w1k #1 Posted May 21, 2013 (edited) hello, yes, its true - i using my CF card in digital-camera and i created partition there for SDX-SIDE II.. today my cf stops work on my camera, and i cant connect/read data on PC - dead card.. i try read it on atari.. and works.. so.. can i in FDISK/FORMAT setup card for basic use? delete, format, or other? then i want format it on PC/camera i deleted all partitions.. but card still dead :/ edit: 15:06.. i create full 16gb APT.. save partition.. voila - WINDOWS see that card.. then i tried format, maybe 7x and succes.. so for phorographers using CF cards - if you cant read card on PC, or CAMERA, buy SIDE II Edited May 21, 2013 by w1k Quote Share this post Link to post Share on other sites
+Gemintronic #2 Posted May 21, 2013 With no partitions and no formatting you cannot get a drive letter in My Computer. Boot to a Linux based Live CD like Parted Magic and partition + format the CF card there using GParted. http://partedmagic.com/doku.php Quote Share this post Link to post Share on other sites
w1k #3 Posted May 21, 2013 that card was no seen on pc.. any utils/soft not helps.. side ii helps Quote Share this post Link to post Share on other sites
fibrewire #4 Posted May 21, 2013 (edited) I've had this happen a few times with Cisco 64MB and 128MB CF cards. It doesn't read anymore on the PC card reader, but works on the Side II? *Open a CMD and type "compmgmt.msc" *Under 'Storage' click on 'Disk Management' Does is show up there? If you have another CF card does it work on the PC? Sometimes pocket lint or dust gets in the pins, or worse a pin in the reader gets bent. In case of the latter, http://www.bentcardpins.com/fixityourself.html Edited May 21, 2013 by fibrewire Quote Share this post Link to post Share on other sites
