flashjazzcat Posted October 8, 2013 Share Posted October 8, 2013 RGB in this case is not VGA. Some VGA monitors will sync down to VBXE's 15KHz RGB signal, but they are in the minority. You may require a scan doubler for a monitor like that one. Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 9, 2013 Share Posted October 9, 2013 Is this using standard or VGA core of VBXE ? Note that under Pal you'll be doing 50 FPS which many monitors won't support or will show distorted or flickering picture. But you'd expect that a Pal TV that handles VGA should be able to handle the VBXE VGA. 1 Quote Link to comment Share on other sites More sharing options...
Aking Posted October 9, 2013 Share Posted October 9, 2013 Is this using standard or VGA core of VBXE ? Note that under Pal you'll be doing 50 FPS which many monitors won't support or will show distorted or flickering picture. But you'd expect that a Pal TV that handles VGA should be able to handle the VBXE VGA. I don't know yet how to set up cores? 2.1 VBXE has all of them flashed from factory,right? But even when it's an ntsc XEGS, had to set the board jumpers to pal in order to get colour on composite after the install. The tv handles pal and ntsc ,(use it to watch tv on pal play games on ntsc)is standard def, with 800x600 max res,has svideo and dvi-pc output with and adapter to vga You get response from the Atari setting the input to Pc-Analog I can take pictures if you want, but its pretty much a square grid Please help Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 9, 2013 Share Posted October 9, 2013 (edited) This is rough info and I think is reasonably accurate but you should look up the official stuff to confirm: - default VGA core for 14 MHz VBXE install only supports VGA mode of GTIA functionality, ie VBXE goodies like extra graphics modes, blitter etc not available. - VGA core in 28 MHz VBXE install supports extra VBXE goodies but only 2 palettes are available instead of 4 (this might be out of date info) Regardless, the VGA mode is a physically different install as well because by default VBXE doesn't provide SYNC outputs, the VGA cores reassign a couple of pins to provide them. Edited October 9, 2013 by Rybags Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted October 9, 2013 Share Posted October 9, 2013 Note: Candle remarked that the VGA core is deprecated and "hit and miss". Quote Link to comment Share on other sites More sharing options...
candle Posted October 9, 2013 Share Posted October 9, 2013 True Quote Link to comment Share on other sites More sharing options...
Aking Posted October 10, 2013 Share Posted October 10, 2013 (edited) success ! went with the scan doubler option nicest / cleanest atari output i have ever seen last word looks amazing too... Edited October 10, 2013 by Aking 1 Quote Link to comment Share on other sites More sharing options...
Aking Posted October 15, 2013 Share Posted October 15, 2013 I've got my VBXE, yeah!....and mine was installed with a vga HD15 connector. I had two plans for getting this hooked to a flat panel monitor, both of which would utilize a HD15 VGA connector. Try #1 http://cbm-hackers.2304266.n4.nabble.com/Anyone-ever-attach-a-mono-LCD-to-a-PET-td4618295.html Users on various forums report that the NEC Multisync can scan down to 15khz - and that it works with Amiga. This was $44 shipped for me from ebay - but it doesn't matter, the NEC LCD1550M did NOT work with my VBXE. Try #2 As a backup plan I bought one of those arcade board to LCD converters. http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5574883395&toolid=10001&campid=5336500554&customid=&mpre=http%3A%2F%2Fwww.ebay.com%2Fitm%2FGBS-8220-Video-Converter-CGA-EGA-YUV-RGB-TO-VGA-Arcade-Jamma-Game-Monitor-to-LCD-%2F261153377967%3Fpt%3DLH_DefaultDomain_0%26hash%3Ditem3ccdf44eaf This did work! $32.99 - looks good to. I have a VGA cable going from my VBXE to the Arcade board, and a VGA cable going from the arcade board to the monitor. I tried both the NEC Multisync, and a regular vga monitor that I know could never scan down to 15khz - both worked good, no banding - the best picture I've ever seen from the Atari. This is a quick report, I'll take some pictures later if I get a chance. used the same board, nice picture on static images though i noticed a side effect (motion blur? some kind of delay?) with fast moving graphics for example on River Raid, moving the plane fast left/right shows some pixels on it's nose form a "tail" similar effect on megamania: the hamburgers moving seem to have a small "hat" H.E.R.O. going fast also has a small hat/tail opposite to the directions it is moving pacman looks like junior when moving fast, etc Quote Link to comment Share on other sites More sharing options...
candle Posted October 15, 2013 Share Posted October 15, 2013 Try with some high end monitor for gamers, as they tend to be fadter than average. Also don't belive in marketing specs, gray-to-gray transition speed means nothing. Stick to good old white-black-white transition speed as a guide for tft matrix qality. Quote Link to comment Share on other sites More sharing options...
Aking Posted October 15, 2013 Share Posted October 15, 2013 (edited) Try with some high end monitor for gamers, as they tend to be fadter than average. Also don't belive in marketing specs, gray-to-gray transition speed means nothing. Stick to good old white-black-white transition speed as a guide for tft matrix qality. tried another old samsung vga lcd, then on a new, 2 ms Syncmaster p2770 same problem maybe the delay is from the scan doubler card, i'm using de hd 9800 (just one vga out)? Edited October 15, 2013 by Aking Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 15, 2013 Share Posted October 15, 2013 Is there docs for the scandoubler? Sometimes the combing problem can be because the device is doing frame blending, ie adjacent frames get combined to form one. If the monitor is a TV-based one then that might also be the case. Quote Link to comment Share on other sites More sharing options...
Aking Posted October 15, 2013 Share Posted October 15, 2013 (edited) Is there docs for the scandoubler? Sometimes the combing problem can be because the device is doing frame blending, ie adjacent frames get combined to form one. If the monitor is a TV-based one then that might also be the case. tried on the samsung p2770, a high end lcd monitor, with same results the doc of the scan doubler we are all using is attached Edited October 15, 2013 by Aking Quote Link to comment Share on other sites More sharing options...
Aking Posted October 15, 2013 Share Posted October 15, 2013 Try with some high end monitor for gamers, as they tend to be fadter than average. Also don't belive in marketing specs, gray-to-gray transition speed means nothing. Stick to good old white-black-white transition speed as a guide for tft matrix qality. just look at the nose of the plane in river raid and you will see the effect tried lots of displays/monitors not happening on vbxe games VBXE or Scan Doubler problem ? Quote Link to comment Share on other sites More sharing options...
Aking Posted October 15, 2013 Share Posted October 15, 2013 Is there docs for the scandoubler? Sometimes the combing problem can be because the device is doing frame blending, ie adjacent frames get combined to form one. If the monitor is a TV-based one then that might also be the case. what about a vga to video component cable ? thus avoiding the scan soubler ? would i get the Vbxe benefits anyway ? Quote Link to comment Share on other sites More sharing options...
Joey Z Posted October 16, 2013 Share Posted October 16, 2013 what about a vga to video component cable ? thus avoiding the scan soubler ? would i get the Vbxe benefits anyway ? you mean RGB + CSYNC to YPbPr? if it is done properly, then yes, you get full VBXE capability. the YPbPr inputs on a TV at least will accept 15khz signals. just beware that on TV's there may be overscan causing some of the picture to be cut off. it's not very likely on an LCD though I think, since it all gets handled digitally Quote Link to comment Share on other sites More sharing options...
Aking Posted October 16, 2013 Share Posted October 16, 2013 you mean RGB + CSYNC to YPbPr? if it is done properly, then yes, you get full VBXE capability. the YPbPr inputs on a TV at least will accept 15khz signals. just beware that on TV's there may be overscan causing some of the picture to be cut off. it's not very likely on an LCD though I think, since it all gets handled digitally thanks for answering ! where do i wire csync output on YPbPr? vga 1 red plug vga 2 green plug vga 3 blue plug vga 13 (csync) ? ground pins ? Quote Link to comment Share on other sites More sharing options...
Joey Z Posted October 16, 2013 Share Posted October 16, 2013 thanks for answering ! where do i wire csync output on YPbPr? vga 1 red plug vga 2 green plug vga 3 blue plug vga 13 (csync) ? ground pins ? you need a converter that converts from RGB to YPbPr. if you are able to build simple electronics, it is possible to build one. Quote Link to comment Share on other sites More sharing options...
Mathy Posted October 16, 2013 Share Posted October 16, 2013 Hello Joey, guys it's not very likely on an LCD though I think, since it all gets handled digitally Most of the CRT TV's that were built in the last 10 to 15 years process the incoming signal digitally. That's why 100Hz, Picture in Picture and other nice features became possible. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
Aking Posted October 17, 2013 Share Posted October 17, 2013 confirmed these scan doublers are not fast enough. so what is the solution for VBXE equipped A8s on modern lcds ? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted October 17, 2013 Share Posted October 17, 2013 confirmed these scan doublers are not fast enough. so what is the solution for VBXE equipped A8s on modern lcds ? See if you can get an LG M1921a or similar. Even if it doesn't have a SCART (and most do - and SCART's generally the best bet in Europe), the VGA input on these monitors syncs down to 15KHz. Quote Link to comment Share on other sites More sharing options...
