Pixelboy #26 Posted December 19, 2015 Where can I find his Java tool? The link seems to be broken. Thanks. Check post #23 in this thread. 1 Quote Share this post Link to post Share on other sites
First Spear #27 Posted December 19, 2015 That's cool and I will try that on my Win10 machine , but I was thinking about the Java version. Thanks. Check post #23 in this thread. Quote Share this post Link to post Share on other sites
+digress #28 Posted December 19, 2015 see post # 23 Where can I find his Java tool? The link seems to be broken. Thanks. Quote Share this post Link to post Share on other sites
LoTonah #29 Posted December 20, 2015 Post #23 links to a .ZIP file, which extracts to an .EXE file. This is NOT the java version! Does anyone have it to share? Thanks! Quote Share this post Link to post Share on other sites
youki #30 Posted December 20, 2015 Post #23 links to a .ZIP file, which extracts to an .EXE file. This is NOT the java version! Does anyone have it to share? Thanks! It is done in Java. The .exe is just a compiled java executable for windows. Quote Share this post Link to post Share on other sites
LoTonah #31 Posted December 22, 2015 Pity. I was hoping that it would be a portable Java program that would work on Linux or Mac. It is done in Java. The .exe is just a compiled java executable for windows. Quote Share this post Link to post Share on other sites
youki #32 Posted December 22, 2015 Pity. I was hoping that it would be a portable Java program that would work on Linux or Mac. Did you try it with WinE on Mac ? Quote Share this post Link to post Share on other sites
First Spear #33 Posted December 22, 2015 I was asking about the Java version specifically because I wanted to change how the output file is written so I could have a format that would be easier to import into my programming environment. Since the exe is locked up I will write a small program to just modify the output myself. Thanks. The tool is fun and useful! Quote Share this post Link to post Share on other sites
First Spear #34 Posted December 23, 2015 (edited) Thanks Digress. Awesome save. The file and all others related are not on the Internet Archive (Wayback Machine), so it seems that you shared the only bits left on earth. I am trying to understand how the save file stores things. This is a save file from a white noise generation. I don't understand "period and attenuation". Is the first number the length in time-slices and the second is the pitch? Thanks. MODE 2 SIZE 120 START 0 END 21 193 3 135 3 149 2 71 2 81 2 85 2 89 2 91 2 95 2 99 2 103 2 103 2 107 2 109 2 111 2 115 2 119 2 119 2 121 2 125 2 127 2 127 2 I am almost there. I think. Thanks again. I do have it. Here I located it and uploaded it to my webspace. http://www.eriscreations.com/downloads/CVSoundFX.zip Edited December 23, 2015 by First Spear Quote Share this post Link to post Share on other sites
+digress #35 Posted December 23, 2015 I haven't analyized the sound data file. but the first number is the note data the second number appears to be the volume 0-15 most likely. mode most likely is white noise versus or tone. If you just want the sound for os7 use export to assembly and you get something like this: >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> .module sound .globl sfx_sproing_3 .area _CODE sfx_sproing_3: .db 0xc0,0x93,0xa2,1 .db 0xc0,0x91,0xa2,2 .db 0xc0,0x8f,0xa2,1 .db 0xc0,0x8b,0xa2,2 .db 0xc0,0x89,0xa2,1 .db 0xc0,0x87,0xa2,1 .db 0xc0,0x85,0xa2,1 .db 0xc0,0x83,0xa2,1 .db 0xc0,0x81,0xa2,1 .db 0xc0,0x7f,0xa2,2 .db 0xc0,0x7b,0xa2,1 .db 0xc0,0x79,0xa2,1 .db 0xc0,0x73,0xa2,1 .db 0xc0,0x6f,0xa2,1 .db 0xc0,0x69,0xa2,1 .db 0xc0,0x61,0x92,1 .db 0xc0,0x59,0x92,1 .db 0xc0,0x53,0x92,1 .db 0xc0,0x49,0x92,1 .db 0xc0,0x3b,0x92,1 .db 0xc0,0x2f,0x92,1 .db 0xc0,0x1b,0x92,1 .db 0xc0,0x07,0x92,1 .db 0xc0,0xf7,0x81,1 .db 0xc0,0xe7,0x81,1 .db 0xc0,0xcf,0x81,1 .db 0xc0,0xb7,0x81,1 .db 0xc0,0xa9,0x71,1 .db 0xc0,0x97,0x71,1 .db 0xc0,0x89,0x61,1 .db 0xc0,0x73,0x61,1 .db 0xc0,0x61,0x51,1 .db 0xc0,0x51,0x51,1 .db 0xc0,0x3f,0x51,1 .db 0xc0,0x2f,0x41,1 .db 0xc0,0x1d,0x41,1 .db 0xc0,0x0b,0x41,1 .db 0xc0,0xf5,0x40,1 .db 0xc0,0xe7,0x40,1 .db 0xc0,0xd1,0x40,1 .db 0xc0,0xbb,0x40,1 .db 0xc0,0xaf,0x40,1 .db 0xc0,0xa1,0x40,1 .db 0xc0,0x93,0x40,1 .db 0xc0,0x7f,0x40,1 .db 0xc0,0x6f,0x40,1 .db 0xc0,0x61,0x40,1 .db 0xc0,0x55,0x50,1 .db 0xc0,0x4b,0x60,1 .db 0xc0,0x43,0x60,1 .db 0xc0,0x39,0x70,1 .db 0xc0,0x35,0x80,1 .db 0xc0,0x31,0x90,1 .db 0xc0,0x2b,0xb0,1 .db 0xd0 which you can convert to work directly in a sound data file static const byte sproing[]= { 0xc0,0xdd,0xb2,1, 0xc0,0xdb,0xb2,1, 0xc0,0xd7,0xb2,1, 0xc0,0xd3,0xb2,1, 0xc0,0xcf,0xb2,1, 0xc0,0xc3,0xb2,1, 0xc0,0xbb,0xb2,1, 0xc0,0xad,0xa2,1, 0xc0,0x99,0xa2,1, 0xc0,0x85,0xa2,1, 0xc0,0x6d,0x92,1, 0xc0,0x4d,0x92,1, 0xc0,0x2b,0x92,1, 0xc0,0xfb,0x81,1, 0xc0,0xd3,0x81,1, 0xc0,0xaf,0x71,1, 0xc0,0x91,0x71,1, 0xc0,0x73,0x61,1, 0xc0,0x59,0x51,1, 0xc0,0x41,0x51,1, 0xc0,0x29,0x51,1, 0xc0,0x17,0x41,1, 0xc0,0x07,0x41,1, 0xc0,0xf7,0x40,1, 0xc0,0xeb,0x40,1, 0xc0,0xdd,0x40,1, 0xc0,0xd3,0x50,1, 0xc0,0xc9,0x60,1, 0xc0,0xc1,0x70,1, 0xc0,0xbb,0x80,1, 0xd0 }; Thanks Digress. Awesome save. The file and all others related are not on the Internet Archive (Wayback Machine), so it seems that you shared the only bits left on earth. I am trying to understand how the save file stores things. This is a save file from a white noise generation. I don't understand "period and attenuation". Is the first number the length in time-slices and the second is the pitch? Thanks. MODE 2 SIZE 120 START 0 END 21 193 3 135 3 149 2 71 2 81 2 85 2 89 2 91 2 95 2 99 2 103 2 103 2 107 2 109 2 111 2 115 2 119 2 119 2 121 2 125 2 127 2 127 2 I am almost there. I think. Thanks again. 2 Quote Share this post Link to post Share on other sites
First Spear #36 Posted August 20, 2018 Uh oh. I lost my local copy of the tool, and the link at http://eriscreations.com/downloads/CVSoundFX.zipappears to now 404. Where else can I get a .zip? Thanks. Quote Share this post Link to post Share on other sites
carlsson #37 Posted August 20, 2018 Close, but no cigar :-( https://web.archive.org/web/20140813004700/http://newcoleco.dev-fr.org/ 1 Quote Share this post Link to post Share on other sites
newcoleco #38 Posted August 23, 2018 (edited) Uh oh. I lost my local copy of the tool, and the link at http://eriscreations.com/downloads/CVSoundFX.zipappears to now 404. Where else can I get a .zip? Thanks. Close, but no cigar :-( https://web.archive.org/web/20140813004700/http://newcoleco.dev-fr.org/ During the past 8 years, I'm having bad luck with technology; I lost 3 computers and various HDD including the one containing a copy of my blog. This issue erased part of my 20 years of coding. Anyway, here's the missing download file, but not sure which version it is. EXE + SRC CVSoundFX.zip Edited August 23, 2018 by newcoleco 3 Quote Share this post Link to post Share on other sites
Milli Vee #39 Posted November 8, 2019 I know this is a very old post but can someone point me to an example of using the export assembly code? As en example I created this simple noise (below) and can see that it is in the standard sound data format OS7 wants I am just unsure how I would go about playing it. Any example code in z80 would be great. Milli sfx_test_1: .db 0x40,0x44,0x30,4 .db 0x40,0xe1,0x30,1 .db 0x40,0xdb,0x30,1 .db 0x40,0xd1,0x30,1 .db 0x40,0xc5,0x30,2 .db 0x40,0xf1,0x30,1 .db 0x40,0x03,0x31,1 .db 0x40,0x0d,0x31,1 .db 0x40,0x17,0x31,1 .db 0x40,0x21,0x31,1 .db 0x40,0x2d,0x31,1 .db 0x40,0xfb,0x30,1 .db 0x40,0xeb,0x30,1 .db 0x40,0xe5,0x30,1 .db 0x40,0xff,0x30,1 .db 0x40,0x1d,0x31,1 .db 0x40,0x25,0x31,2 .db 0x40,0x1b,0x31,1 .db 0x40,0xf1,0x30,1 .db 0x40,0xdf,0x30,1 .db 0x40,0xd7,0x30,1 .db 0x40,0xcd,0x30,1 .db 0x40,0xd1,0x30,1 .db 0x40,0xd7,0x30,1 .db 0x40,0xdd,0x30,1 .db 0x40,0xe3,0x30,1 .db 0x40,0xe9,0x30,1 .db 0x40,0xf5,0x30,1 .db 0x40,0xfb,0x30,1 .db 0x40,0x05,0x31,1 .db 0x40,0x11,0x31,1 .db 0x40,0x0d,0x31,1 .db 0x40,0xcb,0x30,1 .db 0x40,0xc3,0x30,1 .db 0x40,0xcb,0x30,1 .db 0x40,0xd1,0x30,1 .db 0x40,0xd7,0x30,2 .db 0x40,0xdf,0x30,1 .db 0x40,0xe1,0x30,1 .db 0x40,0xe5,0x30,1 .db 0x40,0xed,0x30,1 .db 0x40,0xe3,0x30,1 .db 0x40,0xdf,0x30,1 .db 0x40,0xdd,0x30,1 .db 0x40,0xd7,0x30,5 .db 0x40,0xd5,0x30,1 .db 0x40,0xcf,0x30,1 .db 0x40,0xb3,0x30,2 .db 0x40,0xb1,0x30,1 .db 0x40,0xad,0x30,1 .db 0x40,0xa5,0x30,1 .db 0x40,0x9f,0x30,2 .db 0x40,0xd3,0x30,1 .db 0x40,0xe1,0x30,1 .db 0x40,0xeb,0x30,1 .db 0x40,0xf5,0x30,1 .db 0x40,0x27,0x31,1 .db 0x40,0x2f,0x31,1 .db 0x40,0x39,0x31,1 .db 0x40,0x43,0x31,1 .db 0x40,0x4f,0x31,1 .db 0x40,0x57,0x31,1 .db 0x40,0x59,0x31,3 .db 0x40,0x44,0x30,1 .db 0x40,0x55,0x31,1 .db 0x40,0x44,0x30,1 .db 0x40,0x53,0x31,1 .db 0x40,0x44,0x30,1 .db 0x40,0x4d,0x31,1 .db 0x40,0x44,0x30,1 .db 0x40,0x1b,0x31,1 .db 0x40,0x0f,0x31,1 .db 0x40,0xf3,0x30,1 .db 0x40,0xef,0x30,1 .db 0x40,0xe7,0x30,1 .db 0x40,0xe5,0x30,1 .db 0x40,0xe1,0x30,1 .db 0x40,0xdd,0x30,1 .db 0x40,0xd9,0x30,2 .db 0x40,0xdf,0x30,1 .db 0x40,0xe3,0x30,1 .db 0x40,0xe1,0x30,1 .db 0x40,0x44,0x30,23 .db 0x50 Quote Share this post Link to post Share on other sites
