adam242 Posted April 14, 2013 Share Posted April 14, 2013 When I try to load TurboBASIC from the APT partition of the CF card on my Incognito-equipped 800 under SpartaDOS X, I get an error "179 Memory Conflict". Is TB compatible with SDX? With the Incognito SIDE? I'm not sure what settings to try changing... Quote Link to comment Share on other sites More sharing options...
Frankie Posted April 14, 2013 Share Posted April 14, 2013 You need to run it with the X command 1 Quote Link to comment Share on other sites More sharing options...
adam242 Posted April 14, 2013 Author Share Posted April 14, 2013 You need to run it with the X command Thanks! Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted April 14, 2013 Share Posted April 14, 2013 (edited) You need to run it with the X command OR Put DEVICE COMEXE.SYS into your config.sys. And then rename Turbobas.com to Turbobas.exe ... Edited April 14, 2013 by rdea6 Quote Link to comment Share on other sites More sharing options...
