flashjazzcat Posted May 20, 2013 Share Posted May 20, 2013 MATR.XEX (Beta) added to the APT Tools page (it wasn't there before): http://www.atari8.co.uk/apt/tools/ Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted May 20, 2013 Share Posted May 20, 2013 I see at the wiki that you can change the SIO2SD ID from the config settings. I am not sure how to get to the config mode. The wiki says power up with K4 pressed or hold SHIFT down for 5 seconds. Neither of those seem to work for me using this SIO2SD from Lotharek. Can anyone tell me how to enter the config? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 20, 2013 Share Posted May 20, 2013 Which firmware version is on the SIO2SD? I'd assume Lotharek's has the latest, and if so it's wildly different to the previous (v2) firmware. Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted May 20, 2013 Share Posted May 20, 2013 Which firmware version is on the SIO2SD? I'd assume Lotharek's has the latest, and if so it's wildly different to the previous (v2) firmware. I'll be glad to check...how do I see what firmware is running? Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted May 20, 2013 Share Posted May 20, 2013 http://atariage.com/forums/topic/183534-sio2sd-sdrive-comparison/?do=findComment&comment=2304003 Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted May 20, 2013 Share Posted May 20, 2013 (edited) http://atariage.com/...n/#entry2304003 I read the thread...but what did you want me to see? I didn't see anything about entering config mode. But anyway I emailed Lotharek so he should be able to tell me. Thanks to everyone for the help. *edit* sorry if that sounded a little rude, I didn't mean anything by it. I really do appreciate everyone's help. Edited May 20, 2013 by TheNameOfTheGame Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted May 21, 2013 Share Posted May 21, 2013 Woot! Figured it out. It takes a "double-click" on the shift key to enter config-mode. Then I set the ID to 2 and populated the D2: entry. Now I have the XF551 on D1 and SIO2SD on D2 Success! Haha sorry I am just happy to get this setup that way. Thanks to everyone for the help. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted May 21, 2013 Share Posted May 21, 2013 SIO2SD also has a menu to select on (Atari screen) the atrs wanted and which drive# to put the atr on this program is called SIO2SD.XEX found on the wiki page along with instructions. I just wanted you to see the menu screen for the SIO2SD.. Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted May 21, 2013 Share Posted May 21, 2013 Ah ok, cool. I'll check out the program. Thank you. Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted May 21, 2013 Share Posted May 21, 2013 (edited) I had another question. I can't remember the answer since I haven't worked on Atari 8-bit since 1985 haha. Seriously I haven't. Is the disk in Drive 1 supposed to auto boot or do I need to issue a dos command? I put a game disk in the XF551 Drive 1 but when I turned on the machine it didn't load the game. In fact the drive didn't spin up or anything. I have U1MB, SIDE 2, and SIO2SD installed if that would make some difference. Thanks. Edited May 21, 2013 by TheNameOfTheGame Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted May 21, 2013 Share Posted May 21, 2013 Do you have D1: disabled on the SIO2SD? If not, that could be the problem. Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted May 21, 2013 Share Posted May 21, 2013 (edited) Do you have D1: disabled on the SIO2SD? If not, that could be the problem. Yes I just checked it and D1 is set to "off" not "empty" *Edit* I removed the SIDE 2 cart and now the drive tries to load the disk from the XF551. If I plug in the SIDE 2 cart, the drive doesn't try to boot. Edited May 21, 2013 by TheNameOfTheGame Quote Link to comment Share on other sites More sharing options...
