TXG/MNX #1 Posted June 11, 2013 Hello, I came across this advertisement, I know some of these were really made. Anyone has schematics and hardware info from this. Maybe pictures ? It's an interface to connect a pc keyboard to Atari XL/XE, I do know there are other interfaces like AKI but I am really looking for info from this interface. Transkey for XL-XE.pdf Quote Share this post Link to post Share on other sites
+bob1200xl #2 Posted June 11, 2013 Finding things is a problem, but I have information on the interface. What do you want to know? Bob Quote Share this post Link to post Share on other sites
+bob1200xl #3 Posted June 11, 2013 Here are scans of a blank version 2 PCB... Quote Share this post Link to post Share on other sites
TXG/MNX #4 Posted June 11, 2013 Here are scans of a blank version 2 PCB... Thanx Bob, do you also have pictures of a working full populated version, gal/pal dumps logic.? Quote Share this post Link to post Share on other sites
+bob1200xl #5 Posted June 11, 2013 I only have one early version unit that is complete. This newer PCB has a 6520 in U1, a 6504 in U4, a 555 in U5, An LS32 in U6, and an LS14 in U7. U2 and U3 have a Dallas DS1220Y and a 2732, but I don't know which is where. I don't know where the wiring goes into the Atari. No programmable logic is used. You want to build one, I take it? Bob Quote Share this post Link to post Share on other sites
TXG/MNX #6 Posted June 11, 2013 Hi bob thanx for the info almost all info is there, only the info about resistors, capacitors on the board and the ROM dump of the 2732 rom. Quote Share this post Link to post Share on other sites
+bob1200xl #7 Posted June 13, 2013 TRANSKEY2_4.ROM Well... I have a ROM that is marked TK2.4. The BPC must be ByPassCapacitors - use [email protected]? The pull-up resistors should be 3.3K? The other timing resistors and such are probably 47K? Try 10ufd for the electrolytic capacitor. If you can draw a schematic, we can probably figure it all out. Bob 1 Quote Share this post Link to post Share on other sites
+tf_hh #8 Posted June 14, 2013 Just for my personal knowledge... what are the advantages of this TRANSKEY product? If I understand the attached manual right, it´s "just" a solution to connect a PC-keyboard to an Atari 8-bit. There are some modern solutions like AKI or DarkAKI, which realizes the same using a single ATMEL or MicroChip PIC doing all the work. Schematics and firmware are availible, the few parts needed could be soldered on a breadboard. Candle has made a "SimpleStereo" PCB with a AKI-type solution (i.e. DarkAKI, didn´t know exactly at this time) also. If someone has the time/capacity to make a new project, I think it´s better to realize something to connect an USB PC-keyboard to. PS/2 keyboards are getting rare, the most USB keyboard can be used on PS/2 also (with a simple adapter), BUT most of them have a horrible PS/2 timing, tolerated by most PCs, but not all. Also I have had some of them not working using AKI or DarkAKI. So a keyboard-interface using USB should be the more comfortable way... Quote Share this post Link to post Share on other sites
itzmike #9 Posted June 14, 2013 I've got a TransKey stashed somewhere around here, like as not still in the 130XE I'd used it with. The device only worked with either an AT or XT keyboard; sadly I don't recall which it was now. Regardless, those types of keyboard would be rather hard to come by these days. Quote Share this post Link to post Share on other sites
TXG/MNX #10 Posted June 14, 2013 I've got a TransKey stashed somewhere around here, like as not still in the 130XE I'd used it with. The device only worked with either an AT or XT keyboard; sadly I don't recall which it was now. Regardless, those types of keyboard would be rather hard to come by these days. Interesting when you're not using it anymore PM me Quote Share this post Link to post Share on other sites
Stephen J. Carden #11 Posted October 31, 2013 I only have one early version unit that is complete. This newer PCB has a 6520 in U1, a 6504 in U4, a 555 in U5, An LS32 in U6, and an LS14 in U7. U2 and U3 have a Dallas DS1220Y and a 2732, but I don't know which is where. I don't know where the wiring goes into the Atari. No programmable logic is used. You want to build one, I take it? Bob The 24 pin chip that is the closest to the edge can be either a 6116 SRam or Dallas DS1220Y. The chip in the center can either be a DS1220Y or 2732. Either way you must have the Rom Code in the center 24 pin Slot. The way I run mine is the Stock TransKey Rom Burnt into a 2732 and then I use the DS1220Y in place of the 6116 so it remembers my Macros as I cycle the computer off and on. Quote Share this post Link to post Share on other sites
Stephen J. Carden #12 Posted October 31, 2013 Also I do not see a daughter Board here that is a must have. Now I am Glad I did not solder the last board I have. transkey info.txt Quote Share this post Link to post Share on other sites
+mytek #13 Posted July 25, 2018 Kind of a Necro Bump, but I found what the OP was looking for... the original TransKey schematic, as well as some other drawings of interest. Here are the scanned documents: Original_1990_TransKey_schema.pdf I hope this is still of some benefit to the OP or perhaps others . 6 Quote Share this post Link to post Share on other sites
