TheRealAnubis
SpartaDos 3.2d manual or help?
Hi,
Well, I was finally able to track down a few floppies and test my drive - it may have a broken bezel, but it works great! (The drive looked a lot smaller in the picture..) I've loaded up one un-labeled disk and it states that it is Spartados 3.2d.
I've done a quick search online and I've not found a manual or much info on what commands to use. I've tried commands from a PDF that was Spartados 2.x and those don't seem to do anything.
Anyone have a PDF manual, or maybe just a few commands to get me started?
Thanks!
Edited by TheRealAnubis
Most of the 3.x versions use similar commands. Look for FTe 3.2g. Therw should be a help file with it.
I am using my phone now, and I have no access to my files.
Google will help you.
Hmmmm - I found some info online about FTe 3.2g, but I've already tried DIR to get a directory listing and it says "ERROR DIR" and the drive never tries to access.. I'll try more later - thanks!
Are you at a READY prompt?
if so, you are in basic.
type DOS <enter> then you should see D1:
from there, type DIR.
Else when booting, Hold down OPTION key when turning on. This will disable basic.
James
APPENDIX E - ATARI DOS 2 VS SPARTADOS
Atari DOS 2 Menu and SpartaDOS Equivalents SpartaDOS Semi Equivalent
ATARI DOS 2.0S
A. DISK DIRECTORY DIR
B. RUN CARTRIDGE CAR
C. COPY FILE COPY
D. DELETE FILE ERASE
E. RENAME FILE RENAME
F. LOCK FILE PROTECT(SEE UNERASE)
G. UNLOCK FILE UNPROTECT
H. WRITE DOS FILES (SEE FORMATIINIT/XINIT)
I. FORMAT DISK FORMAT/XINITIINIT/AINIT
J. DUPLICATE DISK DUPDSK
K. BINARY SAVE SAVE/APPEND
L. BINARY LOAD LOAD/OFF _LOAD/fname
M. RUN AT ADDRESS RUN
N. CREATE MEM.SAV (NOT NEEDED WITH
RESIDENT DOS)
O. DUPLICATE FILE SPCOPY/XCOPY
SpartaDOS Commands With no Atari DOS 2 Equivalent
?DIR AT_RS232 BASIC Batch Files BOOT
BUFS CHKDSK CHTD CHVOL CREDIR
CWD DELDIR DIS_BAT DUMP FORMAT
INIT KEY LOCK MDUMP MEM
MEMLO OFF _LOAD PAUSE PORT PRINT
PUTRUN RD130 RDAXLON RDBASIC RPM
SET SPCOPY TD TIME TREE
TSET TYPE UNERASE UNLOCK VERIFY
XCOPY XDIV XINIT XKEY XTD
Edited by Fox-1 / mnx
Hi,
Thanks!
Here's a error number list and commands summary. From Complete SpartaDOS Construction Set, about pages 70 to 85.
Also the 'Complete SpartDOS construction set for version 3.2d.
(text versions, not pdf, read in notepad on PC)
sp32dcomerr.zip
spartdoc.zip
Edited by russg
James
There was my first problem! I thought something was broken! HA! That's a good bit to know!
ATARI DOS 2.0S
C.  COPY FILE                                  COPY
                                               RESIDENT DOS)
Very Useful indeed!
