+JAC! #1 Posted May 13, 2014 Created a Linux 32-bit executable of 1.9.8, maybe somebody can test and confirm if it works on Linux 32/64 bit. mads-1.9.8-linux-i386.zip Quote Share this post Link to post Share on other sites
gozar #2 Posted May 14, 2014 Do you have some sample code to compile? Quote Share this post Link to post Share on other sites
snicklin #3 Posted May 14, 2014 (edited) Created a Linux 32-bit executable of 1.9.8, maybe somebody can test and confirm if it works on Linux 32/64 bit. Hi Peter, Yes, confirmed, this works on Linux Mint 16 (MATE) - 64 bit. Thank you for this. Hmm... maybe I could change my toolchain to run in Linux now? Could you explain how that you produced this? Then if a new version of MADS comes out, it doesn't have to be you completing the compiles. Edited May 14, 2014 by snicklin Quote Share this post Link to post Share on other sites
flashjazzcat #4 Posted May 14, 2014 Note there are compilation instructions in the MADS documentation: http://mads.atari8.info/mads_eng.html#komp These are the directions I followed when recompiling under Linux for the first time. Quote Share this post Link to post Share on other sites
+JAC! #5 Posted May 14, 2014 (edited) I have updated the compilers download archive on my site. http://www.wudsn.com/index.php/ide/installation#InstallingCompilers It also has the scripts to compile and the example files.- ATASM 1.07 recompiled- MADS 1.9.8 compiled for Windows and Linux- KickAss 3.34 included >Could you explain how that you produced this? Then if a new version of MADS comes out, it doesn't have to be you completing the compiles.I have an Ubuntu 12.04 32-bit VM ware image (finally, again) where I test the IDE and now also have everything in place again for compiling.For ATASM I have created a 32-bit and 64-bit Linux version also. So maybe some of you can also test that,too. As you can see here, Mac OS X is a bit of a problem. I do have a VM ware image for that now also, but since it's rather old Mac OS X version and compiling there will take some effort, I'd be happy if people could fill in for the missing versions in http://www.wudsn.com/index.php/ide/installation#InstallingCompilers. Edited May 14, 2014 by JAC! Quote Share this post Link to post Share on other sites
flashjazzcat #6 Posted May 14, 2014 (edited) I managed to install the necessary software to compile MADS under Snow Leopard some months back, but it did involve a lengthy series of downloads. Unfortunately I forget the specifics. If I can recreate the set up again I'll post details. Edited May 14, 2014 by flashjazzcat Quote Share this post Link to post Share on other sites
+JAC! #7 Posted May 15, 2014 In fact I do have a similar VMWare image like the one for Ubuntu also for Mac OS 10.5.5. But due to several reasons I cannot update as it would break the VM. So compiling is actually possible, but since I don't seem to get Java 1.7 onto it, it's becoming a dead end for the other stuff I 'l like to test. Quote Share this post Link to post Share on other sites
gozar #8 Posted May 21, 2014 I managed to install the necessary software to compile MADS under Snow Leopard some months back, but it did involve a lengthy series of downloads. Unfortunately I forget the specifics. If I can recreate the set up again I'll post details. Apple has a download for the command line tools, but they might have removed the 10.6. The command line tools and brew help when compiling. Quote Share this post Link to post Share on other sites
+JAC! #9 Posted May 22, 2014 Compling itself it not the issue. I have VMs for all relevant platforms where I can compile. Upload wil be available soon. Only the OS X is becoming a dead end for me in terms of Java... Quote Share this post Link to post Share on other sites
flashjazzcat #10 Posted June 13, 2014 Just compiled this if it's still of use; perhaps it can be added to the compiler package if it's not already present: mads_1.9.8_OS_X.zip Note: since we were discussing compilation of MADS under Mac OS X previously, I reacquainted myself with the pre-requisites. Under Mac OS X 10.6.8, I installed XCode 4.2 for Snow Leopard (this was hard to find), then the Free Pascal Compiler. I then compiled the MADS sources exactly as directed in the assembler's documentation. Quote Share this post Link to post Share on other sites
+JAC! #11 Posted June 13, 2014 (edited) Thanks Jon. It actually was included already here: http://www.wudsn.com/index.php/106-site-update-2014-14-05 As mentioned above compiling works fien now, but I'm stuck on 10.5.5 with Java 1.5, but that's another topic. Edited June 13, 2014 by JAC! Quote Share this post Link to post Share on other sites
flashjazzcat #12 Posted June 13, 2014 Thanks Jon. It actually was included already here: http://www.wudsn.com/index.php/106-site-update-2014-14-05 I was sure I'd seen an updated compiler package on your website, but it flew by my eyes and I somehow couldn't find it again after that: hence I compiled it in the wee small hours last night. But if it's already there, great. Quote Share this post Link to post Share on other sites
