FND
My 400/800 Super Salt Version 3.03 - 33 pictures could take a while to load
Anyone have one of these, Ver. 3.03 ? Since I was getting ready to sell mine
(along with a few others from the same collection) I have been searching the Web
For info but have not had much luck. Found only one other verifiable example
With screen shot but I suspect it is in the hands of a Non-US collector since the
start screen shows it is plugged into a PAL system. Other then that 1
example I have not been able to find another. There was one listed on Ebay late
last year as Ver. 3.03 but auction pictures showed it was actually a Part #FD100335
Rev. A . not Ver. 3.03
Since info and screen shots seem nearly impossible to find I thought I would
post all the different screen OPTIONS along with what is displayed after running
each option. Also included a scan of the cartridge, Label and Inner PCB front and back.
NOTE I ran this on a 800XL so some of the functions returned error results ( Switches, OS System)
Not sure what the ”ADJUS TMENT” function does but on my 800XL it just returned a black screen,
waited a few minutes but nothing happened so not sure if I needed to wait longer or it simply does not
do anything on my 800XL,. Also when entering the serial # in the ”production” function I keep getting
a warning stating wrong #
I’ll start with the Cartridge and Label
Interestingly there is an "Atari Rejected" labeled applied to this cart and
Identified as either 1250XL or 1200xl (not sure the third number since it
Was written at the crease so its not fully readable). Below are scans of the REJECTED label pulled
away from the front of the cartridge and placed flat allowing it to be viewed complete from left to
right (Rejected label glue has dried out on the front but still firmly stuck to the side) Additionaly it
is labeled 400/800 SALT on the back label and under the Red Rejected Label.
Below PCB front & back
Below is the start screen as displayed on my 800xl (NTSC)
Below is the Function/options screen
I have included only the 1 screen shot below showing the option Screen with the command entered.
The command line selection is entered using the 1 key letter command show in Red for each function,
once pressed it automaticaly enters the correct command. Once entered you then need to press the
enter key to run the function
Below are screen shots of all the Functions/Options.
1st option ANYVIDEO
2nd option COLORBARS
3rd option GRAYBARS
4TH option keyoard (Blue is lowercase, Red is uppercase)
5TH option PORT TEST
There are 2 settings that can be used for results.
Either “Pass / Fail” or “Display Errors” (Set using “DISPLAY OPTIONS”)
I have included both types of screen results below.
6TH option RAM TEST
When running the RamTest a second option screen will display asking you to choose a number from 1 to 4,
each choice will check 8K Blocks RAM.
Example 1 = 8K, 2 = 16k, 3 = 24k and 4 = 32k
7th option SWITCHES
8TH option TONE TEST – This function when run will play a series of tones. It
runs through 3 different registers and the # changed with each series of tones
9th option VOLTAGE TEST
10th option PRODUCTION TEST – Requires a serial number. I suspect it wants the unit serial number
and since I am using an 800XL it is looking in the wrong location and returning the error message
11th option BAUD RATE
12th option DISPLAY OPTIONS – As stated above this function lets you set both
the way the results are displayed and also if you want to run a continues cycle.
I did not check the continues cycle option but I guess it runs all the test on after
the other ?
13th option ITIA
14th option EXT AUDIO
Blank screen – May need an external speaker attached ?
15th option QUE SPEAKER
Blank screen but makes a tone when buttons are pressed
16th option BI CLOCK – blank screen probably the 800XL issue again
17th option ADJUST – blank screen and then nothing, may need to wait longer
but nothing seems to be happening
18th option OS ROM
