bogax
fun with tables
Not sure how useful this is likely
to be.
I modified SeaGtGruff's move_around_rooms
code to use tables to choose a new room
from more than 256 possibilities based
on a couple of indexes using a bit of asm.
In bB a table index can only go up to 256
(I don't know what the limit on entries in
the actual table is but it can be more than
256)
So you need to use more than one table
to index more than 256 entries.
You can do that by using different routines
for different tables (as is done in SeaGtGruff's
code) This needs more code and a lot of
jumping around
Here I've put (the pointer to) the tables in
tables then select a table with one index
then point into the selected table with another
index. Unfortunately this is (relatively)
complicated and needs a bit of asm.
First you have to create a table of
pointers to tables. Since you need two bytes
to specify a table and bB tables have one
byte entries the table of pointers is
split into tables of hi and lo bytes.
Since the target table is changing and
not hard coded in rom you need a couple
(consecutive) bytes of ram to point to it.
I used temp1 and temp2.
You need to create the tables of pointers to
tables
data pointers_hi
>table0_name, >table1_name, >table2_name
end
data pointers_lo
<table0_name, <table1_name, <table2_name
end
bB adds a "." to the beginning of labels
but not for table names so you don't need
the a "."
So you look up the table pointers and put
the lo part of the pointer in temp1 and the
hi part of the pointer in temp2.
Then a bit of asm looks into the pointed to
table and puts the result in a variable.
This is packaged in a macro called lookup
rem parameter 1 is the destination variable
rem parameter 2 is a variable containing
rem the index into the tables of
rem pointers to tables
rem parameter 3 is a variable used to index
rem into the selected table
macro lookup
temp1 = pointers_lo[{2}] : temp2 = pointers_hi[{2}]
asm
ldy {3}
lda (temp1),y
sta {1}
end
end
here I've molested SeaGtGruff's code
tables_of_tables.bas
if lookup is a function you can pass
constants (but it's slower and uses
another level of stack)
rem first parameter is the index into
rem the table of pointers table
rem second parameter is the index into
rem the selected table
function lookup
asm
tax
lda pointers_lo,x
sta temp1
lda pointers_hi,x
sta temp2
lda (temp1),y
end
return
tables_of_tables_w_function.bas
Edited by bogax
When batari starts to dig back into bB enhancements I hope he'll continue with his aim of gynourmous 512k EEPROM support. In that case we'll have to think bigger than 256 element game maps.My thought is that normal DATA statements can have up to 256 elements - which equates to 16x16 map locations. You could have a 16x16 world array of 16x16 map location arrays for the player to march through.If I'm making enough sense, can an example of that be done?
I do a podcast on 2600 games, and I was in email contact with Ed Riddle. He said that Indy 500 was "largely table driven." I have no idea what that means, can you explain it to a uses-the-computer-for-the-internet-only person?
That means complicated math like car rotations can't be done nicely on the 2600. Instead, you create a cheat sheet using a portion of game data as a table to look up correct values. So, instead of calculating how many pixels to move when you go 90 degrees you look it up on a nice chart you put into storage.
Which is a lot faster but takes a lot more space.
But it's not necessarily only speeding up calculations.
It might be look up what to do for this player moving in that
direction with those conditions.
I moved the SeaGruff's playfields into a data statement.
There's a macro that adds a constant to an 8.8 variable.
Apparently if the constant is declared with const bB prepends
a # but DASM doesn't seem to mind (here the constant is
the label from a data statement which doesn't have that
problem)
http://basicplay.netau.net/
tables_of_tables_2.bas
Edited by bogax
