w1k #1 Posted March 22, 2013 i have problem with flashing SIO2SD with LPT cable.. like before i habe new MB on PC without LPT, then i buy PCI LPT.. but not working http://www.atari.turiecfoto.sk/albums/atari-rozne/IMG_0598.jpg i using ponyprog or AVRprgWin LPT1 DC00-DC07 D880-D887 with old MB which have LPT works fine.. Quote Share this post Link to post Share on other sites
flashjazzcat #2 Posted March 22, 2013 1. Is LPT connector on the correct way around on motherboard header? 2. Try different parallel port configuration in BIOS. Quote Share this post Link to post Share on other sites
+tf_hh #3 Posted March 22, 2013 (edited) Hi, i have problem with flashing SIO2SD with LPT cable.. like before i habe new MB on PC without LPT, then i buy PCI LPT.. LPT1 DC00-DC07 D880-D887 with old MB which have LPT works fine.. This is quite normal. These programs are awaiting the parallel register at the classical LPC/ISA address 0x378 and need direct hardware access to match needed timing and so on. Switch to USB. There are a lot of solutions, the one I use is the open-hardware project USBasp. Extremly cheap, can be build on a breadboard. It´s compatible to ATMEL´s STK500, so you can use AVRDUDE and all other tools they are supporting STK-500. Find schematics, infos, firmware and so on here: http://www.fischl.de/usbasp/ Juergen Edited March 22, 2013 by tf_hh 1 Quote Share this post Link to post Share on other sites
w1k #4 Posted March 22, 2013 its PARALLEL PCI CARD i dont have USB cable or external programer device Quote Share this post Link to post Share on other sites
+tf_hh #5 Posted March 22, 2013 Please read my post again A free USB port you have, I think. The PCI parallel card is useless - none of these (old) programs will work with it. Get the few parts from link I wrote and you get a cheap but good working USB external programmer. Only the ATmega for the programmer must be programmed once with "old", but I think, you can do this with your old system. If you don´t want to DIY and have time, order it here: http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5574883395&toolid=10001&campid=5336500554&customid=&mpre=http%3A%2F%2Fwww.ebay.de%2Fitm%2F261146114337 - less than 7 euros. Juergen Quote Share this post Link to post Share on other sites
w1k #6 Posted March 22, 2013 thank you.. ordered, payed.. maybe that helps Quote Share this post Link to post Share on other sites
w1k #7 Posted March 27, 2013 hmm, strange.. no answer, no reply, no money transfer info, nothing.. lol Quote Share this post Link to post Share on other sites
w1k #8 Posted April 9, 2013 (edited) here is.. how i connect it to sio2sd? Edited April 9, 2013 by w1k Quote Share this post Link to post Share on other sites
8bit-guy #9 Posted April 9, 2013 is 3.5 the last firmware? after updating , i can't get high speed loading with start Quote Share this post Link to post Share on other sites
+tf_hh #10 Posted April 10, 2013 here is.. how i connect it to sio2sd? These are the pinouts for 10-pin and 6-pin AVR isp connector. You´ve to make a little adapter cable for it. Juergen Quote Share this post Link to post Share on other sites
w1k #11 Posted April 10, 2013 thats easy, thank you! Quote Share this post Link to post Share on other sites
