Mord Posted March 15, 2016 Share Posted March 15, 2016 Does 7800 basic compile into assembler or into a binary? Both. It'll make a .asm file and a .bin (And a .a78) file in the output. 1 Quote Link to comment Share on other sites More sharing options...
+xucaen Posted March 15, 2016 Share Posted March 15, 2016 Unfortunately, the asm that is produced doesn't seem compatible with the standard assembler dev kit available elsewhere. It's missing 7800basic_variable_redefs.h and several other .asm files, so I can't get any of the samples to build. Quote Link to comment Share on other sites More sharing options...
RevEng Posted March 15, 2016 Author Share Posted March 15, 2016 Those files are bundled with 7800basic in the includes directory. Quote Link to comment Share on other sites More sharing options...
+xucaen Posted March 15, 2016 Share Posted March 15, 2016 I tried copying them over to my other folder but it still wouldn't compile. Quote Link to comment Share on other sites More sharing options...
RevEng Posted March 16, 2016 Author Share Posted March 16, 2016 Yeah, it's hard to say without more info. Its possible the assembly includes other files not provided. It's probably going to be easier to just use the basic file, and compile it. Quote Link to comment Share on other sites More sharing options...
DonavinTheSuperGamer Posted June 6, 2016 Share Posted June 6, 2016 Hello, RevEng. I have downloaded this software and ran 'install_win.bat', which succeeded. According to your instructions that shows how to test installation, it states: To test your installation, several sample programs are included in the "samples" folder. "cd" to this folder and type: 7800bas simple.bas If successful, a file called simple.bas.a78 will be generated that you can run on an emulator. The sample program is not very interesting, but note how simple it was to write. Open sample.bas in a text editor and take a look at how it was written. I decided to move my 7800basic folder straight to the C Drive. So I put it in the Command Prompt an it stated. '7800bas' is not recognized as an internal or external command, operable program or batch file. Could I possibly be making a mistake? Quote Link to comment Share on other sites More sharing options...
DonavinTheSuperGamer Posted June 6, 2016 Share Posted June 6, 2016 Never mind. It worked. Quote Link to comment Share on other sites More sharing options...
+frankodragon Posted June 11, 2016 Share Posted June 11, 2016 I'm having problems with the score0 code. When it displays, it looks like this on the top right: No matter where I put it, it keeps looking like that. Quote Link to comment Share on other sites More sharing options...
RevEng Posted June 11, 2016 Author Share Posted June 11, 2016 160a characters are 4 pixels wide. If you want to use an 8 pixel font, use doublewide characters. 1 Quote Link to comment Share on other sites More sharing options...
+frankodragon Posted June 11, 2016 Share Posted June 11, 2016 160a characters are 4 pixels wide. If you want to use an 8 pixel font, use doublewide characters. Thanks. That was the problem- setting the displaymode to 160A. Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted July 19, 2016 Share Posted July 19, 2016 I've been out of the loop for a while. Is there a convenient way to make graphics with the 7800 compiler or are you stuck using The Gimp like when the program first debuted? I started something, what, two years ago? However, I moved and just lost interest in the project. The long, tedious process of importing graphics was part of the reason why. Quote Link to comment Share on other sites More sharing options...
+SmittyB Posted July 19, 2016 Share Posted July 19, 2016 I've been out of the loop for a while. Is there a convenient way to make graphics with the 7800 compiler or are you stuck using The Gimp like when the program first debuted? I started something, what, two years ago? However, I moved and just lost interest in the project. The long, tedious process of importing graphics was part of the reason why. I use GraphicsGale for the actual graphics and then use ImageMagick to convert to a 2BPP image. It can be a bit hit or miss as to how it orders the palette and sometimes whether the output can be imported by 7800BASIC but it (mostly) does a good job. 1 Quote Link to comment Share on other sites More sharing options...
+frankodragon Posted July 20, 2016 Share Posted July 20, 2016 When I made Fat Axl and tested it on real hardware, I noticed using a Sega Genesis/Mega Drive controller would cause the Game Over screen to loop when the game was turned on. Has anyone else had a similar issue using Genesis/MD controllers playing other games made with 7800Basic on real hardware? Quote Link to comment Share on other sites More sharing options...
Trebor Posted July 20, 2016 Share Posted July 20, 2016 When I made Fat Axl and tested it on real hardware, I noticed using a Sega Genesis/Mega Drive controller would cause the Game Over screen to loop when the game was turned on. Has anyone else had a similar issue using Genesis/MD controllers playing other games made with 7800Basic on real hardware? Playing the 7800basic games, T:Me Salvo and Dungeon Stalker I've never experienced such an issue. I utilize an Edladdin Seagull 78 Controller Adapter though with the Genesis controller. Are you using an adapter with the Genesis controller, or just plugging the controller directly to the console? 2 Quote Link to comment Share on other sites More sharing options...
+frankodragon Posted July 20, 2016 Share Posted July 20, 2016 Playing the 7800basic games, T:Me Salvo and Dungeon Stalker I've never experienced such an issue. I utilize an Edladdin Seagull 78 Controller Adapter though with the Genesis controller. Are you using an adapter with the Genesis controller, or just plugging the controller directly to the console? Directly into the console. Quote Link to comment Share on other sites More sharing options...
Mord Posted July 21, 2016 Share Posted July 21, 2016 Directly into the console. That's likely the cause then I guess. I don't think genesis controllers are perfectly compatible on their own. Then again I remember plugging a genesis controller in to my SMS (Actually a power base converter on a genesis) and trying to play a few SMS games (like Wonderboy in Monsterworld) and it... caused weird things to happen. 3 Quote Link to comment Share on other sites More sharing options...
Trebor Posted July 21, 2016 Share Posted July 21, 2016 That's likely the cause then I guess. I don't think genesis controllers are perfectly compatible on their own. Then again I remember plugging a genesis controller in to my SMS (Actually a power base converter on a genesis) and trying to play a few SMS games (like Wonderboy in Monsterworld) and it... caused weird things to happen. Add Graze Suit Alpha to the list of 7800basic games I've played with no issues having the Edladdin adapter attached with a Genesis controller. Franko, plugging the Genesis controller 'stand-alone' to the console may indeed result in undesirable side effects, hence the need for an adapter for it to interact and function properly with the console (Including the allocation and mapping of the two independent fire buttons). 2 Quote Link to comment Share on other sites More sharing options...
+frankodragon Posted July 22, 2016 Share Posted July 22, 2016 I gave those whom bought my game a slip of paper warning them not to directly plug a Sega Genesis controller. Just to make sure they know beforehand before I get someone telling me the Game Over screen rolls when the game's turned on. Quote Link to comment Share on other sites More sharing options...
RevEng Posted July 22, 2016 Author Share Posted July 22, 2016 As mentioned, it's a general issue with the console's 2-button circuitry and the (non-adapted) genesis controllers. Nothing to be done about it, and really no need to warn about it either. Lots of systems used the D-Sub 9, and lots of them don't work correctly on the 7800. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted August 12, 2016 Share Posted August 12, 2016 As mentioned, it's a general issue with the console's 2-button circuitry and the (non-adapted) genesis controllers. Nothing to be done about it, and really no need to warn about it either. Lots of systems used the D-Sub 9, and lots of them don't work correctly on the 7800. I'm going to post this sounding like I ignored the "Nothing to be done about it" part of your answer. Forgive me! Is there a way to make games Genesis joystick tolerant? Manually resetting whatever gets screwed up every iteration of the game loop? Quote Link to comment Share on other sites More sharing options...
Trebor Posted August 12, 2016 Share Posted August 12, 2016 I'm going to post this sounding like I ignored the "Nothing to be done about it" part of your answer. Forgive me! Is there a way to make games Genesis joystick tolerant? Manually resetting whatever gets screwed up every iteration of the game loop? Guaranteed 100% Genesis joystick tolerant games, plus the addition of correct joystick button behavior for games which utilize two independent button inputs, by this method. Additionally, this method too works great. For those that prefer not to utilize either of those methods provided, there is this third method. Last, but not least, there is a fourth method. 2 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted August 13, 2016 Share Posted August 13, 2016 Guaranteed 100% Genesis joystick tolerant games, plus the addition of correct joystick button behavior for games which utilize two independent button inputs, by this method. Additionally, this method too works great. For those that prefer not to utilize either of those methods provided, there is this third method. Last, but not least, there is a fourth method. I may have mis-read those links but they all look like hardware solutions. What in particular makes this not resolvable in software? I'm interested from a technical perspective. Quote Link to comment Share on other sites More sharing options...
Mord Posted August 13, 2016 Share Posted August 13, 2016 I may have mis-read those links but they all look like hardware solutions. What in particular makes this not resolvable in software? I'm interested from a technical perspective. Well, checking some pinout charts with google images, it looks like the +5V pin is in different locations on the two controllers. On the genesis it's on pin 5, On the 7800 it's on pin 7. I suspect this can cause a lot of problems on it's own given the 5V pin I believe supplies power to the rest of the buttons for detecting if they're pressed or not. So plug in a genesis controller to a 7800, and you'd probably have to hold down the select button just to get any other buttons to work. And they'll work in odd ways even then, or not at all. The Right Button on the 7800 (The pin the 7800 will be looking for Right Button info) is the +5V line on the genesis controller - so no switch there at all. I'm just talking out of my ass here given I'm not overly familiar with the genesis controller and it's been over a decade since I've seriously looked at digital circuits. 3 Quote Link to comment Share on other sites More sharing options...
RevEng Posted August 13, 2016 Author Share Posted August 13, 2016 I'm going to post this sounding like I ignored the "Nothing to be done about it" part of your answer. Forgive me! Is there a way to make games Genesis joystick tolerant? Manually resetting whatever gets screwed up every iteration of the game loop? You can make the genesis work on a 7800 if you stick to the VCS one-button mode. I believe this should force one-button mode in 7800basic... SWCHB=%00010100 joybuttonmode=%00010100 In 7800 2-button mode, the wiring is just plain incompatible. Nothing to reset or fix... the 7800 2-button circuit uses a button-press detection scheme that's electrically incompatible with the genesis controller. Genesis controllers weren't designed for these systems, so it's a happy coincidence they work in any capacity at all. Unless it's an optional thing, it's probably a bad idea to favor un-adapted genesis controllers over native controllers for 7800 games. Most 7800 players will avoid these controllers - or purchase adapters such as those that Trebor listed - because they don't work on any 7800 2 button games. @Mord, I agree that from a circuit perspective it appears the genesis controller's multiplexer chip shouldn't work on a 2600 (or 7800 in 2600 controller mode), but it does work in the real world, and quite robustly. I think the multiplexer chip is getting back-powered over the select line. (also, the select line is an independent concept from the select button. The select button is read through one of the other lines. The select line is an input to the controller multiplexer chip, and the console chooses which button sets it can read by bringing the select line high or low.) 2 Quote Link to comment Share on other sites More sharing options...
RevEng Posted October 2, 2016 Author Share Posted October 2, 2016 I've posted an updated 0.5 version of 7800basic at 7800.8bitdev.org. There were a some minor fixes here and there, and I documented the music tracker commands. If you've been using the high score module, you probably need to look at the "Feature Modules" section of the manual. Due to general fixes eating up the meager 4k 7800basic normally takes, the high score code needs to be used as an external module now. Enjoy! 4 Quote Link to comment Share on other sites More sharing options...
