RobR
Combat & Air-Sea Battle question
Sorry if this question has been asked and answered somewhere else, but I have never see it asked:
Why does Comabt and Air-Sea Battle have a time limit of 2 min 15 sec? At first, I thought of the 7 bit Maximum number of 128, but that would equal 2 min 8 sec.
This has been answered in detail before - from a programmer's perspective IIRC. Anyone remember the thread?
Other games Star Ship, Street Racer, Indy 500 all had the time limit. Back before the 2600 came out, there were a lot of b&w game consoles that mainly played Pong variants. When these units were played for a long time or left on, they would "burn" the image into the screen! You could then watch tv with an image of a pong or other design there all the time! This made a lot of consumers upset, so the early 2600 games would "time-out" and start to do the color shift to keep burn-in from happening to a limit. Even variations of the game used different color schemes to help keep burn-it low. I remember a woman who loved Tetris on the NES and would play it for hours, and later there was a permanent "tower" in the middle of their big projection screen!
Early projector sets used super-bright CRT tubes. Very susceptible to burn in. But I don't believe the burn-in time out has anything to do with the 2:15 game limit.
Actual frame-rate of the 2600 is usually less than broadcast (59.97 for NTSC) - 59.9227 should be the rate for a 262 scanline display.
But still the maths doesn't help there - it adds barely 1/10th of a second.
A look at the program code would probably reveal what's going on. Maybe tied to the RIOT timers ?
I think I've worked it out.
Time counter starts with value $80 and gets incremented once every 64th frame = 8192 frames total game time.
8192 / 60 = 136.53 seconds
8192 / 59.97 = 136.6 seconds
8192 / 59.9227 = 136.7 seconds
High bit of counter likely used as "game in progress" flag. Simple compare can be used as trigger to flash score during final part of game.
Edited by Rybags
I know about the "burn in" effect, but I was talking about the in game timer. Just seemed a weird #, that's all
Sort of weird. Maybe they wanted 2 minute game time and the "every 64th" turned out the best compromise.
There's a counter that's incremented every frame, no doubt it probably gets used for other things as well.
Checking for "every 64th" is easy, just AND #$3F and Z flag set = 64th frame.
They could easily enough had made it 2 minutes almost exactly by setting the initial value differently at game start - a value of $90 instead of $80 would probably be sufficient.
