Developing a new language - ACUSOL
Pab
Oh, for the....
I have to stop programming late at night. This was the line causing all the trouble...
   If p.VBank <> ProgramBank Then JSRB(p.VAddress,p.VBank) Else JSR(p.VAddress);
In other words, if the procedure is in a bank other than the one you are in, switch to that bank and JSR. Unfortunately, not only did I not check whether the procedure being called is in shared memory (i.e., no bank), but it never occurred to me that a routine in one bank would be calling another bank!
Nothing is ever foolproof because we fools are so ingenious.
Writing bank switching code is a lot of fun [irony]. ;) There's nothing stopping code in one bank calling a routine in another bank (providing the bank-switching routine is situated outside of the banking area), as long as the bank switching routine ensures that RTS in the target routine causes the originating bank to seamlessly switch back in before the instruction following the original JSR is hit.
This is the bankswitching code I came up with for the Ultimate/Incognito PBI BIOS, if it's of any interest:
; Must be outside of banking area
longjsr ; call with address of routine-1 in x,a and bank # in y (note only the processor status and Y are preserved on return)
	jsr Exec
	php
	dec BankSp ; stack pointer (initialized to zero)
	ldx BankSp
	lda BankStack,x ; bank # stack
	sta BANK ; activate bank
	plp
    	rts
Exec
	pha ; save address
	txa
	pha
	sty BANK ; activate bank
	tya
	inc BankSp
	ldx BankSp ; save bank # on stack
	sta BankStack,x
	rts
ljsr	.macro
	ldx #< [:1-1]
	lda #> [:1-1]
	ldy #:2
	jsr longjsr
	.endm
To perform a in inter-bank JSR, you just write "LJSR <ROUTINE> <BANK>". For PORTB banking, you can just use the value here stored in BANK as an index into an array of PORTB values.
Edited by flashjazzcat
I just don't think it's safe and reliable, and therefore it's inadvisable. I'd have to use the Altirra debugger to verify this, but I suspect that (for example) when DOS 2.5 grabs a sector from the RAMdisk (requiring writes to PORTB), it won't necessarily restore the banking register's original state (it may simply be hard-coded to restore the base bank). Whether this is the case, I'm not completely certain, but I can't say it isn't the case, and unless it's written somewhere that direct binary loads into extended RAM are guaranteed to work with all widely used DOS packages, then my advice would be: don't assume it will work.
That's a pretty cynical point of view, that all programmers are retards who don't know how to code. I generally work on the assumption that the programmer knew what he was about, so in the case of DOS 2.5 that it will correctly save and restore the $D301 mask as required. Now I've generally only worked with SpartaDos, so maybe I've been spoiled by the fact that Gustafson is a fairly clever and organised fellow.
That Polish ram check routine looks clever, but I'm not convinced it's correct for all cases. It's only checking that $4000 is ram, and it only checks $0 and $4000 of the main bank. So it will detect that a Rambo XL has two extra banks, main bank $8000 and $C000. It also assumes a specific switching pattern, which might not be true. The only way to be sure is to strobe all 254 combinations of $D301 and check each 16K page.
Where did I say all programmers are retards? Maintaining the base bank during a binary load wouldn't be a retarded decision on the part of the DOS developer: in fact it's perfectly reasonable, unless you assert somewhere that DOS supports binary loading directly into extended banks (which it might: I'm happy to be referred to documentation or circumstantial evidence that supports the idea that all DOSes can absolutely be relied upon to support this facility, in which case happy days. Saving and loading of buffers out of banked RAM is certainly mandatory, so maybe it should work). It's obvious that if you assume binary loads into extended RAM are possible but DOS happens to reinstate the base bank, your software will crash. You can take that risk, or implement some simple workarounds to ensure the application is in control of the situation at all times.
Well, I've used it but I have no special attachment to it and if anyone can suggest or write something better for Pab, I'm sure he'd be happy to use it. :)
Well, to answer the question once and for all, here's a short program which causes two segments to be loaded directly into consecutive extended banks. The segments are then called in turn when the load is complete.
	icl 'common.inc'
	icl 'macros.inc'
	org $2000
Start
	mva BaseBank portb
	jsr printf
	.byte 'This is the main bank',155,0
	mva banks portb ; call code in bank 1
	jsr Bank1
	mva banks+1 portb ; call code in bank 2
	jsr Bank2
	mva BaseBank portb
	rts
Init1 ; test for extended RAM and enable bank 1
	lda portb
	sta BaseBank
	jsr MapExtRAM
	cpb ExtBanks #2
	bcs @+
	jsr printf
	.byte 'No extended RAM!',155,0
	jmp ($0a)
	mva banks portb ; switch in bank #1
	rts
	icl 'printf.s'
	icl 'bankmap.s'
	org $2E2
	.word Init1
	org $4000 ; bank #1
Bank1
	jsr printf
	.byte 'This is bank 1',155,0
	rts
	org $3000
Init2
	mva Banks+1 portb ; second bank
	rts
	org $2E2
	.word Init2
	org $4000 ; bank #2
Bank2
	jsr printf
	.byte 'This is bank 2',155,0
	rts
	org $2E0
	.word Start
bankload.xex
It works perfectly under SpartaDOS X, which is the only DOS I tested it with. But if it works under every other popular DOS, then it would be reasonable to load binary segments directly into extended RAM.
No, it's not reasonable, it's completely unreasonable. Since the ability to change banks exists, stuffing a fixed bank value in would be sloppy programming by a poor coder.Proper technique would be to save the existing mask, change only what you needed to change for the function requested and then put the original mask back. For example, I would also expect no DOS written for the XL/XE series would ever assume the OS rom was switched in, because it may very well not be given the existence of things like the translator disk.
That's the other problem with that Polish routine: he keeps masking the OS rom back in, which is an unwarranted assumption.
No, it's not reasonable, it's completely unreasonable. Since the ability to change banks exists, stuffing a fixed bank value in would be sloppy programming by a poor coder. Proper technique would be to save the existing mask, change only what you needed to change for the function requested and then put the original mask back. For example, I would also expect no DOS written for the XL/XE series would ever assume the OS rom was switched in, because it may very well not be given the existence of things like the translator disk.
Well, look here: I've made assumptions about all kinds of things in the past and run into no end of problems because I credited third-parties with common sense. So perhaps I've become a little cautious as a result. But in any case, I ran the test program above with DOS 2.5 as well, and it worked, so it looks as if I was wrong and it's safe enough to load binary segments directly into extended RAM. But I wouldn't assume without seeing it with my own eyes. :D
Yeah: I used it in a program which also manipulated BASIC and required a RAM-based OS. It was no problem to mask the required bits when extracting values from the table.
I suspect, that you confuse reason with specification.
If the specification says, 'We will change the bank without restoring it', that's perfectly reasonable. Then it's on the programmer of an application to maintain a shadow of the bank register and test, that the correct bank is on.
That's the reason, we have to have APIs.
E.g. when DOS 2.5 is developed under the assumption, that, if the ramdisk is running, no other program is using the banks, then it's perfectly reasonable not to restore the bank, because it's faster.
Edited by JoSch
Just waiting for the updated version of Lazarus (they released 1.2, I was using 1.0.8) to install on my computer before I get back to work on this beast.
I did get a chance to weed out a lot of redundant code in my variable assign routine. I had multiple checks for conditions (are both variables outside of banked area? Are they in the same bank? Is one banksafe and the other not? etc.) under each of the possibilities for assigning value to a variable (numeric constant, another variable, a function call, an object method). Then it occurred to me that to properly support banking I only needed to write one subroutine that would do all the checking and assign the value accordingly.
So I just wrote a subroutine that would check whether the location being written to needs to be banked or not, switch the bank accordingly, store the value, and pop back into the original bank (or, if the code itself is in a banked area, JSR to a runtime routine to do the whole thing). Then I just meticulously went through my old routine removing all the checks and replacing LDA xx/STA yy.
I also realized just how much of an assembler I'd actually written into procedures in my Pascal source, to the point that sometimes at first glance it's hard to tell whether you're reading a Pascal program or a 6502 assembler program.
Procedure TCompiler.BankPoke(Addr : Word; Bank : Byte);
Begin
   If (Bank <> ProgramBank) And ((Addr > $3FFF) And (Addr < $8000)) Then Begin
      PHA;
      LDAImm(Lo(Addr));
      STA($CB);
      LDAImm(Hi(Addr));
      STA($CC);
      LDAImm(Bank);
      STA($CD);
      PLA;
      JSR(BankPokeAddress);
   End;
End;
I get a similar feeling looking at the source to bankload.xex. :) MADS assembler source can look quite approachable.
Eureka.
I got a little creative with this one. Self-modifying code! A routine in the runtime switches banks, JSR's to the routine it's calling, then pops back into the original bank. How does it know where to JSR? The program plugs the address right into the JSR statement. (In this compilation's case, at $1F5A and $1F5B.)
Source code compiled:
MODULE ORG=$1F00
USES Print
MODULE ORG=$4000:1
PROC Bank1
   PrintE("Hello from bank #1!")
RETURN
MODULE ORG=$4000:2
PROC Bank2
   PrintE("Hello from bank #2!")
RETURN
MODULE ORG=$4000:3
PROC Bank3
   PrintE("Hello from bank #3! Let me check in on bank 2 again.")
   Bank2
RETURN
MODULE ORG=$4000:4
PROC Bank4
   PrintE("Hello from bank #4!")
RETURN
MODULE // Return to where we left off in main bank.
PROC MAIN
   Bank1
   PrintE("Back from bank 1.")
   Bank2
   Bank3
   Bank4
RETURN
The procedures in the banks are loaded directly into banked RAM during binary load, with brief routines at $480 to do the switching through INIT as needed.
test16.bin
Trying it under MyDOS with different memory sizes....
1088K upgrade: works.
576K Compy: Crash in detection routine.
576K: Detects 20 banks.
320 Compy: Crash in detection routine.
320 Rambo: Crash in detection routine.
Stock XE: Works.
Crashes are happening when attempting to verify bank $3D. Happening under both Altirra and Atari800Win
Yes. Here is the original source. With a few modifications, it should look familiar. :)
0000        10          *=   $480
D40E        20 NMIEN    =    $D40E
00C9        30 BANKS    =    $C9
00CA        40 OLDPORTB =    $CA
D301        50 PORTB    =    $D301
8000        60 SAVETABLE =   $8000
0480        65 BANKTABLE =   $480
            70 START
0480 78     80          SEI
0481 AD0ED4 90          LDA  NMIEN     ; TURN OFF INTERRUPTS
0484 48     100         PHA
0485 A900   110         LDA  #0
0487 8D0ED4 120         STA  NMIEN
048A AD01D3 130         LDA  PORTB
048D 85CA   140         STA  OLDPORTB
048F 48     150         PHA
0490 A200   170         LDX  #0
            180 TESTLP1
0492 8E01D3 190         STX  PORTB
0495 AD0040 200         LDA  $4000     ; SAVE MEMORY
0498 9D0080 210         STA  SAVETABLE,X
049B AD0140 220         LDA  $4001
049E 9D0081 230         STA  SAVETABLE+256,X
04A1 8A     240         TXA
04A2 8D0040 250         STA  $4000
04A5 18     260         CLC
04A6 6904   270         ADC  #4
04A8 8D0140 280         STA  $4001
04AB E8     290         INX
04AC D0E4   300         BNE  TESTLP1
04AE A000   310         LDY  #0
            320 TESTLP2
04B0 8E01D3 330         STX  PORTB
04B3 EC0040 340         CPX  $4000
04B6 D00E   350         BNE  NOTSAME
04B8 8A     360         TXA
04B9 18     370         CLC
04BA 6904   380         ADC  #4
04BC CD0140 390         CMP  $4001
04BF D005   400         BNE  NOTSAME
04C1 8A     410         TXA
04C2 998004 420         STA  BANKTABLE,Y; ADD TO TABLE
04C5 C8     430         INY
04C6 E8     440 NOTSAME INX
04C7 D0E7   450         BNE  TESTLP2
04C9 88     460         DEY            ; IGNORE MAIN BANK ($FF)
04CA 84C9   470         STY  BANKS     ; # EXPANDED BANKS IN Y
04CC A200   490         LDX  #0
            500 RESTORE
04CE 8E01D3 510         STX  PORTB
04D1 BD0080 520         LDA  SAVETABLE,X ; RESTORE OLD VALUES
04D4 8D0040 530         STA  $4000
04D7 BD0081 540         LDA  SAVETABLE+256,X
04DA 8D0140 550         STA  $4001
04DD E8     560         INX
04DE D0EE   570         BNE  RESTORE
            580 ;
04E0 68     590         PLA
04E1 8D01D3 600         STA  PORTB
04E4 68     610         PLA
04E5 8D0ED4 620         STA  NMIEN     ; RE-ENABLE INTERRUPTS
04E8 58     630         CLI
            640 ;
            650 ALLDONE
04E9 60     660         RTS
Ah. I just look at the Polish one and my mind goes apfjasjhowgio hweitghwiphpsad. Trying to figure out WTF is going on with it at points. Yours seemed straightforward enough. I like to understand what is going on, either by logic or by comments, and the comments did not help me at all there.
Let me stare at it a little while longer. Maybe it will make sense then.
I can't say I worried too much about how it worked. It appeared reliable enough to propagate on the Net, and performed well in tests: therefore I used it.
Just found this: interesting reading, should you wish to write your own test:
http://web.archive.org/web/20071231110133/http://www.s-direktnet.de/homepages/k_nadj/main.html
There is yet another generic routine at the foot of the page, however.
