Serious #1 Posted February 11, 2014 Hi everyone, I'm doing some cleanup of the difficulty settings in the highscore.com database, aided by some fellow AtariAge members. When reviewing the Dragonfire manual, it makes no mention of the use of difficulty switches, so we assumed (at first) that his meant that the difficulty switches have no effect on this game. However, if you look at the scores on the game with difficulty set to A and B, there is an obvious difference: Dragonfire (Atari 2600 Expert/A) 4,300 killersquirel << 2,930 Serious 2,810 S.BAZ << Dragonfire (Atari 2600 Novice/B) 8,780 killersquirel << 7,280 heywoodfloyd 4,300 S.BAZ << So, two of the same players scored almost twice as much in difficulty mode B than mode A. I took a look through the source code, and found this: ; ; DELTA FIREBALLS ; LDA FPCTL ; DO FIREBALL SPEED WITH WAVENO E DIFF ASL ; SHIFT DIFFICULTY TO CARRY LDX PLAYNO BNE SKIP34 ASL SKIP34 LDY WAVENO LDA #0 ADC FBSPEEDS,Y STA T0 LDX #NUP0S-1 DEFBLOOP LDA P0YS,X CMP #DEAD BEQ NEXT05 ADC T0 ; FIREBALL SPEED IF PAL CMP #$95+15 ELSE CMP #$95 ENDIF BCC OKXX LDA #DEAD OKXX SKIP18 STA P0YS,X NEXT05 DEX BPL DEFBLOOP Without understanding the routine here, based on the comments, it appears to me that the fireball speed may be different based on the difficulty settings. I would appreciate any insight from someone who can decipher the source, or who knows the game better than I do. Quote Share this post Link to post Share on other sites
+Omegamatrix #2 Posted February 11, 2014 You are correct, the difficulty switch is used by this game. Also you have correctly found the place where it is used in the rom. When the difficulty switch is in PRO position the fireballs are faster. Kudos on being able to understand enough of the assembly to find that. 1 Quote Share this post Link to post Share on other sites
Serious #3 Posted February 11, 2014 Thanks very much for the help! Quote Share this post Link to post Share on other sites
NIKON #4 Posted February 11, 2014 Here is a video comparison... http://www.youtube.com/watch?v=LJcJ09Oa9QM&feature=youtu.be Quote Share this post Link to post Share on other sites
SoulBlazer #5 Posted February 12, 2014 Why wasn't this mentioned in the manual? I thought the differences in difficulty switches as a big thing back then. Quote Share this post Link to post Share on other sites
+Omegamatrix #6 Posted February 12, 2014 Why wasn't this mentioned in the manual? I thought the differences in difficulty switches as a big thing back then. Yeah, who knows? Maybe they thought it would be obvious to the user and it was an oversight. What's worse are games that use the other controller port and don't make mention of it anywhere. Towering Inferno comes to mind! Quote Share this post Link to post Share on other sites
