d3bug #1 Posted July 21, 2014 I am using Altirra 2.40 to run bobsterm. No matter what command I issue inside the terminal (for example: ATDI BFBBS.NO-IP.COM 23) it returns "ERROR"... I have tried all baud rates, and I just don't know what I am missing... shouldn't this be connecting? PLEASE HELP. Quote Share this post Link to post Share on other sites
David Baldwin #2 Posted July 21, 2014 You have to setup your serial port options first when you set those up add the ip address in the dial proxy address like this for yyzbbs 99.116.104.171 and port numb 23 when thats all setup go back into the bobterm terminal and type atdt them press control them the m key bobterm with dial out and your on line good luck. David B Quote Share this post Link to post Share on other sites
phaeron #3 Posted July 24, 2014 ATDI should also work. Check that you have the translation in BobTerm set to Ascii and that you can get an OK prompt with AT<Enter>. Quote Share this post Link to post Share on other sites
scotty #4 Posted July 25, 2014 I am on my android tablet, and don't have my computer in front of me. But there is a native PC program that I can not think of the name of that does Atascii. Works great, but I have not used it in a long time and forget the name. Quote Share this post Link to post Share on other sites
