Sign in to follow this
rwt
Spartados access hard drive from command-line in emulator
In Spartados 4.46, running under Atari800Win or Altira, how can I access the hard drive (emulated on the host pc) from the command line? From basic I can save or load from "H1:", but the command line doesn't recognize "H1:", "H:", or "HDD:" as a device.
I am not sure, but I think you should change config.sys in SDX.
DEVICE SIO -> change that into DEVICE SIO /A
I did not test this, but since that line (without the /A) makes that all (S)IO uses SDX vector, it can not work with other devices.
With /A it uses SIO vector of os. Since HDD access is a tweak, I guess the /A is needed.
But as said: not tested, so it might fail anyway ;)
That won't work for H:, which needs CIO access, not SIO.
AFAIK, there is no easy way to directly access the classic H: device from the SDX command line. There was a program a while ago to copy files to and from H:, but I can't find it. With Altirra, there are a couple of alternatives:
  • Mount a folder on an emulated drive. This will appear to SDX as a regular SDFS disk, and therefore all regular disk access commands will work with it. However, it is read-only.
  • Set up PCLink, using the PCLINK.SYS driver from the Toolbox disk. This is the SDX version of H: and gives full read-write access. Use it with /A and SIO patch enabled for high speed access.
It seems to work with Sparta 3.3 and A800win... but I certainly don't know how. :)
Go to http://sdx.atari8.info/index.php?show=en_addons and get the Emupack. It contains a driver to let you access the emulated drive.
