w1k Posted March 24, 2014 Share Posted March 24, 2014 what movplay i must use if i want run video on real 800xe? i have SIDE II.. any other tools i required? Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted March 25, 2014 Share Posted March 25, 2014 Is there a player for Incognito? Quote Link to comment Share on other sites More sharing options...
phaeron Posted March 25, 2014 Author Share Posted March 25, 2014 Not specifically, but try the regular SIDE2 player -- I forget whether Incognito is SIDE2 compatible or not. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted March 25, 2014 Share Posted March 25, 2014 I thought it was compatible, but all I get is error D5D5 and more D5's. Maybe the base IDE register is wrong? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 25, 2014 Share Posted March 25, 2014 IDE registers are not in the same place, so not compatible at that level. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 25, 2014 Share Posted March 25, 2014 Change IDE_BASE to $D1E0 and it should work with Incognito. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted March 25, 2014 Share Posted March 25, 2014 Thanks for the info, but I can't get it working yet. I replaced all instances of F0 D5 with E0 D1, and I still get the Read error D5D5 D5D5D5D5 message. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 25, 2014 Share Posted March 25, 2014 (edited) You'd be better off downloading the source a couple of pages back and simply changing one equate and then recompiling. You may have replaced all instances of the data register, but there are a further seven IDE registers at consecutive locations. Edited March 25, 2014 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted March 25, 2014 Share Posted March 25, 2014 Do I also need to change these? side_sdx_control equ $d5e0side_cart_control equ $d5e4 I wish I could find a comprehensive memory map of all the different devices (SIDE, SIDE2, Incog, U1M). Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 25, 2014 Share Posted March 25, 2014 (edited) The Ultimate map is described here: http://spiflash.org/block/20.html SIDE is here: http://spiflash.org/block/17.html Note self-explanatory URLs [irony]. Both Ultimate and Incognito use the same SDX build, so there should be enough information there. Edited March 25, 2014 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted March 25, 2014 Share Posted March 25, 2014 Thanks again for the info. It attempts to play, but I get only flashing, tearing video and an obnoxious high pitched beep. It may be my VERY old CF card. I'll get a new card and try again. Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted March 27, 2014 Share Posted March 27, 2014 Hey, it's Sega CD video! Great work! Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 27, 2015 Share Posted April 27, 2015 ex-Ocean coder Jim Bagley apparantly https://youtu.be/V6-_48Aqso0 Quote Link to comment Share on other sites More sharing options...
bugbiter Posted May 20, 2015 Share Posted May 20, 2015 My god, I just discovered this thread and I absolutely LOVE it! I'm actually going to get me an SIDE cartridge now just to be able to play those videos! As far as I've seen the mode for playback is a static APAC. I would really love to see a video in a line-interlaced APAC mode, like I did in my clash of lightsabers demo. http://atariage.com/forums/topic/231575-clash-of-the-lightsabers-a-little-apac-animation/ Phaeron already commented about using that mode, said it was impossible because there are not enough cycles left in hblank. But I don't understand, why would you need extra cycles in hblank for swapping frame A/B kernels? That would be done in Vblank. Frame A with luma on even and chroma on odd lines is one kernel routine on its own, Frame B with chroma on even lines and luma on odd lines would be another. Of course I have no clue how the video data is arranged - is it a char mode Display List or Gr.15 lines? But I'd like to see it pulled off! The line flicker is not everyone's taste but it kinda doubles the vertical resolution which in my opinion really boosts the look and I like it better than the horizontal pinstripes. P.S. Huge thanks Phaeron, for giving us Altirra! 1 Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 21, 2015 Author Share Posted May 21, 2015 I think there's been a misunderstanding. Swapping the polarity of the lines each frame is possible, and actually it only requires switching two register values with the same kernel. The reason I didn't do it is that when I tried, my TV wigged out -- the dynamic picture enhancement chip really didn't like it. Quote Link to comment Share on other sites More sharing options...
bugbiter Posted May 21, 2015 Share Posted May 21, 2015 cool! In these cases only an old scool CRT will pay off.. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted June 6, 2015 Share Posted June 6, 2015 (edited) How hard would it be for someone to cobble together a program to select the address configs from a menu, just choose the device and it changes the code in the player so on can simply select it and go? Edited June 6, 2015 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted June 6, 2015 Share Posted June 6, 2015 It should be relatively easy to make the player auto-detect the host device, for that matter. 1 Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted August 15, 2015 Share Posted August 15, 2015 I thought the same player compiled for MyIDE + flashcart would work with MyIDE II but I get "read error ffff ffffffff". I'm pretty sure the IDE base addresses for MyIDE II are the same $D500-$D507. Is there something I need to do differently with MyIDE II? Quote Link to comment Share on other sites More sharing options...
phaeron Posted August 15, 2015 Author Share Posted August 15, 2015 Haven't tried it with MyIDE-II, but I think the CompactFlash power has to be enabled via $D50E first. Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted August 16, 2015 Share Posted August 16, 2015 (edited) Thanks, Phaeron. Seems to be working now with MyIDE II (at least it does in Altirra). I hope I didn't mangle anything in your player. -SteveS Edited August 16, 2015 by a8isa1 Quote Link to comment Share on other sites More sharing options...
Beetle Posted May 4, 2016 Share Posted May 4, 2016 I'd like to know what length the video can have. Is it restricted to a known size, or only by the size of the media? Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 5, 2016 Author Share Posted May 5, 2016 Size of media, unless you have a CF card bigger than 128GB. The player uses 28-bit LBA addressing. 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted May 5, 2016 Share Posted May 5, 2016 I still can't get this to work on my Incognito. I have used a sector editor and set the IDE registers correctly (I think). Has anyone made a version of the player specifically for Incognito? Hopefully the player doesn't use illegals because I have an 816. I really want to see this work. Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 5, 2016 Author Share Posted May 5, 2016 No illegals. It only abuses ANTIC, not the CPU. 1 Quote Link to comment Share on other sites More sharing options...
