gozar
Sick 1200XL
I decided to fire up a 1200XL I bought years ago, and it doesn't work right. I can get into the memory test, and it completes it fine. Nothing else works, I get gibberish on screen right before it locks up. Attached is a screen shot when I first turn it on with nothing attached before it goes into the hardware test.
Where should I start?
open it up, carefully push down on all the socketed chips to re-seat them if they are loose. If that doesn't work, try swapping ANTIC and GTIA with known good ones. Could be the OS ROM(s) as well.
I've seen the same type of gibberish with eventual lock up just as reported when I had RAM timing issues, I'm thinking it cleared up after I replaced the 74LS08 AND chip with an HCT08 one (phase two clock generation) and it's hammered along just fine these 15 years since. But this was on an 800XL, don't know if this will work for the 1200XL since it may not be the same chip doing the same job in there. Verify that much yourself first and I think it might be worth trying?
The 08 is involved in Phase2, but, is most likely not a problem here.
I pulled up each of the main chips and re-seated (re-sat? :-) them and the gibberish went away. I can boot it into MyDos just fine. I tested it with Action! and didn't see any problems.
I also found a bonus, apparently it has a Newell 256K upgrade installed! But....
Spartados X doesn't boot, and neither does my MyIDE+Flash.
Also, it looks like the previous owner cut out a square above the cartridge port. Any idea why? (See attached pic)
Oh, and HISIO.COM reports incompatible OS. I thought it worked with all of the XL/XE OSs?
Geez, hate replying to myself... Spartdos X does work. MyIDE+Flash does not. I get my initial boot menu, but no matter what I select it won't boot from the drive.
If the opening had extended all the way to the outside I would think it was to allow insertion of an ICD SDX or RT8 cartridge. As is it might still allow reassembly with either already in the cartridge slot?
That's a funny looking 1200XL, with a cart port on top of the case. If it is really a 1200XL, and has a Newell, it is for sure extensive modification.
Oh, pardon me, that is just your avatar, not the computer in question.
Edited by russg
Yes - amazing. The 1200XL in his avatar has been extensively modified to exactly resemble an 800XL. :D
It doesn't go through the case at all. I guess it would allow for access to the inside, but there isn't anything there.
Bill means the cut-out in the cartridge tunnel (not the case) looks as if it's intended to accomodate the "lip" on the SDX and R-Time 8 cartridges. They certainly don't fit the standard bay, but having just tested one, I'd say the cut-out is precisely for the purpose Bill suggested. I don't think the cut would need to go all the way to the edge.
Oh! That makes sense. Since I've never used a 1200XL, I just assumed the Sparta carts would fit. :-)
Now to figure out why my MyIDE+Flash won't boot. Plus I have to do something about the video, it's painful compared to my 800XL!
Oh, well.
I checked it. The RTime and SpX carts don't fit. The cutout is for ICD carts. It seems to allow insert the cart, but it just doesn't go far enough.
Edited by russg
Yeah - the cart tunnel is a bit of a pain in that respect. On the other hand, the SDX and RT8 carts are a non-standard shape... as are a lot of modern cartridges which won't fit without modification to the tunnel.
The 1200XL video sucks famously. Plenty of mods out there you can try, though. I gave up and put a VBXE in there, but I have to say the 1200XL video mod I did looked a lot better when I converted the machine to PAL - not sure why.
The Clearpic mod looks pretty doable. I've done a few of the mods to my 800XL, and the output looks really good. It looks amazing compared to the 1200XL, lol!
Yeah - Clearpic may have been the one I did. It was certainly an improvement, but LCD screens still suffered from a lot of smearing on certain colour combinations. Things miraculously improved when I converted it to PAL. I always said the 800XLs had decent video, though. I managed to tweak one or two to look really nice through LCD screens.
I have a Dell 20" with composite input, but it looks like crap. That's why I dug out my Commodore 1702 monitor, looks so much better!
Annoyingly, I was forced to resort to s-video LCDs when I first got the 1200XL because none of my 1084S monitors would sync to 60Hz y/c. Now the 1200XL's PAL, I use tubes exclusively. :)
I've found with some LCD monitors that Composite is better than S-video and on other monitors it's the S-video thats better, it depends how the manufacturer designed the input circuits.
I've been meaning to build a cable for SVideo from my 800XL, but haven't gotten around to it.
The stock 800XL doesn't come with the Chroma/color signal connected to the monitor port, but it's a simple modification.
The commonly available stereo DIN5M to 4 X RCA cable works with monitors like the Commodore 1702 which uses 2 x RCA jacks for chroma/luma inputs, more modern TVs/monitors normally have an mini-DIN port. 8-bit Classics sells such a cable, it has the mini-DIN for s-video, RCA for composite, and the single audio channel is on 2 RCA plugs for connection to TVs/monitors with stereo inputs.
http://www.8bitclassics.com/Atari-800-XL-XE-5-Pin-DIN-S-Video-Cable.html
Already added the chroma connection to use with the separate jacks on my 1702, but that cable looks really nice.
