S.BAZ Posted August 9, 2014 Share Posted August 9, 2014 Dino Eggs 257 Yeah, that does happen. You get so many monsters zipping around with the massive leg of Mama Dino descending from above it get to be almost impossible and worth it just to leave. It's a reat game though. Very challenging and inventive. maybe I'm missing something. far as I can tell, it actually IS impossible sometimes. even if you got a fire burning. there's no jumping & no way to go up except by the ladders & sometimes there just isn't a ladder. I just have to hope to warp up there. but if I spawn below & there's no ladder, I see no way to get up. same with spawning above & no ladder. I can't drop down to get more eggs because I know it will cost me a life seeing as I can't climb back up to the portal. one time it actually started me off on a ledge I couldn't get back to if i were to drop off, & no eggs. this was the 1st level. so I had no choice but to abandon & lose 20+ pts., or else die! so I got off to a whopping start with -24 pts or something like that. ...or is there some way I hadn't noticed? but yes I'm liking the game it's very addicting. it just seems a little heavy on the luck-factor. Quote Link to comment Share on other sites More sharing options...
darthkur Posted August 10, 2014 Share Posted August 10, 2014 maybe I'm missing something. far as I can tell, it actually IS impossible sometimes. even if you got a fire burning. there's no jumping & no way to go up except by the ladders & sometimes there just isn't a ladder. I just have to hope to warp up there. but if I spawn below & there's no ladder, I see no way to get up. same with spawning above & no ladder. I can't drop down to get more eggs because I know it will cost me a life seeing as I can't climb back up to the portal. one time it actually started me off on a ledge I couldn't get back to if i were to drop off, & no eggs. this was the 1st level. so I had no choice but to abandon & lose 20+ pts., or else die! so I got off to a whopping start with -24 pts or something like that. ...or is there some way I hadn't noticed? but yes I'm liking the game it's very addicting. it just seems a little heavy on the luck-factor. That shouldn't be happening. There should always be a way to get around. The only way I've ever been blocked away from something is if I started a fire in a bad place and couldn't get around it. Quote Link to comment Share on other sites More sharing options...
S.BAZ Posted August 11, 2014 Share Posted August 11, 2014 That shouldn't be happening... woah I just noticed (by accident) you can wrap around through to the other side! that was my problem. makes a big difference... Dino Eggs: 535 1 Quote Link to comment Share on other sites More sharing options...
classicgamer_27330 Posted August 20, 2014 Author Share Posted August 20, 2014 Shonobi 36,100 Quote Link to comment Share on other sites More sharing options...
darthkur Posted August 20, 2014 Share Posted August 20, 2014 (edited) Dino Eggs - 413 I know it's a lame update but it proves I'm still working on it. Edited August 20, 2014 by darthkur Quote Link to comment Share on other sites More sharing options...
