Sign in to follow this
frankodragon
An error on my end or is it the machine
I'm following the Zelda example for 7800basic only to use my own graphics and I've run into a snag when compiling the file. I don't know if it's the computer's fault (bad dimm) or something else? There's not much about the reverse-indexed error and "cartridge size is not a multiple of 4k bytes."
Here's a screenshot:
It's not a bad dim, but likely something wrong in the source. Usually the error means you've run out of ROM space.
Try posting your .bas, or better still a zip of .bas + gfx.
The screenshot says you've overrun the ROM space.
"-48205 bytes of ROM Space left in the main area"
Try set romsize 48k at the top of your code. As RevEng mentioned, posting your source & gfx directory is always helpful too.
