blakespot #1 Posted July 12, 2014 I have an early, proper 520ST with no internal drive and I want to mount an HxC2001 in one of the external floppy drives. Has anyone done this? Is the proper power there, etc? Thanks. bp Quote Share this post Link to post Share on other sites
moonlight_mile #2 Posted July 12, 2014 I never really found a nice clean looking way to mount the hxc internally. I am not good with building cases and the such so I gave up and just got a cased model. I have the power and ribbon cable sticking out of my drive bay. Quote Share this post Link to post Share on other sites
blakespot #3 Posted August 11, 2014 My original 520ST has no internal drive connector. Is it possible to out this in an SF314 / SF354? Or is this not possible? Thanks. bp Quote Share this post Link to post Share on other sites
+wood_jl #4 Posted August 21, 2014 Of course it is possible. If you search this ST sub-forum for "HxC" then some threads will pop up. Here are a couple: http://atariage.com/forums/topic/159593-hxc-floppy-emulator-any-st-owners-here-getting-one/ http://atariage.com/forums/topic/165297-where-to-source-st-floppy-cables-power-extension/ Note - however - that I have been using older drives. I **believe** (I do not know) that in some of the very last Atari drives, they changed something - like dropping one of the voltages, and moving to non-standard connector(s). I do not have one of these drives. The ones I have use the standard 34-pin PC-style data cable, and standard PC-style voltages. I'm just mentioning this because I'm pretty sure I saw it somewhere that some of the last drives were lower-voltage (or something) and had weird connectors. Someone who has more experience with the later ST floppy drives, please chime in. Addendum: This thread...... http://atariage.com/forums/topic/211924-old-atari-sf354-hxc-floppy-emulator/ ....has pictures of the non-standard connector drive. I thought it was the newer drives, as I use the older ones and they're standard 34-pin. Good luck! Quote Share this post Link to post Share on other sites
