Opry99er #226 Posted June 13, 2015 Some current pix of my awesome setup!!! Just.... boxes upon boxes upon totes upon totes of this. Sad...... 3 Quote Share this post Link to post Share on other sites
+OLD CS1 #227 Posted June 14, 2015 I think the whole drive dedicated to Xevious is interesting! ....It was a great NES game. I particularly like the ceiling mounted chain-so that you can flush without having to leave the TI. ...maybe it is to flush the DNS-Server on the upper floor. Actually, what is REALLY funny about that is "Xevious" is my internal DNS, DHCP, SMTP, and syslog aggregation server running Solaris 8. FTR, it is a 500MHz AMD K6-III+ with 128MB RAM and a 120GB SSD. So, yeah, I could have a pull-chain to flush the Bind cache Xevious is the only remaining server of a half-dozen game-theme named servers from around 2002 or so. It runs like a damn champ and all I have to do is replace the PSU and CPU fans every once in a while. Quote Share this post Link to post Share on other sites
wyerd #228 Posted June 14, 2015 Not quite Ti-99 related, but if we're showing racks, here's mine (well the UDS10 is connected to the LAN and PEB) :- It's split in two. The top half is the networking, and the bottom half is the AV as it's located in the theatre room which I've just finished...........well, phase one........ 2 Quote Share this post Link to post Share on other sites
+Schmitzi #229 Posted June 14, 2015 hmm, looks like that you mounted it in the basement, in the niche under the stairs ? Nice frame If so, how do you pass the hot air away ? through an vent in one of the upper stair-steps ? Quote Share this post Link to post Share on other sites
wyerd #230 Posted June 14, 2015 It's in the loft's old bonus room. The air is drawn through the grille above the receiver and out at the top by the 1U fan. The room itself is connected to the house's central AC. You can just see the white thermostat on the left of the pic. 1 Quote Share this post Link to post Share on other sites
+Schmitzi #231 Posted June 14, 2015 ah, in the loft, OK. also thought of that, because of that angle in the upper right. But was covinced from the downstairs a cool solution, literally Quote Share this post Link to post Share on other sites
Omega-TI #232 Posted June 15, 2015 Not quite Ti-99 related, but if we're showing racks, Man that is the nicest rack I've ever seen that did not have to be labeled as ! Quote Share this post Link to post Share on other sites
wyerd #233 Posted June 16, 2015 Man that is the nicest rack I've ever seen that did not have to be labeled as ! Thanks! You should see the other side when it's pulled out - it's not as neat as the front. BTW, I also made each and every one of the patch cables - it took a while! Quote Share this post Link to post Share on other sites
daafies #234 Posted July 4, 2015 my humble setup i use the built-in drive as drive 3. drive 1 and 2 are on the HxC floppy emulator. i'll get a bigger monitor eventually 2 Quote Share this post Link to post Share on other sites
Omega-TI #235 Posted July 4, 2015 Have you ever considered getting one of these... ...then mounting the unit in a case to get a better angle on the display and to protect the electronics? You would be able to have the display and the SD card at the same angle. Ciro mounted his in the P-Box itself, but I would never have the guts to go hacking on the PEB! 3 Quote Share this post Link to post Share on other sites
daafies #236 Posted July 4, 2015 Yea for sure i need to do that still. Quote Share this post Link to post Share on other sites
daafies #237 Posted July 4, 2015 Have you ever considered getting one of these... ...then mounting the unit in a case to get a better angle on the display and to protect the electronics? You would be able to have the display and the SD card at the same angle. Ciro mounted his in the P-Box itself, but I would never have the guts to go hacking on the PEB! Ciro's box looks awesome 1 Quote Share this post Link to post Share on other sites
ti99iuc #238 Posted July 4, 2015 (edited) Have you ever considered getting one of these... ...then mounting the unit in a case to get a better angle on the display and to protect the electronics? You would be able to have the display and the SD card at the same angle. Ciro mounted his in the P-Box itself, but I would never have the guts to go hacking on the PEB! Well, i do not like so much hacking vintage items too, but i can change idea on items that have not more a life... The PEB i hacked was really in dead conditions: Very rusty inside, stained and scratched on external plastics, power supply absent. I gave him a new life... I thought that it could never be as like the original, and then I changed for my needs of actually use. Ciro's box looks awesome thank you daafies ... i am happy you like... i also done some update on my modification lastly, i changed the Power Supply with a new one from the Classic Arcade of the '80 years it has 4A for Floppy Drives I also inserted the HxC in a 3.5" case so it will more easy to update the SD Card (before of this i had to open everytime the PEB cover) and update the front panel of the SD Card with a PowerButton On/Off so i can change the sd card without poweroff the PEB, and also e number drive settings so i can decide the number of the drive without open the PEB too :) i have some other idea for other details, the third drive is external in past days, my friend gifted me some spare parts of TI99 beige and silver, in very ugly condition and missing parts... i really believe that i will do some hack with these too :) one only problem for me.... lot of ideas but really not enough time for complete them Edited July 4, 2015 by ti99iuc 5 Quote Share this post Link to post Share on other sites
Omega-TI #239 Posted July 4, 2015 Well, i do not like so much hacking vintage items too, but i can change idea on items that have not more a life... The PEB i hacked was really in dead conditions: Very rusty inside, stained and scratched on external plastics, power supply absent. I gave him a new life... I thought that it could never be as like the original, and then I changed for my needs of actually use. Ahhh, that make sense! If it was already thrashed everything is an improvement with nothing to lose. 1 Quote Share this post Link to post Share on other sites
am1933 #240 Posted July 18, 2015 Managed to add this to the collection for less than £2 4 Quote Share this post Link to post Share on other sites
+Ksarul #241 Posted July 18, 2015 Nice find--and a very good book to have too! Quote Share this post Link to post Share on other sites
LynxHandyCaster #243 Posted July 26, 2015 Here's my humble TI 99/4a setup, combined with my Atari 130XE on the same monitor, at the latest meeting of the Atlanta Historical Computing Society last week. 6 Quote Share this post Link to post Share on other sites
+Ksarul #244 Posted July 26, 2015 I'm glad to see you were able to show it! Awareness that a classic system is still alive is a very good thing. Nice beginning for a really good system too--you have parsec which is one of the better old-school games. Quote Share this post Link to post Share on other sites
+Schmitzi #245 Posted July 26, 2015 Here's my humble TI 99/4a setup, combined with my Atari 130XE on the same monitor, at the latest meeting of the Atlanta Historical Computing Society last week. very nice system. how did you connect the screen to the TI ? (can´t see the cable) Quote Share this post Link to post Share on other sites
LynxHandyCaster #246 Posted July 26, 2015 Hope this photo helps show you how I have the TI hooked up (the white coaxial cable). The black cables are connected to my Atari 130XE. 1 Quote Share this post Link to post Share on other sites
+Schmitzi #247 Posted July 26, 2015 thank you Quote Share this post Link to post Share on other sites
am1933 #248 Posted July 27, 2015 Here's my humble TI 99/4a setup, combined with my Atari 130XE on the same monitor, at the latest meeting of the Atlanta Historical Computing Society last week. Some nice other bits 'n' pieces in there, like the Wico Boss, the 1050 and the Touch Tablet. Quote Share this post Link to post Share on other sites
ClausB #249 Posted August 2, 2015 Do TI-59s count? http://atariage.com/forums/gallery/image/12218-ti-sr-56/ 5 Quote Share this post Link to post Share on other sites
+Ksarul #250 Posted August 2, 2015 (edited) I've got an SR-50 and an SR-56, but I never did pick up a TI-59 for some reason. I do have the maintenance manual for the Mag Tape Strip port though. . . Edited August 2, 2015 by Ksarul 1 Quote Share this post Link to post Share on other sites
