g007 #326 Posted February 16, 2014 (edited) Hi everybody! I'm also a digikey customer and got my board about 3 weeks ago - unsurprisingly with the 'edbl' SRAM chip and the same problems other people told before.Foft's hint to change the pin setting does the magic - no ram problems anymore :-) Thank you Foft! I added the following lines to the qsf (atari800core_20140119.tar.xz): set_instance_assignment -name CYCLONEII_TERMINATION "SERIES 25 OHMS" -to SRAM_CE_N set_instance_assignment -name CYCLONEII_TERMINATION "SERIES 25 OHMS" -to SRAM_LB_N set_instance_assignment -name CYCLONEII_TERMINATION "SERIES 25 OHMS" -to SRAM_OE_N set_instance_assignment -name CYCLONEII_TERMINATION "SERIES 25 OHMS" -to SRAM_UB_N set_instance_assignment -name CYCLONEII_TERMINATION "SERIES 25 OHMS" -to SRAM_WE_N set_instance_assignment -name CYCLONEII_TERMINATION "SERIES 25 OHMS" -to SRAM_ADDR[0] ... set_instance_assignment -name CYCLONEII_TERMINATION "SERIES 25 OHMS" -to SRAM_ADDR[17] set_instance_assignment -name CYCLONEII_TERMINATION "SERIES 25 OHMS" -to SRAM_DQ[0] ... set_instance_assignment -name CYCLONEII_TERMINATION "SERIES 25 OHMS" -to SRAM_DQ[15] I encountered the same SRAM problems with the ZX Spectrum project where the termination resistors also resolved the problems. I also patched the 'DE1 Control Panel' binary to fix the anoying 'Quartus version bla bla' message, you can download it here. GreetsG. Edited February 16, 2014 by g007 3 Quote Share this post Link to post Share on other sites
foft #327 Posted February 17, 2014 Cool:) Thanks for building/testing. Its actually an engineer at Terasic's suggestion. The engineer also suggested adding these: set_input_delay -max -clock CLOCK_50 -1.5 [get_ports SRAM_DQ*] set_input_delay -min -clock CLOCK_50 -1.5 [get_ports SRAM_DQ*] I'll add these + resistors as above to the source and build on my site. Quote Share this post Link to post Share on other sites
jugac64 #328 Posted February 19, 2014 Hi Foft and everybody! My name is Juan and I am a C64 fan, I hope you don’t mind if I post this information here :-) Foft: Do you know the Turbo Chameleon 64? It is another FPGA system developed in the form of a Commodore 64 cartridge, but it works also in standalone mode (without a real C64) and it can emulate very well the Commodore 64. There it is also an accessory for it that offers four joysticks connections: the Docking Station. Actually the Chameleon emulates 4 platforms (cores) very well: Commodore 64, Atari 2600 (done by the creators of the Chameleon) and from other devs: ZX Spectrum and Amiga 500 (Minimig). It would be awesome if you could port the Atari 8-bit core to the Chameleon, I guess you can get some support from the Chameleon’s developers (it seems that they helped also the other core’s developers). Here you can get useful information about the Chameleon: http://wiki.icomp.de/wiki/Chameleon http://syntiac.com/chameleon.html The Docking Station: http://wiki.icomp.de/wiki/Chameleon_docking_station The Manuals: http://beta.icomp.de/bin/Chameleon_usermanual.pdf http://beta.icomp.de/bin/Chameleon_progmanual.pdf And this manual is specifically targeted to core’s developers: http://syntiac.com/pdf/chameleon_coredev.pdf Here it is the Chameleon’s Yahoo mailing list where we (beta testers) communicate with the Chameleon's developers: https://groups.yahoo.com/neo/groups/chameleon_64/info Hope you get some interest on this platform and we can have the Atari 8-bit ported to the Chameleon some day! Best regards, Juan PD: Hi Mark! (NML32) Quote Share this post Link to post Share on other sites
NML32 #329 Posted February 19, 2014 Hey Juan, I really wish I could afford the Chameleon 64 with docking station. Also good to see you here on AA forum. -Mark Quote Share this post Link to post Share on other sites
NML32 #330 Posted February 23, 2014 @foft, How's it going any updates? Thanks, Mark Quote Share this post Link to post Share on other sites
foft #331 Posted February 23, 2014 @foft, How's it going any updates? Not much this weekend - guests... MIST starting to run. Memo pad + keys with wrong mapping! 1 Quote Share this post Link to post Share on other sites
foft #332 Posted February 23, 2014 Hi Foft and everybody! My name is Juan and I am a C64 fan, I hope you don’t mind if I post this information here :-) Foft: Do you know the Turbo Chameleon 64? It is another FPGA system developed in the form of a Commodore 64 cartridge, but it works also in standalone mode (without a real C64) and it can emulate very well the Commodore 64. Hi Juan. This Atari XL core wouldn't be so good without the Turbo Chameleon's great 6502 core. So it's definitely a candidate. I've got plenty of porting to do already though. Replay, MIST, MCC216 and SOCkit. Then I have to fix some bugs Mark (NML32) reported... Oh and make the DE1 breakout board. So it might be a while! Quote Share this post Link to post Share on other sites
pik33 #333 Posted February 23, 2014 (edited) I tried this core - on "old" DE1 with no success. Maybe I did something wrong. I flashed this: atariroms3.bin at address 0 Then I used this: atari800core_20140120.sof Results was mixed from time to time. Black screen (sync signals OK), white rectangle on black screen (several times) and one time I got something like OSD menu. My board has damaged SW1, it is difficult to get it pressed (it seems OSD menu appeared after succesfullu pressing SW1) Edited February 23, 2014 by pik33 Quote Share this post Link to post Share on other sites
foft #334 Posted February 23, 2014 I suggest trying the old version with internal rom and/or ram to narrow it down. I think Hias posted some instructions in this thread. Before that, try these: I) Erase flash rom before flashing. ii) Turn off sd mode. With a valid sd card it hangs. Quote Share this post Link to post Share on other sites
jugac64 #335 Posted February 23, 2014 Hi Juan. This Atari XL core wouldn't be so good without the Turbo Chameleon's great 6502 core. So it's definitely a candidate. I've got plenty of porting to do already though. Replay, MIST, MCC216 and SOCkit. Then I have to fix some bugs Mark (NML32) reported... Oh and make the DE1 breakout board. So it might be a while! Hi Foft! It is great that you are considering porting the Atari 8-bit core to the Chameleon 64 on the future, thank you!!! :-) It seems that Peter's 6502 core is very good indeed. Take care and keep the good work! Juan Quote Share this post Link to post Share on other sites
foft #336 Posted March 1, 2014 I put a newer version of the build on my website. The only change being the inclusion of the 25ohm resistors on the SRAM. So should work on the newer boards. 2 Quote Share this post Link to post Share on other sites
TheMontezuma #337 Posted March 2, 2014 I put a newer version of the build on my website. The only change being the inclusion of the 25ohm resistors on the SRAM. So should work on the newer boards. Hello foft, since a few days I have an Altera DE1 Board at home (with IS61LV25616AL SRAM Chip). My board is connected to a TFT VGA Monitor (640x480). All tests with DE1 Control Panel were successful. I have just tried atari800core_20140301.sof and I can see only black screen http://youtu.be/kVlywCjFHaQ Actually I tried older versions too and I had the same results. I realized that SW9 UP enables VGA, otherwise the monitors display "No signal". All others SW switched are down. I ereased the flash and flashed the OS XL (16kb) at address 0x0000. Then I read it and verified it against the original file and they were the same. Then I flashed BASIC at 0xC000. Did I forget anything? Does anybody work with VGA monitor at all? I really appreciate your efforts for the community. Perhaps you could find some time and setup a small wiki for the project. At the moment the only documentation available seems to be the readme.txt file and the forum with over 300 postings... Best Regards TheMontezuma Quote Share this post Link to post Share on other sites
foft #338 Posted March 2, 2014 (edited) Flash the OS XL at 0x4000. There are 4 banks and since most people are flashing atariroms3 from my site I changed it to default to bank 1 without thinking! Edited March 2, 2014 by foft Quote Share this post Link to post Share on other sites
xxl #339 Posted March 2, 2014 can user adjust speed of the 6502? Quote Share this post Link to post Share on other sites
NML32 #340 Posted March 2, 2014 @TheMontezuma If you are using your SD card to load files you need SW0 up also. Quote Share this post Link to post Share on other sites
TheMontezuma #341 Posted March 2, 2014 Flash the OS XL at 0x4000. There are 4 banks and since most people are flashing atariroms3 from my site I changed it to default to bank 1 without thinking! Thanks! That helped can user adjust speed of the 6502? Yes, via OSD (press KEY0) Quote Share this post Link to post Share on other sites
foft #342 Posted March 2, 2014 Thanks! That helped Yes, via OSD (press KEY0) Great:-) As for speed adjustment - it doesn't really work properly at the moment. Breaks PMGs and Pokey! I had it working, but when I added multiple levels I broke it. I need to fix this and add a cache - so it runs at effectively 57MHz... 1 Quote Share this post Link to post Share on other sites
foft #343 Posted March 2, 2014 (edited) can user adjust speed of the 6502? xxl - I think you are a bit of an illegal ops guru. This core is pretty good at matching them, but I get some blitting issues on some games using them. Do you know what opcodes are commonly used for that? Also any chance of helping me out getting the gtia sound running properly? I take 4 digital pokey channels -> non-linear mixing filter then just add on gtia 1-bit (at low vol) before sending to whatever the board dac is. Edited March 2, 2014 by foft Quote Share this post Link to post Share on other sites
xxl #344 Posted March 2, 2014 for undocumented code look here: http://xxl.atari.pl/?p=824 or even better for you to atari800 sources http://sourceforge.net/projects/atari800/files/atari800/3.0.0/ / cpu.c, about gtia/pia PWM sound ask Fox - he make it works fine in ASAP http://asap.sourceforge.net/ (sources available) I keep my fingers crossed for your project Quote Share this post Link to post Share on other sites
TheMontezuma #345 Posted March 2, 2014 Hello foft, is it correct that you are working on a breakout PCB for Altera DE1? I would be very interested in it Greetings TheMontezuma Quote Share this post Link to post Share on other sites
foft #346 Posted March 3, 2014 Something like this? Just need to double check it then I can order a few. Note the DE1 is not 5V tolerant though and this board uses 5V freely. I built some other boards to make the DE1 5V tolerant so it will end up quite big. But this is V1;-) Eventually this will be all in one with the FPGA on board too. 1 Quote Share this post Link to post Share on other sites
foft #347 Posted March 3, 2014 for undocumented code look here: http://xxl.atari.pl/?p=824 or even better for you to atari800 sources http://sourceforge.net/projects/atari800/files/atari800/3.0.0/ / cpu.c, about gtia/pia PWM sound ask Fox - he make it works fine in ASAP http://asap.sourceforge.net/ (sources available) I keep my fingers crossed for your project Thanks. I'll check out the ASAP code. Quote Share this post Link to post Share on other sites
candle #348 Posted March 3, 2014 could i help? Quote Share this post Link to post Share on other sites
jhusak #349 Posted March 3, 2014 hello foft, is there an a800 core for mist to download and test? It would be good to have a deeper look into sources (for read), so everybody interested in involvement in this great project (I mean Candle, for example who wants to help and he can surely) As xxl said he does, I keep fingers crossed for this project, too. There is quite a few fingers crossed already. I am ready to test some games/demos on mist platform. Quote Share this post Link to post Share on other sites
foft #350 Posted March 4, 2014 (edited) @jhusak: Mist rbf file uploaded: http://ssh.scrameta.net/www.scrameta.net/mist/readme.txt Regarding source: Now I've ported it a few places I'm going to clean it up/refactor it all into one archive then release again. The DE1 one I last uploaded isn't _that_ different. edit: Works pretty well but extended RAM is broken... @Candle: Help always appreciated. Its in Eagle though - which I think you aren't a fan of:-) Edited March 4, 2014 by foft Quote Share this post Link to post Share on other sites
