8bit-guy #1 Posted April 10, 2013 HI updated my sio2sd firmware to 3.5 -is it the last one?- but although it works fine, can't get hi speed mode pressing start any advice? Quote Share this post Link to post Share on other sites
8bit-guy #2 Posted April 10, 2013 should i email Lotharek ? Quote Share this post Link to post Share on other sites
w1k #3 Posted April 10, 2013 here: http://sio2sd-dev.gucio.pl/wiki/English latest is 3.1RC2 - 14.2.2012 Quote Share this post Link to post Share on other sites
8bit-guy #4 Posted April 11, 2013 can't get sio hi speed unless i select qmeg as os, now on 3.1 rc2 Quote Share this post Link to post Share on other sites
8bit-guy #5 Posted April 11, 2013 solved 3.1 rc2 does not like picodos images with start button the rest works great Quote Share this post Link to post Share on other sites
+CharlieChaplin #6 Posted April 11, 2013 Well, there is a (double-) driver conflict: a) you are using the MypicoDOS version with built-in ultraspeed / turbo driver on ATR I guess and b) you are also trying to use SIO2SD turbo-driver. One of these turbo-drivers (ultraspeed-drivers) would be enough, both will not work... So, either use a) MypicoDOS barebone version (without turbo/ultraspeed driver) on ATR image and SIO2SD turbo driver on -or- b) MypicoDOS highspeed version (with turbo/ultraspeed driver) on ATR image and SIO2SD turbo driver off -Andreas Koch. Quote Share this post Link to post Share on other sites
8bit-guy #7 Posted April 17, 2013 the only way to get hi speed on spartados with last update is using hi speed os Quote Share this post Link to post Share on other sites
