Gazoo Posted April 13, 2014 Share Posted April 13, 2014 (edited) GPLMOVE.txt Attached is the GPLMOVE examples file. I've always used it to move stored code in Grom to execute in CPU memory as per the example near the end of the file and it has worked flawlessly. However, there are some examples that seem to contradict the format. The format is listed as MOVE #bytes,source,destination. The first example, after the first 2 short paragraphs, shows the format MOVE #bytes,destination,source. I am looking to use the GPL Move code to move data from non-indexed cpu memory to non-indexed cpu memory and want to make sure I use the correct format before typing all this code in blindly only to find it doesn't work. Can someone provide any insight as to the exact nature of the GPL Move code to move data from non-indexed cpu memory to non-indexed cpu memory? Thanks, Gazoo EDIT: Assembling the code MOVE >1234,@>A000,@>2000 into a compiled image will give 1 of 2 results. 1. >3512, >348F, >9D00, >8F1D,>00 or 2. >3512, >348F, >1D00, >8F9D,>00 I just need to know which. And does it really move FROM >A000 TO >2000? or FROM >2000 TO >A000? Edited April 13, 2014 by Gazoo Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 13, 2014 Share Posted April 13, 2014 The GPL Programmer's Guide and Thierry's site both say your format of—MOVE #bytes,source,destination—for the GPL Assembler code is correct. However, the machine code does it the other way round. I think I read somewhere a rationalization of that scheme, but can't remember where. The example you mention is not GPL Assembler, it is an explanation of the GROM machine code generated. The third MOVE statement (your example) should assemble to (1.) and it would move from >A000 to >2000—or, following the flow of the machine code, to >2000 from >A000, which are, of course, the same thing. That's how I read it. I haven't actually assembled any GPL ALC, however. Someone whose actually assembled GPL ALC, like Rich, will likely weigh in soon. ...lee Quote Link to comment Share on other sites More sharing options...
Gazoo Posted April 13, 2014 Author Share Posted April 13, 2014 (edited) The GPL Programmer's Guide and Thierry's site both say your format of—MOVE #bytes,source,destination—for the GPL Assembler code is correct. However, the machine code does it the other way round. I think I read somewhere a rationalization of that scheme, but can't remember where. The example you mention is not GPL Assembler, it is an explanation of the GROM machine code generated. The third MOVE statement (your example) should assemble to (1.) and it would move from >A000 to >2000—or, following the flow of the machine code, to >2000 from >A000, which are, of course, the same thing. That's how I read it. I haven't actually assembled any GPL ALC, however. Someone whose actually assembled GPL ALC, like Rich, will likely weigh in soon. ...lee Well, what I'm interested in is the Grom machine code generated, because that's what I'm entering into the memory editor. I think I see where i was misreading the file, got it now. Thanks. Gazoo Edited April 13, 2014 by Gazoo Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 13, 2014 Share Posted April 13, 2014 Well, what I'm interested in is the Grom machine code generated, because that's what I'm entering into the memory editor. The confusing part is that some of the moves appear to compile into code which has the source first, such as from Grom to CPU (line <0016>). Other moves appear to compile into code which has the destination first, such as from CPU to CPU (line <0011>). Gazoo The GPL machine code always has the destination first. The example you cite is no different. Here's my stab at breaking it down per the method in GPLMOVE.TXT: ===Listing Fragment================================== <0016> 6030 31,12,34 MOVE >1234,G@>C000,@>2000 6033 8F,9D,00 6036 C0,00 ===Breakdown========================================= MOVE >1234,G@>C000,@>2000 >31 ...MOVE (>31 = move immediate count bytes from GROM to CPU RAM or VRAM) >1234 ...>1234 bytes >8F ...to CPU RAM (non-indexed) >9D00 ...at >2000 (>9D00 + >8300 = >2000) ...from GROM/GRAM (by virtue of MOVE opcode) >C000 ...at >C000 ...lee Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 13, 2014 Share Posted April 13, 2014 (edited) Oops! Did not see your edit in time. Sorry. ...lee Edited April 13, 2014 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
RXB Posted July 9, 2014 Share Posted July 9, 2014 I totally missed this thread when posted. Found it when I typed in search for GPL RND MOVE in GPL from GPL Assember is this sample for the PI command in XB. *********************************************************** * NUD FOR PI *********************************************************** NPI MOVE 8,G@CONPI,@FAC Load constant PI XML CONT CONPI BYTE >40,3,14,15,92,65,35,90 * 3.1415992653590E+00 *********************************************************** In GPL Assember by Ryte Data the format is MOVE #BYTES,FROM,TO The GPL dis-assembly is always backwards from that. Quote Link to comment Share on other sites More sharing options...
Willsy Posted July 9, 2014 Share Posted July 9, 2014 Just weighing in here but not really qualified... If my hazy memory serves me correctly, I think some of the confusion may have arisen from the RAG GPL Assembler. IIRC, it was developed completely independantly of TI. They (RAG) changed (or rather invented, since they had nothing else to go on) the formats of a couple of GPL commands. Pretty distant hazy memory from circa 1989, so I could be wrong!! Quote Link to comment Share on other sites More sharing options...
RXB Posted July 9, 2014 Share Posted July 9, 2014 Just weighing in here but not really qualified... If my hazy memory serves me correctly, I think some of the confusion may have arisen from the RAG GPL Assembler. IIRC, it was developed completely independantly of TI. They (RAG) changed (or rather invented, since they had nothing else to go on) the formats of a couple of GPL commands. Pretty distant hazy memory from circa 1989, so I could be wrong!! Yea I used to us the RAG GPL Assembler and RAG GPL Linker, but found most of the extra features superfluous. The other issue was the lack of examples left much unexplained and a mystery on how to use these features. I do think the RAG SAMS Assembler and RAG C SAMS support a better package. Quote Link to comment Share on other sites More sharing options...
