounded in BASIC to make the transition (to assembly). Regardless of advantages and disadvantages I enjoy BASIC. I even enjoy the double limitations of both the hardware (2600) and software (bB). BASIC homebrew isn't for everybody, that's for sure! Quote Share this post Link to post Share on other sites
jbs30000 #5 Posted February 16, 2013 Actually, I was thinking of the DPC+ kernel. It's just been so long I forgot the name. And I have played around with assembly. I did the tutorials from Andrew Davie. Although searching, I see he's done more lately. Anyway, is collision detection on the DPC+ kernel still buggy for sprites 2 - 5? Thank you. Quote Share this post Link to post Share on other sites
+iesposta #6 Posted February 17, 2013 ... Anyway, is collision detection on the DPC+ kernel still buggy for sprites 2 - 5? Thank you. I only have ever used bB DPC+ kernel, and I haven't used it enough to answer your question. I think I remember reading there is some way to see what collided with sprites 2-5. One of the last things added was a way to color the missile differently when it is not horizontal with its player. It only seem to work for me when the missile was below the player, above was black. Also defining a range of players to the same data was added. Scrolling was going to be the next thing, but seemed to have stopped development about a year ago. Some very impressive games can be done with the DPC+ bB tools we have now, but so far only a few have been completed. Quote Share this post Link to post Share on other sites
Cybearg #7 Posted February 17, 2013 You could do some kind of soft collisions, though it would, of course, take more processing power. Start at the location of the sprite, then check if something is within the range of spritex - 1/2 sprite width and spritey - 1/2 sprite height to spritex + 1/2 sprite width and spritey + 1/2 sprite height. Quote Share this post Link to post Share on other sites
+Random Terrain #8 Posted February 17, 2013 And I have played around with assembly. I did the tutorials from Andrew Davie. Although searching, I see he's done more lately. Has he done more than what is here: www.randomterrain.com/atari-2600-memories.html#assembly_language I better get back to work if he's added more. Quote Share this post Link to post Share on other sites
Gemintronic #9 Posted February 17, 2013 I think only Byte Knight would have a straight answer. He's done serious work with DPC+ http://www.atariage.com/forums/topic/201071-emr-ii-evil-magician-returns-upgraded-to-dpc/ I think he might even have some source in that topic. Maybe (if it's there) we could peek at his code to see how he handles collisions. Quote Share this post Link to post Share on other sites
jbs30000 #10 Posted February 17, 2013 (edited) I guess session 25 is the only one that's new. OK, and as for collisions, that last time I played around I had to use sprite locations to detect virtual sprite collisions (and that should be sprites 2-9 instead of 2-5, my mistake). One last question then. When was the last time the DPC+ kernel was updated? The last time I did anything with bB was about 8 months ago. Edited February 17, 2013 by jbs30000 Quote Share this post Link to post Share on other sites
Byte Knight #11 Posted February 17, 2013 I think only Byte Knight would have a straight answer. He's done serious work with DPC+ http://www.atariage....pgraded-to-dpc/ I think he might even have some source in that topic. Maybe (if it's there) we could peek at his code to see how he handles collisions. My workaround is to check sprite x and y positions for overlap using temp variables. The example is for a collision between player1 and player0, but you could use it for any of the players. The routine will return a temp1 value of 200 if there is a collision. I'm sure there's a more efficient way of coding this, but it works well. pickupkey temp3=player1x+6:temp4=player1y+14 temp5=player1x:temp6=player1y gosub pickup if temp1<>200 then return thisbank z{0}=1:temp1=0:r=%00000010:q=11 return thisbank pickup temp1=player0x+7:temp2=player0y+29 if temp5>=player0x && temp5<=temp1 then goto ypos if temp3>=player0x && temp3<=temp1 then goto ypos return thisbank ypos if temp6>=player0y && temp6<=temp2 then goto col if temp4>=player0y && temp4<=temp2 then goto col return thisbank col temp1=200 return thisbank Quote Share this post Link to post Share on other sites
Gemintronic #12 Posted February 17, 2013 Couldn't that be a function like this: function softcol_player0 rem x1 as player0x, y1 as player0y, x2 as temp1, y2 as temp2, x3 as temp3, y3 as temp4, x4 as temp5, y4 as temp6 if player0x > temp5 then return 0 if temp1 < temp3 then return 0 if player0y > temp6 then return 0 if temp2 < temp4 then return 0 return 1 end Quote Share this post Link to post Share on other sites
jbs30000 #13 Posted February 17, 2013 Yeah, the last program I was working on uses sprite positions to check for collisions. So has there been any DPC+ kernel updates lately, or will there be? Just curious. Quote Share this post Link to post Share on other sites
Gemintronic #14 Posted February 18, 2013 Yeah, the last program I was working on uses sprite positions to check for collisions. So has there been any DPC+ kernel updates lately, or will there be? Just curious. That's a question for batari. I know he had planned for more features regarding the DPC+ kernel. One was making the extra EEPROM on Melody boards accessible for graphic data. Quote Share this post Link to post Share on other sites
Byte Knight #15 Posted February 18, 2013 Couldn't that be a function like this: function softcol_player0 rem x1 as player0x, y1 as player0y, x2 as temp1, y2 as temp2, x3 as temp3, y3 as temp4, x4 as temp5, y4 as temp6 if player0x > temp5 then return 0 if temp1 < temp3 then return 0 if player0y > temp6 then return 0 if temp2 < temp4 then return 0 return 1 end That's good thinking! I hadn't thought to use the function command. This works better for my example: pickupkey temp3=player1x+6:temp4=player1y+14 temp5=player1x:temp6=player1y temp1=pickup(f) if temp1<>200 then return thisbank z{0}=1:temp1=0:r=%00000010:q=11 return thisbank function pickup temp1=player0x+7:temp2=player0y+29 if player0x > temp3 then return 0 if temp1 < temp5 then return 0 if player0y > temp4 then return 0 if temp2 < temp6 then return 0 return 200 Quote Share this post Link to post Share on other sites
Gemintronic #16 Posted February 18, 2013 That's good thinking! I hadn't thought to use the function command. This works better for my example: pickupkey temp3=player1x+6:temp4=player1y+14 temp5=player1x:temp6=player1y temp1=pickup(f) if temp1<>200 then return thisbank z{0}=1:temp1=0:r=%00000010:q=11 return thisbank function pickup temp1=player0x+7:temp2=player0y+29 if player0x > temp3 then return 0 if temp1 < temp5 then return 0 if player0y > temp4 then return 0 if temp2 < temp6 then return 0 return 200 Just to clarify for the studio audience, the lines: temp3=player1x+6:temp4=player1y+14 and temp1=player0x+7:temp2=player0y+29 refer to the far sides of the object being compared. (right?) Quote Share this post Link to post Share on other sites
Byte Knight #17 Posted February 19, 2013 Just to clarify for the studio audience, the lines: temp3=player1x+6:temp4=player1y+14 and temp1=player0x+7:temp2=player0y+29 refer to the far sides of the object being compared. (right?) Quote Share this post Link to post Share on other sites
