Sign in to follow this
lucien2
Fractals
Here are fractals in GPL.
This is not the first fractal program for the TI. I have "Fractal Explorer" from Steve Langguth, I don't know where it comes from.
In the Lima user group disks, there is "mandelzoon" in 150B.DSK, "FLOGO" in 172A.DSK, "FRACT-NTSC" in 174A.DSK, and "FRACTALS" in 817.DSK. (I didn't try any of those).
What is annoying with the Weiand's GPL assembler is that it doesn't compile floating point constants. Another problem is that there is no "integer to float" conversion routine (CIF) in the ROM. So I had to use floats for my counters. I started to convert the CIF function from the E/A cartridge to GPL, but it was to long.
The next step is to implement the zooming function and save/load the result to a file.
2 ways to run it:
FRACTALS/FRACTALT - EA5 program with Weiand's GPL simulator included (no hardware needed, slower)
[email protected] - Compressed object file to load at GRAM >C000 with [email protected] (runs fine with classic99, check "Options/GRAM/>C000")
I wanted to generate a GROM cartridge file: How do I convert a GPL object file to that?
GROM >C000
DATA >AA00,>0100,>0000
DATA MENU
DATA >0000,>0000,>0000,>0000
MENU DATA >0000
DATA START
STRI 'FRACTALS'
OXS TEXT '-2.15'
BYTE 0
OYS TEXT '-1.05'
BYTE 0
ZS TEXT '0.045'
BYTE 0
ONE DATA >4001,>0000,>0000,>0000
TWO DATA >4002,>0000,>0000,>0000
FOUR DATA >4004,>0000,>0000,>0000
SIXTYFOUR DATA >4040,>0000,>0000,>0000
FOURTYEIGHT DATA >4030,>0000,>0000,>0000
FOURTEEN DATA >400D,>0000,>0000,>0000
FMAX DATA >4028,>0000,>0000,>0000
COLORS BYTE 6,8,9,11,10,3,2,12,7,5,4,13,15,1
FLAGS EQU >83FD
CCHA EQU >837D
B1 EQU >8300
B2 EQU >8301
W1 EQU >8302
W1H EQU >8302
W1L EQU >8303
W2 EQU >8304
B3 EQU >8306
B4 EQU >8307
RAM EQU >A000
T32 EQU RAM
OX EQU RAM+32
OY EQU RAM+40
Z EQU RAM+48
X0 EQU RAM+56
Y0 EQU RAM+64
X EQU RAM+72
Y EQU RAM+80
X2 EQU RAM+88
Y2 EQU RAM+96
X2SQU EQU RAM+104
Y2SQU EQU RAM+112
IT EQU RAM+120
MAX EQU RAM+122
X3 EQU RAM+124
FIT EQU RAM+132
COL EQU RAM+140
RAMEND EQU RAM+142
START
MOVE 6,[email protected],[email protected]>1000
DST >1000,@FAC+12
XML CSN
MOVE 8,@FAC,@OX
DST >1000,@FAC+12
XML CSN
MOVE 8,@FAC,@OY
DST >1000,@FAC+12
XML CSN
MOVE 8,@FAC,@Z
ST 40,@MAX
CALL MCCLEAR
CALL MCMODE
DCLR @X
DCLR @Y
PIXEL
MOVE 8,@X,@FAC
MOVE 8,@Z,@ARG
XML FMUL
MOVE 8,@OX,@ARG
XML FADD
MOVE 8,@FAC,@X0
MOVE 8,@Y,@FAC
MOVE 8,@Z,@ARG
XML FMUL
MOVE 8,@OY,@ARG
XML FADD
MOVE 8,@FAC,@Y0
DCLR @X2
DCLR @Y2
CLR @IT
DCLR @FIT
ITERATION
MOVE 8,@X2,@FAC
MOVE 8,@X2,@ARG
XML FMUL
MOVE 8,@FAC,@X2SQU
MOVE 8,@Y2,@FAC
MOVE 8,@Y2,@ARG
XML FMUL
MOVE 8,@FAC,@Y2SQU
MOVE 8,@X2SQU,@ARG
XML FADD
MOVE 8,[email protected],@ARG
XML FCOMP
GT
BR DRAW
CH @IT,@MAX
BR DRAW
MOVE 8,@X2SQU,@ARG
MOVE 8,@Y2SQU,@FAC
XML FSUB
MOVE 8,@X0,@ARG
XML FADD
MOVE 8,@FAC,@X3
MOVE 8,@X2,@FAC
MOVE 8,@Y2,@ARG
XML FMUL
XML FMUL
MOVE 8,@Y0,@ARG
XML FADD
MOVE 8,@FAC,@Y2
MOVE 8,@X3,@X2
MOVE 8,@FIT,@FAC
XML FADD
MOVE 8,@FAC,@FIT
INC @IT
B ITERATION
DRAW
MOVE 8,@X,@FAC
XML CFI
ST @FAC+1,@XPT
MOVE 8,@Y,@FAC
XML CFI
ST @FAC+1,@YPT
MOVE 8,@FIT,@ARG
MOVE 8,[email protected],@FAC
XML FDIV
XML FMUL
XML CFI
DST @FAC,@>8300
* ?? CRASH.
* MOVE 1,[email protected](@>8300),@CCHA
MOVE 1,[email protected](@>8300),@COL
ST @COL,@CCHA
MOVE 8,@X,@FAC
XML FADD
MOVE 8,@FAC,@X
XML FCOMP
GT
BS PIXEL
DCLR @X
MOVE 8,@Y,@FAC
XML FADD
MOVE 8,@FAC,@Y
XML FCOMP
GT
BS PIXEL
END B END
MCMODE
ST >E8,@B1
MOVE 1,@B1,#1
ST 2,@FLAGS
CLR @B1
CLR @B3
DCLR @W2
MC1 DCLR @W1
MC3 ST @B1,@T32(@W1)
DINC @W1
INC @B1
DCHE >20,@W1
BR MC3
CLR @B2
MC2 MOVE >20,@T32,V*W2
DADD >20,@W2
INC @B2
CHE 4,@B2
BR MC2
INC @B3
CHE 6,@B3
BR MC1
RTN
MCCLEAR
DST >800,@W1
MCC1 DCLR V*W1
DINCT @W1
DCHE >E00,@W1
BR MCC1
RTN
END
FRACTALS.zip
Use the CARTSAVE program. It's pretty intuitive. You shouldn't need any docs.
Looks like you've got a cart header properly set up, so it's just a matter of running
CARTSAVE after you've loaded your code and saving the proper Grom bank.
ftp://ftp.whtech.com/9640news/CAT24/CARTSAVE.ARK
Gazoo
Thanks. It worked to save a cartridge from GRAM >C000. But classic99 loads GROM cartridges at >6000 by default, so you must add a line in classic99.ini with "G|C000|1800".
The problem is if I put my program at GRAM>6000, I can't load CARTSAVE anymore.
Cartsave loads at c>A000. There should be no conflict.
Is it because you're using EA to load it? Use a relocated EA image.
Gazoo
Oops... Just checked out CARTSAVE -- same program. My file has no docs or the L&R version.
Edited by Torrax
Yes I'm using EA to load it, with classic99, so it's not possible to load it with TI-BASIC (No disk controller commands).
Maybe there is another emulator with GRAM. I tried to enable the HSGPL card in MESS 0.136, but then I only have a black screen when I start the emulator.
A relocated EA image? It seems to be a hard thing to find. How could that be named? EARELOC? EAC000?
OK, I found how to do it.
1. Load CARTSAVE
2. Warm restart (Keep RAM)
3. Load Fractal object file to GRAM >6000
4. With the debugger, change the PC to >A4A6 to run CARTSAVE
Here is the cartridge file: Fractals-Cartridge.zip
Nice!
It might (MIGHT) also be helpful to know you can make a "ram" cartridge - basically to make Classic99 preload a file into RAM as part of startup. The type letter for RAM in Classic99.ini is 'R', and the rest is the same (load address, length, filename). This loads the file into memory like 'C' but doesn't mark it as ROM. You could create a custom cart that loads your CARTSAVE into RAM and your Fractal code into GROM.
You'd still be stuck with the debugger to get it to start at >A4A6, unless you made a custom ROM cart for CPU >6000, just a header with a name and a start address of >A4A6 would be enough.
If you had to do it many times in the course of debugging it might be helpful to set up. If you only need to do it once or twice your listed steps are probably enough. :)
You can use the RXB package.
Assemble the source with the GPL assembler be sure to use Compressed object code format.
Use the [email protected] to load into >C000
Use CSAVE to save to to a GRAM format at >C000
Bingo you have a new cart file to load at >C000 or you could assemble it to any GROM address.
Thanks, I tested both of your solutions.
@Rich: I didn't thought that REA was at GROM>E000, it works perfectly for my problem.
@Tursi: I didn't notice this "RAM Cartridge" feature. It works fine except that [email protected] does not load the standard characters, but it does its job.
Here is the "GPL Utils" cartridge, with [email protected] and CARTSAVE. Add these lines to classic99.ini:
[usercartXX]
name="GPL Utils"
rom0=C|6000|002E|mods\GPL Utils.C.bin
rom1=R|2000|0FFA|mods\GPL Loader.R.bin
rom2=R|A000|08FA|mods\CartSave.R.bin
GPL Utils.zip
Hello Lucien,
probably you have not set up the HSGPL properly.
http://www.ninerpedia.org/index.php/Setting_up_the_HSGPL_for_MESS
(however, this applies for versions 0.146 and higher, so you'd have to upgrade first.)
Michael
...this applies for versions 0.146 and higher, so you'd have to upgrade first
It's nice to have a GRAM card fully emulated!
How do you load a GPL Tagged object file to the GRAM?
Here's is what I did:
1. Load the E/A module to GRAM bank 16
2. Return to TI-BASIC
3. CALL TIBASIC
4. CALL GRAM
5. Reset and select bank 0 (16)
6. Run E/A
7. Run [email protected]
8. Load compressed object -> Error: No GRAM found at >C000
Another question: CALL HSGPL or EA5/HSGPLE40 bring me directly to the loader sub-menu. How do I go to the main menu?
Er ... do I still have a telephone joker? :) Sorry, I cannot give you more information about how to work with the HSGPL. I just did some elementary tests to make sure the emulation is good. Of course, if things don't work as in real, please tell me.
Michael
3. CALL TIBASIC
4. CALL GRAM
6. Run E/A
Lucien,
Here are the steps that I used to load your FRACTALS program into a bank of my HSGPL card.
1 - Ran the GPL source file through the Weiand GPL Assembler to create a compressed GPL object file.
2 - On my HSGPL card I had previously loaded file TK40G0 into all the banks from bank 0 to bank F. This makes TI BASIC accessible from any bank when you return to the title screen. There is also a file from Winfried Winkler which will also load into GROM 0 to 2. I prefer TK40G0.
3 - Prepared the HSGPL card to receive the object file. On my HSGPL card BANK 7 had GROM 6 and 7 empty. GROM 6 will receive a file loading at >C000. Enter from TI Basic CALL BANK(7) followed by CALL GWRON (turns gram write on) and return to title screen.
4 - Now run GPL*LOADER and it should indicate that the object file has been loaded at >C000.
5 - I cannot do a CALL HSGPL because it comes up as an 80 column program so I run EA5/HSGPLE40. Bank 7 will not show FRACTALS at GROM 6 but BANK(10)(16) will be a copy of BANK(7) and includes FRACTALS at GROM 6 being >C0000.
6 - You can copy the FRACTALS program from BANK(10) to any other BANK you want. To SAVE the file toggle off all the astericks except the one opposite GROM 6. Then press F to enter a file name and press S to save the file. Select a BANK where you want to load your file and press L to load the file.
When I first got my HSGPL card it took a lot of trial and error to understand what the various HSGPL CALLs did. I still have to reason it through but their use is now more easily understood. I assume that the MESS version works in a similar manner. I have never used MESS.
Jacques
Thanks Jacques!
Your method works fine with MESS too.
The only step that was missing in my method was "CALL GWRON" to allow GRAM write...
Fractals, or sort of, in Extended Basic. :)
100 CALL CLEAR::CALL SCREEN(2)::FOR I=1 TO 10::READ CO
110 CALL COLOR(I,CO,2)::CALL CHAR(25+I*8,"78FCFCFCFC78")::NEXT I
120 DATA 14,6,5,13,4,12,7,10,15,16
130 A=20::FOR B=0 TO 31::FOR C=0 TO 23:=B/15-1.5::E=C/11-1::F=D::G=E::H=0
140 I=F*F::J=G*G::IF I+J>4 OR H>=A THEN 150 ELSE G=2*F*G+E::F=I-J+D::H=H+1::GOTO 140
150 IF H>=10 THEN 160 ELSE CALL HCHAR(C+1,B+1,25+H*
160 NEXT C::NEXT B
170 GOTO 170
2 ways to run it:
GROM >C000
DATA MENU
MENU DATA >0000
DATA START
STRI 'FRACTALS'
OXS TEXT '-2.15'
BYTE 0
OYS TEXT '-1.05'
BYTE 0
ZS TEXT '0.045'
BYTE 0
FLAGS EQU >83FD
CCHA EQU >837D
B1 EQU >8300
B2 EQU >8301
W1 EQU >8302
W1H EQU >8302
W1L EQU >8303
W2 EQU >8304
B3 EQU >8306
B4 EQU >8307
RAM EQU >A000
T32 EQU RAM
OX EQU RAM+32
OY EQU RAM+40
Z EQU RAM+48
X0 EQU RAM+56
Y0 EQU RAM+64
X EQU RAM+72
Y EQU RAM+80
X2 EQU RAM+88
Y2 EQU RAM+96
X2SQU EQU RAM+104
Y2SQU EQU RAM+112
IT EQU RAM+120
MAX EQU RAM+122
X3 EQU RAM+124
FIT EQU RAM+132
COL EQU RAM+140
RAMEND EQU RAM+142
START
DST >1000,@FAC+12
XML CSN
MOVE 8,@FAC,@OX
DST >1000,@FAC+12
XML CSN
MOVE 8,@FAC,@OY
DST >1000,@FAC+12
XML CSN
MOVE 8,@FAC,@Z
ST 40,@MAX
CALL MCCLEAR
CALL MCMODE
DCLR @X
DCLR @Y
PIXEL
MOVE 8,@X,@FAC
MOVE 8,@Z,@ARG
XML FMUL
MOVE 8,@OX,@ARG
XML FADD
MOVE 8,@FAC,@X0
MOVE 8,@Y,@FAC
MOVE 8,@Z,@ARG
XML FMUL
MOVE 8,@OY,@ARG
XML FADD
MOVE 8,@FAC,@Y0
DCLR @X2
DCLR @Y2
CLR @IT
DCLR @FIT
ITERATION
MOVE 8,@X2,@FAC
MOVE 8,@X2,@ARG
XML FMUL
MOVE 8,@FAC,@X2SQU
MOVE 8,@Y2,@FAC
MOVE 8,@Y2,@ARG
XML FMUL
MOVE 8,@FAC,@Y2SQU
MOVE 8,@X2SQU,@ARG
XML FADD
XML FCOMP
GT
BR DRAW
CH @IT,@MAX
BR DRAW
MOVE 8,@X2SQU,@ARG
MOVE 8,@Y2SQU,@FAC
XML FSUB
MOVE 8,@X0,@ARG
XML FADD
MOVE 8,@FAC,@X3
MOVE 8,@X2,@FAC
MOVE 8,@Y2,@ARG
XML FMUL
XML FMUL
MOVE 8,@Y0,@ARG
XML FADD
MOVE 8,@FAC,@Y2
MOVE 8,@X3,@X2
MOVE 8,@FIT,@FAC
XML FADD
MOVE 8,@FAC,@FIT
INC @IT
B ITERATION
DRAW
MOVE 8,@X,@FAC
XML CFI
ST @FAC+1,@XPT
MOVE 8,@Y,@FAC
XML CFI
ST @FAC+1,@YPT
MOVE 8,@FIT,@ARG
XML FDIV
XML FMUL
XML CFI
DST @FAC,@>8300
* ?? CRASH.
ST @COL,@CCHA
MOVE 8,@X,@FAC
XML FADD
MOVE 8,@FAC,@X
XML FCOMP
GT
BS PIXEL
DCLR @X
MOVE 8,@Y,@FAC
XML FADD
MOVE 8,@FAC,@Y
XML FCOMP
GT
BS PIXEL
END B END
MCMODE
ST >E8,@B1
MOVE 1,@B1,#1
ST 2,@FLAGS
CLR @B1
CLR @B3
DCLR @W2
MC1 DCLR @W1
DINC @W1
INC @B1
DCHE >20,@W1
BR MC3
CLR @B2
DADD >20,@W2
INC @B2
CHE 4,@B2
BR MC2
INC @B3
CHE 6,@B3
BR MC1
RTN
MCCLEAR
DST >800,@W1
MCC1 DCLR V*W1
DINCT @W1
DCHE >E00,@W1
BR MCC1
RTN
END
I wonder if the XB versions of CSN, FMUL, FCOMP, CFI and FDIV are faster then the TI Basic versions.
From some examples the ones in the XB ROMs seem to be much faster then the ones in the Console.
The reason is they are more compact and I wondered if a marked speed difference is there.
Other wise why would TI have written them so much different then the Console versions for XB.
If there was no speed increase then why not use the Console versions?
The answer obviously would be that they are slower so the XB ROMs were created to speed up the Floating Point functions.
Rich
Now the TI-BASIC version with GPL subprograms for multicolor mode.
I tried to put the subprograms at GROM>E000 to use them with XB and RXB2012. The subprograms seem to work in command mode (without parameters), but they are not found in program mode...
I used Nouspikel's doc. He wrote that XML >13 takes the address of basic variables names at >832C.
I think >832C must contain the address of the first character of the variable name +1 and that >8342 (the last processed token) must contain the first character of the name.
100 CALL MCMODE
110 DIM COLS(14)
120 FOR I=1 TO 14
130 READ COLS(I)
140 NEXT I
150 DATA 6,8,9,11,10,3,2,12,7,5,4,13,15,1
160 OX=-2.15
170 OY=-1.05
180 MAX=40
190 Z=0.045
200 FOR Y=0 TO 47
210 FOR X=0 TO 63
220 X0=X*Z+OX
230 Y0=Y*Z+OY
240 X2=0
250 Y2=0
260 IT=0
270 X2SQU=X2*X2
280 Y2SQU=Y2*Y2
290 IF(X2SQU+Y2SQU>4)+(IT>MAX)THEN 350
300 X3=X2SQU-Y2SQU+X0
310 Y2=X2*Y2*2+Y0
320 X2=X3
330 IT=IT+1
340 GOTO 270
350 COL=COLS(IT/MAX*13+1)
360 CALL MCPOINT(X,Y,COL)
370 NEXT X
380 NEXT Y
390 CALL KEY(0,K,S)
400 IF S=0 THEN 390
410 CALL GMODE
GROM >6000
DATA >AA00,>0000,>0000,>0000
DATA >0000,SUBS,>0000,>0000
SUBS DATA SUB2
DATA MCMODE
STRI 'MCMODE'
SUB2 DATA SUB3
DATA GMODE
STRI 'GMODE'
SUB3 DATA SUB4
DATA MCCLEAR
STRI 'MCCLEAR'
SUB4 DATA >0000
DATA MCPOINT
STRI 'MCPOINT'
B1 EQU >8300
B2 EQU >8301
W1 EQU >8302
W1H EQU >8302
W1L EQU >8303
W2 EQU >8304
W2H EQU >8304
W2L EQU >8305
B3 EQU >8306
B4 EQU >8307
W3 EQU >8308
W3H EQU >8308
W3L EQU >8309
X EQU >830A
Y EQU >830B
COL EQU >830C
RAM EQU >A000
T32 EQU RAM
RAMEND EQU RAM+32
MCMODE
CALL FIRSTTOKEN
CALL CLEAR
ST >E8,@B1
MOVE 1,@B1,#1
ST >02,@B1
MOVE 1,@B1,#4
CLR @B1
CLR @B3
DCLR @W2
MC1 DCLR @W1
DINC @W1
INC @B1
DCHE >20,@W1
BR MC3
CLR @B2
DADD >20,@W2
INC @B2
CHE 4,@B2
BR MC2
INC @B3
CHE 6,@B3
BR MC1
CALL >0012
MCCLEAR
CALL FIRSTTOKEN
CALL CLEAR
CALL >0012
GMODE
CALL FIRSTTOKEN
ST >E0,@B1
MOVE 1,@B1,#1
CLR @B1
MOVE 1,@B1,#3
CALL >0012
MCPOINT
CALL FIRSTTOKEN
CALL READINTVAR
ST @FAC+1,@X
CALL READINTVAR
ST @FAC+1,@Y
CALL READINTVAR
ST @FAC+1,@COL
XML >1B
ST @X,@W1L
CLR @W1H
DSRL 1,@W1
DSLL 4,@W1
ST @X,@W2L
DAND >0001,@W2
DADD @W1,@W2
ST @Y,@W1L
CLR @W1H
DSRL 3,@W1
DSLL 9,@W1
ST @Y,@W3L
DAND >0007,@W3
DSLL 1,@W3
DADD @W1,@W3
DADD @W2,@W3
DST @W3,@W2
DSRL 1,@W3
ST [email protected]>1000(@W3),@B1
DCLOG >0001,@W2
BS MCP1
AND >F0,@B1
OR @B1,@COL
B MCP2
MCP1 AND >0F,@B1
SLL 4,@COL
OR @B1,@COL
MCP2 ST @COL,[email protected]>1000(@W3)
CALL >0012
FIRSTTOKEN
CLR @W1H
ST V*>832C,@W1L
DINC @>832C
DADD @W1,@>832C
XML >1B
RTN
CLEAR
DST >1000,@W1
MCC1 DCLR V*W1
DINCT @W1
DCHE >1600,@W1
BR MCC1
RTN
READINTVAR
XML >1B
XML >13
XML >14
MOVE 8,V*>834E,@FAC
XML CFI
RTN
END
Here's the cartridge with the subprograms: Multicolor subprograms.zip
Edited by lucien2
That is basically correct unless, of course, the variable name is just one character. In any event, >832C is simply the next byte (token) to be processed. As you imply, before the call to XML >13, you would have just read the first character of the name to see whether it is a valid starting character for a variable name. The call to XML >13 expects the first character to be in >8342, as you say. XML >13 will continue to process tokens as part of the variable name until it finds one with the high bit set (any byte greater than >7F). When the call returns, the byte (token) just past the variable name will have already been processed and will be available in >8342.
...lee
Rich
As near as I can tell, XB uses the same console routines as TI Basic. It appears that XB calls the routines directly, whereas TI Basic calls them indirectly through the XML tables. This added level of indirection may well account for the slower speed for TI Basic execution of the same routines.
...lee
I didn't say that >832C must contain the address of the second character of the variable name, I said it must contain the address of the first character + 1. So what is incorrect ? :-D
Anyway, thanks for the explanation, I was a little confused about that. I spent a lot of time moving all those "XML >1B" before digging into the ROM with the debugger.
Touché! :P
No prob. An indispensable resource for digging into the console ROM and GROMs is Heiner Martin's TI 99/4A Intern, which is available in the sticky thread at the top of this forum (TI-99/4A development resources). I use it all the time!
...lee
...lee
I was going to make a video but the speed difference was so small as to be not noticeable. Very disappointed in results.
Most of the XML routines in XB are for String handling and using RAM for programs instead of everything in VDP.
Also the rest of the XML routines are for manipulation of tokens that is far faster then Basic that uses only GPL and no Assembly.
For example XML SPEED uses Assembly to find tokens in a Assembly in ROMs rather then use GPL like BASIC.
Edited by RXB
I don't know the reason many of the XML routines might have been rewritten for XB unless the console XML routines replaced use the CPU RAM PAD or other memory differently from XB and/or return to different locations; but, TI Basic does, in fact, use Assembly in the console ROM for token processing (and many other functions, as well) via XML calls from GPL to ROM. I would expect a speed difference with the use of expansion RAM by XB, but I wonder if that is true when VDP RAM is used for both TI Basic and XB.
...lee
