foft
Potential new hardware
4 hours ago, foft said:
Did you put sdflash.bin in there?
This must be new! No, I don't know about sdflash.bin - where do I get it? I see on google (mentioned in one release page) that it has something to do with profile support, but there is no link to it, or other explanation.
Thanks for helping, foft!
@foft
Hi. Thank you for doing this. I have been following the thread but I haven’t done anything.
Today, with newer boards, what would you recommend me to buy to work on this?
Should I still use the DE-1 or do you recommend other options ?
In here
http://www.64kib.com/autobuild/20200603/mist/
Put it in the atari800/rom folder.
Might need to press f11 and select screen mode.
http://www.64kib.com/redmine/projects/eclairexl/wiki/Setting_video_mode
Edited by foft
19 minutes ago, Blues76 said:
@foft
If you want just an Atari, EclaireXL. For a multi-device take a look at the mist, mister and turbo chameleon.
36 minutes ago, foft said:
In here
Aha!  Not having an Eclaire, I didn't realize those instructions also applied to the MIST. F11 + V set it to VGA, and I'm now looking at a friendly menu. Thanks so much!
I can now boot to the core, and set the VGA mode, but I can't figure out how to load a disk. I used to go into the MIST OSD menu to select one. I see F8+Enter is supposed to launch a prompt, but I'm not seeing that happen. Oddly, I'm getting "Internal server errors" on a lot of the links in the Eclaire wiki right now.
Edited by dylanmc
Yeah something looks broken on the web server, I’d better take a look...
Thanks
I’m aware there is a mister forum.
I was looking at some links that recommend the pieces that one need (de-10 nano board, etc.)
https://www.retrorgb.com/mister.html
https://hothardware.com/reviews/mister-diy-console-fpga
https://github.com/MiSTer-devel/Main_MiSTer/wiki
Im going to follow what I found but if you or anyone has recommendation, they are welcome.
Things are working great, except colors seem off in some games, and the game Sea Dragon's horizontal scrolling is jerkier than on the original machine.
http://atariprojects.org/2019/05/18/play-sea-dragon-on-your-atari-8-bit-computer-15-60-mins/
Here's a video of it running more smoothly:
Edited by dylanmc
7 hours ago, foft said:
Sounds like pal vs ntsc
I’ll check in any case
I'll also experiment with PAL & NTSC settings -thanks! Silly me: I thought modern multisync monitors & VGA took that off the table, but I understand that when emulating this old hardware, it's still a factor. I'm using NTSC settings, and it's connected to a NEC multisync monitor via VGA on the MIST.
I bought a SiDi MIST clone, but the atari800 core leads to a black screen, and a return to the menu. Any idea what could cause this?
I have upgraded to the latest firmware, put a800xl.rom in the root of the SD card, and tried previous versions of the atari800 core with the same result. I also tried F11 + V, putting a settings file in atari800/rom and putting sdflash.bin in atari800/rom.
Edited by dgreefhorst
Did you try to use the MiST RBF on SiDi?
You must use this:
https://github.com/ManuFerHi/SiDi-FPGA/tree/master/Cores/Computer/Atari800
