Satoshi Matrix #1 Posted March 19, 2014 Last weekend, I got a deal I couldn't pass up - a perfect condition Coleco Gemini, both its original controllers, two other third party controllers, a "Y" splitter (for Warlords I'm assuming), cables, and 28 games in perfect condition with all their manuals as well, for $30. I had played the Gemini when I was a kid, and always thought it was the best looking and best designed 2600. So in this day and age, I just gotta replace the RF. I know there are boards out there that can be built for composite, and even boards that can get S-Video out of the 2600. What about the Gemini?Does anyone know if the Gemini can be S-Video modded, and what parts would be needed? I can provide high res shots of the board if need be. Quote Share this post Link to post Share on other sites
ApolloBoy #2 Posted March 21, 2014 Yes since it's pretty much the same as a regular 2600. Quote Share this post Link to post Share on other sites
snstay #3 Posted March 21, 2014 (edited) Try game tech us. Jason dose a great job and i see coleco gemini is one of his options. http://www.game-tech.us/ Edited March 21, 2014 by snstay Quote Share this post Link to post Share on other sites
ColecoGemini #4 Posted March 21, 2014 Try game tech us. Jason dose a great job and i see coleco gemini is one of his options. http://www.game-tech.us/ I'd be a bit concerned about this site's accuracy, because the example screenshot they show for the Coleco Gemini page is a screencap of Pole Position II for the Atari 7800, an entirely different console/mod. Quote Share this post Link to post Share on other sites
snstay #5 Posted March 21, 2014 I think thats just a stock screenshot. Believe me he knows what hes doing. He helped me when i messed up my 2600 mod. Quote Share this post Link to post Share on other sites
atariguy1021 #6 Posted March 22, 2014 (edited) I recently acquired my first Gemini and here's the install I just completed... almost, I'm waiting on a switch to use for the pause function. The stock switch doesn't stick out far enough to be used. The purple wire that's sticking out of the screw post is for the pause switch. I omitted the trimmers on the mod board and put in the appropriate resistors after dialing in the values that looked best. With where I chose to locate the board, there simply wasn't enough clearance for them. I used a 8 pin mini din connector for all outputs and there is an adapter cable that goes from the 8 pin to composite, s-video, and right + left audio. The cable fits in the stock opening snugly and I may end up filing the hole just a touch to loosen up the fit a bit. I will likely add a power LED that shines up through the power switch hole when I'm ready to button it all up. Edited March 22, 2014 by atariguy1021 3 Quote Share this post Link to post Share on other sites
+iesposta #7 Posted July 4, 2014 How did I miss this?! First, thanks for taking the time and posting pictures. Much appreciated. Second, great job using one connector for all the signals, why don't I think of these things? . Love that. I love its controller. Some games work great with the short stick like Jr. PAC Man. The paddles are easy to clean since the potentiometer carbon is part of the circuit board and not in a metal can. Do you have a Harmony? You should test the TIA by running "2 or 3" and Omegamatrix's "Circus Atariage" balloon test. Have you found any games that have odd display problems? I've seen some problems with 1977 gray TIA's and in a 7800 with Byte Knight's and my DK Arcade 2600. (Link in my signature.) 2or3.bin BalloonTrial(NTSC).bin Quote Share this post Link to post Share on other sites
atariguy1021 #8 Posted July 4, 2014 Thanks! I actually sold that console, but I have another Gemini around that I'm going to mod in the same fashion. I have a Harmony Cart and will give those games a try when I complete the work. Quote Share this post Link to post Share on other sites
+iesposta #9 Posted July 4, 2014 Which parts did you remove? Did you cut any traces? I'm probably the only person in the world interested LOL Quote Share this post Link to post Share on other sites
atariguy1021 #10 Posted July 4, 2014 I didn't cut any traces. I did remove some resistors though. I had a few people message me with regards to this and gave them the pin equivalents between the Atari TIA and the clone TIA in the Gemini. The pins of interest for the video mod are below. I found some information that others had posted, but they contained errors. I removed the resistors to isolate the pins that are bent up during the standard video mod. Atari Gemini 2 5 5 6 6 8 7 4 8 7 9 9 12 27 13 28 2 Quote Share this post Link to post Share on other sites
Tupin #11 Posted September 22, 2014 Bumping this because I've got a Gemini coming and am looking at this ElectricSentimentalities modboard that I'm assuming is based on the LHE board that went into open source recently. Thanks for the equivalents! Quote Share this post Link to post Share on other sites
