0078265317
The 5 " black and white tv test...
Hard to say like that, but ROB react to timed flashes more than the lightgun. So you can't fake them with an empty TV. Now if he doesn't react to the game... maybe try to get him closer to the TV set.
Put the contrast to the minimum or the maximum (depends of the TV menu) so you get dark black and flashy white. Ajust the brightness accordingly too.
The blank tv was the black and white untill I got it working. The symphonic is color and works with the game. My 20 inch rca on the cealing or this symphoic color tv/vcr won't work with robby. The game show on the tv. He lights up in test mode but won't move. But he moves left and right when I put fresh batteries in. So not totally broken.
But the tv/vcr combo was only 1 dollar and the black and white was only 2 dollars. So no big deal.
When you click test the light on top of robs head lights up. When you goto direct the light is supposed to stay on isnt it. Or is it only for test mode. And the second controller does nothing in direct mode. The first one controls him right?
OK, I figured it out. You hit test and he lights up. And then select and he stays light up. In direct mode you use the first controller and he works. But he has to be dead center to work. Or sometimes to the side. So he works now. But getting the position just right is key. And sometimes after hitting test and select he lights up but doesn't stay lit. You just hit test again and then select. You have to do it a couple of times. Don't know why he refuses to stay lit sometimes but at least he works. He goes up and down and left and right. Only problem is he doesn't close or open arms. I swear he did once or twice but now he doesn't anymore. But for my mod needs he doesn't need to.
