RetroFiends #1 Posted January 1, 2014 (edited) Edit: Edit:Fixed. See post #6. Time to make some billboard 100 pop hits http://atariage.com/forums/topic/220302-music-and-sound-editor-doesnt-work/?do=findComment&comment=2897157 Edit: For the time being, I suppose this isn't a huge priority considering the lovely Tonetool provided. I'm making a shark game, and I needed a "Jaws" Esque alternating two note pattern which was easily done using the tones in Tonetool as a reference and a counter. ______________________________________It just seems to be one thing after another.It's the same issue that's shown up a couple of times, but no answers work. For the record, I'm using the latest VbB and am trying to use the very same Music and Sound editor included with that.I get this error: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.IO.FileNotFoundException: The specified module could not be found. (Exception from HRESULT: 0x8007007E) at VisualbB.SoundLib.vbBSoundLib..ctor() at VisualbB.DialogMusic..ctor() at VisualbB.mainIDE.MusicEditorToolStripMenuItem_Click(Object sender, EventArgs e) at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e) at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5472 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- VisualbB Assembly Version: 1.0.0.566 Win32 Version: 1.0.0.566 CodeBase: file:///C:/VisualbB/VisualbB.exe ---------------------------------------- Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Runtime.Remoting Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- VisualbB Title Kernel Assembly Version: 1.0.0.4 Win32 Version: 1.0.0.4 CodeBase: file:///C:/VisualbB/VisualbB%20Title%20Kernel.DLL ---------------------------------------- System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll ---------------------------------------- System.Transactions Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll ---------------------------------------- System.EnterpriseServices Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll ---------------------------------------- VisualbB.SoundLib Assembly Version: 1.0.0.1 Win32 Version: 1.0.0.1 CodeBase: file:///C:/VisualbB/VisualbB.SoundLib.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. I tried following suggestions of installing .net 1.1 but that isn't happening as there is a known compatibility issue regarding it and as such just won't work. I'm on Windows 7 64 bit.So, any suggestions or alternatives? Edited January 2, 2014 by RetroFiends Quote Share this post Link to post Share on other sites
jwierer #2 Posted January 1, 2014 When does it occur, when you try to launch the sound editor or when you try to use it. The "The specified module could not be found", leads me to believe you may just be using an earlier version that doesn't work with the visualbb.exe you have. -Jeff Quote Share this post Link to post Share on other sites
RetroFiends #3 Posted January 1, 2014 It happens when I try to launch it. I'm using 566, and I'm using the version of soundlib for 566, (1.0.0.1). Quote Share this post Link to post Share on other sites
jwierer #4 Posted January 2, 2014 Can you zip it up your folder and PM it to me? I want to see if I get the same error. Thanks, Jeff Quote Share this post Link to post Share on other sites
RetroFiends #5 Posted January 2, 2014 Absolutely, will send it momentarily. Quote Share this post Link to post Share on other sites
jwierer #6 Posted January 2, 2014 Fixed. Anybody that is having this problem simply doesn't have msvcr71.dll installed on their system. Simply copying this file to your vbB folder should fix the issue. It's a matter of the .NET 1.1 framework not being installed, or not allowed to be installed. You only need this one missing DLL. -Jeff Quote Share this post Link to post Share on other sites
+Random Terrain #7 Posted January 2, 2014 Fixed. Anybody that is having this problem simply doesn't have msvcr71.dll installed on their system. Simply copying this file to your vbB folder should fix the issue. It's a matter of the .NET 1.1 framework not being installed, or not allowed to be installed. You only need this one missing DLL. -Jeff Will you add that to the first post in the VbB thread in whatever section of the post is appropriate? Quote Share this post Link to post Share on other sites
jwierer #8 Posted January 2, 2014 Will you add that to the first post in the VbB thread in whatever section of the post is appropriate? Yep, already did that. 1 Quote Share this post Link to post Share on other sites
