ballyalley #1 Posted April 8, 2014 I've created 50 "stickers" for each key on a PC keyboard that are required to emulate the Atari 8-bit computer when running under the Altirra emulator. These "stickers" have been sent to a place called www.4keyboard.com. The company will recreate the keys using vector graphics. Eventually the stickers for use with the Atari will be available for sale from them. I'm not sure how much they'll cost. Be aware that this company, besides already making dozens (maybe hundreds?) of keyboard stickers for various uses already makes a set of Commodore 64 stickers that I've been using-- and enjoying!-- for several years now. My first tentative idea of keyboard stickers already came up once before back in July of 2011. See my original posting for additional information: http://atariage.com/forums/topic/184504-atari-keyboard-stickers/ Atari 8-Bit Keymapping for Attached JPG FilesThere are 50 keys that need stickers for use with the PC's host keyboard and the Atari 8-Bit Altirra emulator. Each key has been created individually and saved in an Photoshop documents. I've saved the original images as jpgs and attached them all in a zip file so that other people can examine the work that has been done already. Here are all the keys that I've made: Atari 8-Bit Keys (JPGs).zip These files are not the final product. These were created for the designer(s) at 4keyboard.com to help guide them in creating their own sticker set. Here is the key mapping to the PC keys followed by the name of the Atari key created for it.A-Z Keys (26 Keys) A: A-Key with Graphic Symbol for Atari 800 in Altirra.jpg B: B-Key with Graphic Symbol for Atari 800 in Altirra.jpg C: C-Key with Graphic Symbol for Atari 800 in Altirra.jpg D: D-Key with Graphic Symbol for Atari 800 in Altirra.jpg E: E-Key with Graphic Symbol for Atari 800 in Altirra.jpg F: F-Key with Graphic Symbol for Atari 800 in Altirra.jpg G: G-Key with Graphic Symbol for Atari 800 in Altirra.jpg H: H-Key with Graphic Symbol for Atari 800 in Altirra.jpg I: I-Key with Graphic Symbol for Atari 800 in Altirra.jpg J: J-Key with Graphic Symbol for Atari 800 in Altirra.jpg K: K-Key with Graphic Symbol for Atari 800 in Altirra.jpg L: L-Key with Graphic Symbol for Atari 800 in Altirra.jpg M: M-Key with Graphic Symbol for Atari 800 in Altirra.jpg N: N-Key with Graphic Symbol for Atari 800 in Altirra.jpg O: O-Key with Graphic Symbol for Atari 800 in Altirra.jpg P: P-Key with Graphic Symbol for Atari 800 in Altirra.jpg Q: Q-Key with Graphic Symbol for Atari 800 in Altirra.jpg R: R-Key with Graphic Symbol for Atari 800 in Altirra.jpg S: S-Key with Graphic Symbol for Atari 800 in Altirra.jpg T: T-Key with Graphic Symbol for Atari 800 in Altirra.jpg U: U-Key with Graphic Symbol for Atari 800 in Altirra.jpg V: V-Key with Graphic Symbol for Atari 800 in Altirra.jpg W: W-Key with Graphic Symbol for Atari 800 in Altirra.jpg X: X-Key with Graphic Symbol for Atari 800 in Altirra.jpg Y: Y-Key with Graphic Symbol for Atari 800 in Altirra.jpg Z: Z-Key with Graphic Symbol for Atari 800 in Altirra.jpg Function KeysNote: Function keys F1 and F7-F12 have blue text on them. This text is for use with the Altirra emulator only. It serves no purpose on the Atari-side. F1: Function Key - F1 Key with Graphic Symbol for Atari 800 in Altirra.jpg F2: Start-Key for Atari 800 in Altirra.jpg F3: Select-Key for Atari 800 in Altirra.jpg F4: Option-Key for Atari 800 in Altirra.jpg F5: Reset-Key for Atari 800 in Altirra.jpg F6: Help-Key for Atari 800 in Altirra.jpg F7: Function Key - F7 Key with Graphic Symbol for Atari 800 in Altirra.jpg F8: Function Key - F8 Key with Graphic Symbol for Atari 800 in Altirra.jpg F9: Function Key - F9 Key with Graphic Symbol for Atari 800 in Altirra.jpg F10: Function Key - F10 Key with Graphic Symbol for Atari 800 in Altirra.jpg F11: Function Key - F11 Key with Graphic Symbol for Atari 800 in Altirra.jpg F12: Note Used - This key is unused in the emulator. No sticker was created. Special Keys: , [Comma]: Comma-Key with Graphic Symbol for Atari 800 in Altirra.jpg . [Period]: Period-Key with Graphic Symbol for Atari 800 in Altirra.jpg ; [semicolon]: Semicolon-Key with Graphic Symbol for Atari 800 in Altirra.jpg ` [back Tick]: Invert - Fuji Symbol Key [For ` Key] for Atari 800 in Altirra.jpg Caps Lock: Caps-Key for Atari 800 in Altirra.jpg Clear: Clear-Key for Atari 800 in Altirra.jpg Delete: Key for Atari 800 in Altirra.jpg END: Invert - Fuji Symbol Key [For END Key] for Atari 800 in Altirra.jpg Enter: Return-Key for Atari 800 in Altirra.jpg Esc: Esc-Key for Atari 800 in Altirra.jpg Insert: Insert-Key for Atari 800 in Altirra.jpg Pause/Break: Break-Key for Atari 800 in Altirra.jpg Tab: Tab-Key for Atari 800 in Altirra.jpg What Do You Think? I'd like some advice. Do you like what you see? Are all the stickers for keys that may be needed available in what I've created? I want to make sure that I haven't missed any keys, so this is for you Atari 8-bit emulation users to look over carefully. Be aware that I am not making the final sticker-set-- there is a designer at 4keyboard.com who will be doing that. I have no final say in what will be eventually available-- I can only help them by giving them as much data needed to get started on a good sticker set. I'll direct the person that I've been in communication with over at 4keyboard.com here so that he can see the ideas that you all come up with. This is your chance to have your input heard for the creation of these Atari keyboard stickers, so don't miss out! Adam Quote Share this post Link to post Share on other sites
Irgendwer #2 Posted April 9, 2014 http://atariage.com/forums/topic/205431-cks12-make-yourself-a-christmas-present/?do=findComment&comment=2640741 Quote Share this post Link to post Share on other sites
foft #3 Posted April 9, 2014 Great. I'll have a look at these later when I can access the zip:). For the FPGA side I'm using the real Atari layout, so having stickers would be great. ie each ps2 key maps to a position in the Atari keyboard matrix. Few initial thoughts... I don't see the number keys there, am I missing something? How about a 'power button'/coldstart key in addition to reset? Quote Share this post Link to post Share on other sites
ballyalley #4 Posted April 9, 2014 http://atariage.com/forums/topic/205431-cks12-make-yourself-a-christmas-present/?do=findComment&comment=2640741 These are great-- I've not seen them before. They are not what I'm looking for. I decided not to include the international character set on the keyboard. I may actually purchase these anyway... I kind of like them. These would even work well on a real Atari. Quote Share this post Link to post Share on other sites
ballyalley #5 Posted April 9, 2014 I don't see the number keys there, am I missing something? How about a 'power button'/coldstart key in addition to reset? The number buttons aren't included because the Altirra emulator maps the PC keyboard keystokes to the Atari. For example, Shift-2 on a real Atari gets you quote marks. On the PC keyboard pressing Shift-2 gets you the "@" symbol. So, if you press Shift-2 on the PC's keyboard under Altirra you still get the "@" sign (which normally requires you to press Shift-8 on the Atari). All of the PC keyboard strokes work this way. It's quite handy. For this reason, I didn't actually have to make any stickers for the numbers. The "Power" button requires you to press Shift-F2 (meaning Shift-Reset). I wanted to fit "Power" on the F2 key, but there was just no way to do it without the key's sticker becoming much too crowded. Plus, I have no way to convey to the user to press the shift key. Quote Share this post Link to post Share on other sites
foft #6 Posted April 9, 2014 I see, but I think it's better to have stickers for all Atari keys, then they can support Altirra and an actual direct Atari style mapping. Or even use them on a real Atari job to refresh symbols:) Quote Share this post Link to post Share on other sites
ballyalley #7 Posted April 9, 2014 I see, but I think it's better to have stickers for all Atari keys, then they can support Altirra and an actual direct Atari style mapping. Or even use them on a real Atari job to refresh symbols:) It looks like "all Atari keys" gets the winning vote. 4Keyboard.com would like to see a "full" set of stickers. I just got 4keyboard.com's first pass at creating the stickers. They gave me permission to post what they have made so far here on this forum. These stickers are still in flux-- they may change, and there will be certainly be more stickers. Here is what they came up with thus far: This is based on the keys that I sent to them that I created in Photoshop. This will put together in a 24-hour turn-around time! What else would you like to see added to this sticker set? Does anyone notice something that needs to be fixed with what has been made so far? 1 Quote Share this post Link to post Share on other sites
foft #8 Posted April 10, 2014 Looking good:) As well as numbers +*- and =, along with some fine arrows:) <> with clear/insert. [] on the ,. keys. I wonder whether the key itself can have more weight than the ctrl symbol. Good for typing in basic stuff but otherwise less useful. My 600xl actually doesn't have them at all! For the f keys do we still need them to say 'f10' etc? Since the Atari doesn't have them? Well I think 1200xl has f1 to f4. I agree having debugger keys included is good though different emus etc may have different ones. Quote Share this post Link to post Share on other sites
ballyalley #9 Posted April 10, 2014 As well as numbers +*- and =, along with some fine arrows:) <> with clear/insert. [] on the ,. keys. For the f keys do we still need them to say 'f10' etc? I think that "+*- and =, along with [...]" are considered part of the "full" set. If there are extra "blank" stickers then maybe function keys can be printed without key descriptions, but otherwise I think that is staying. I should hear back today with another example and progress. I'll post what I'm sent. Quote Share this post Link to post Share on other sites
ballyalley #10 Posted April 11, 2014 Here is the newest version of the Atari stickers: They are waiting for feedback to wrap-up this project. I have yet to look it over, I'll do that later today. However, I want to post the "stickers" here to get as much feedback as quickly as possible. Do you see anything that needs changes? Or additions? Quote Share this post Link to post Share on other sites
gozar #11 Posted April 11, 2014 Here is the newest version of the Atari stickers: atari8bit screenshot 11042014.jpg They are waiting for feedback to wrap-up this project. I have yet to look it over, I'll do that later today. However, I want to post the "stickers" here to get as much feedback as quickly as possible. Do you see anything that needs changes? Or additions? What about other emulators? Atari800 has F12 as Warp Speed F1 as the emulator menu. The option, select, start keys are different too. Quote Share this post Link to post Share on other sites
foft #12 Posted April 11, 2014 Great, looking good. OK, just comparing with my 600XL and XEGS... and some online stuff. I suggest these adjustments: i) F1-F4 for 1200XL (I guess we can just leave them off since we have real F keys, but good to show they are 'Atari keys') ii) Can we put '[' on the ',' key? iii) Can we put ']' on the '.' key? iv) Can we put '<' as the main function on 'Clear'? v) Can we put '>' as the main function on 'Insert'? vi) Great to have the +*-= arrow keys. I vote for the Atari style inverse arrows:-) I voted before for my preference for slightly faded or different colour inverse video symbols. Also I still vote for separating functions from 'the key underneath', then they can be placed wherever people want. Emulators change over time and these keys, even in Altirra, may eventually change location - or be remapped by the user Quote Share this post Link to post Share on other sites
+Ripdubski #13 Posted April 12, 2014 I vote for the Atari style inverse arrows:-) Thats right, if your going to do it, do it right. Quote Share this post Link to post Share on other sites
ballyalley #14 Posted April 12, 2014 What about other emulators? Atari800 has F12 as Warp Speed F1 as the emulator menu. The option, select, start keys are different too. Understood. The sticker sheet will have keys that won't be used by people that use all of the Atari emulators. If a user uses the Altirra emulator then some stickers, such as "Warp Speed" and others, will be useful. For other emulators those stickers will be "extra" ones that won't be applied to the keyboard. There are separate stickers for other Atari functions keys. The Help, Start, Select, Option and Reset keys have keys without the host's function key printed under it. Users of other emulators can use these keys instead. I do use Altirra and I still plan to use the Atari function keys without the host key printed on it. Quote Share this post Link to post Share on other sites
gozar #15 Posted April 12, 2014 That's exactly what I was thinking as a solution! :-) Quote Share this post Link to post Share on other sites
ballyalley #16 Posted April 12, 2014 Great, looking good. OK, just comparing with my 600XL and XEGS... and some online stuff. i) F1-F4 for 1200XL (I guess we can just leave them off since we have real F keys, but good to show they are 'Atari keys') ii) Can we put '[' on the ',' key? iii) Can we put ']' on the '.' key? iv) Can we put '<' as the main function on 'Clear'? v) Can we put '>' as the main function on 'Insert'? vi) Great to have the +*-= arrow keys. I vote for the Atari style inverse arrows:-) I voted before for my preference for slightly faded or different colour inverse video symbols. Also I still vote for separating functions from 'the key underneath', then they can be placed wherever people want. Emulators change over time and these keys, even in Altirra, may eventually change location - or be remapped by the user Good points all. I will request each of these keys in addition to what's already on the sticker sheet. I asked what the limit was for the amount of stickers on a sheet and was told, "We can make any size because we don’t have limitations in the length for sticker (limit 46 meter roll)" Now that's really something, isn't it?! Quote Share this post Link to post Share on other sites
foft #17 Posted April 12, 2014 Oooh, 46 metres! Wow with that there can be a version for each Atari and each emulator:) Quote Share this post Link to post Share on other sites
ballyalley #18 Posted April 14, 2014 Here is the latest update to the Atari keyboard stickers: I haven't had time to look this over yet. I know that 4keyboard.com wants to wrap this project up. I'll need any feedback/suggestion in the next few hours to send it off to them. Quote Share this post Link to post Share on other sites
foft #19 Posted April 14, 2014 Only thing I'd ask them now is if they can quickly combine the ',' and '.' with the control symbol and the shift symbol. They are on two keys right now. Quote Share this post Link to post Share on other sites
ballyalley #20 Posted April 14, 2014 Only thing I'd ask them now is if they can quickly combine the ',' and '.' with the control symbol and the shift symbol. They are on two keys right now. I won't be able to reply to them until tomorrow evening (Tuesday). I just heard back from them a couple of minutes ago and they said that they'd rather get it right the first time. "One day or one week," are the exact words used. I'm glad to hear that. This also will give some people time to view the newest version of the keyboard stickers and suggest changes/additions if they have any. Quote Share this post Link to post Share on other sites
ballyalley #21 Posted April 21, 2014 I got the latest sticker sheet to check over. All suggested changes mentioned in this thread are on it, so I approved the sticker sheet. I'll get an email in a few days saying when it will be ready to order and how much it will be. I'll let you all know. Thanks for the suggestions. Quote Share this post Link to post Share on other sites
ballyalley #22 Posted May 6, 2014 The Atari sticker sheet is done and is available for sale right now. I started a seperate topic about it here: http://atariage.com/forums/topic/225142-atari-8-bit-sticker-for-sale/ Thanks to everyone that made suggestions. This is what my Dell keyboard now looks like when I use Altirra: Finding the keys that I want to use now is a breeze. I love it! 1 Quote Share this post Link to post Share on other sites
foft #23 Posted May 6, 2014 I was just about to post that they are for sale - having just ordered:) Thanks. 1 Quote Share this post Link to post Share on other sites
+Stephen #24 Posted May 7, 2014 The Atari sticker sheet is done and is available for sale right now. I started a seperate topic about it here: http://atariage.com/forums/topic/225142-atari-8-bit-sticker-for-sale/ Thanks to everyone that made suggestions. This is what my Dell keyboard now looks like when I use Altirra: Atari Keyboard.jpg Finding the keys that I want to use now is a breeze. I love it! Nice - the gf will be getting me one of those KBs, and I am ordering stickers tonight Quote Share this post Link to post Share on other sites
